Welcome to the North American Subaru Impreza Owners Club Thursday July 19, 2018
Old 01-04-2001, 11:04 PM   #1
V6
Member#: 2703
Y2K GC8
Silver forever
Smile Anyone have installed the remote fuel door kit successfully?
Hi,
Are there any complete detail step by step instructions?
Thanks
V6 is offline   Reply With Quote
Old 01-04-2001, 11:38 PM   #2
Rubasu
Member#: 1418
MY00 2.5RS
Post
Check AZScooby.com i think I remember seeing something about that there. Not sure though.
Good Luck
Rubasu
Rubasu is offline   Reply With Quote
Old 01-04-2001, 11:51 PM   #3
V6
Member#: 2703
Y2K GC8
Silver forever
Post
I have tried already and there is no info.
That's why I am asking.
I know many members got this kit but still no one have detail instructions with pics of the complete installation.
Old 01-05-2001, 12:11 AM   #4
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
Talking
Somewhere online I read instructions for the fuel door, I remember them saying that routing the cable was the hardest part. I just routed a chunk of 4 gauge copper from my trunk to my battery tonight and it was a piece of cake, so the fuel door should be way easy!
CosmoTheCat is offline   Reply With Quote
Old 01-05-2001, 04:00 AM   #5
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
Arrow
Brian has instructions on routing the cable and I have pics on how to put in the spring for the door. I've sent the info to be put on the AZScooby but it isn't up yet. I'm about to send you the info I have.
Peaty
Peaty is offline   Reply With Quote
Old 01-05-2001, 04:05 AM   #6
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
Arrow
OK well I was going to send it until I just discovered you don't have your e-mail in your profile. e-mail me direct for the pics of the spring install, but here is the text of the message I was going to send:
Yet another mod that Brian pioneered, I liberated and added my twist to. The pictures that follow are only how to add the spring to the tabbed door flap and of the pull handles. If you want to see how to run the cable, hop to this page:
http://members.nbci.com/_XMCM/northu...za/gas/gas.htm
Brian did a good job of documenting that part. The only thing I would add is this. I didn't remove the filler neck to remove locking pin. If after you remove right inside trunk liner, you can reach up to the locking pin (the white pin mechanism that holds the door shut) from the inside, grab the pin and give a twist, pull and remove it. Then you can put the pin in that has the cable release. No need to take the filler neck out. Also, when snaking the pull cable I removed the drivers side seat to make it easier to get at everything.
Also a word about the door flap. I'm still trying to get a door that is flat, with no tab. The flat door was standard on the 93-95 Impreza's. Currently the only way I know of getting one is from an auto recycling center. Those doors have the release spring already installed. If you can't find one either, you'll have to add one to the existing door like I did. I used a Dremel w/ a cutting wheel to enlarge the hole in the door tang. Then I used a drill to put a hole in the plastic thing that goes over the tang so the pin could go in there and lock. I put some touch up paint around the cut surfaces. You won't be able to see the cuts but I didn't want any rust to start. To do the work on the door you'll have to remove it. There are 2 phillips screws that hold it on. Before I removed the door I traced around the hinge so I would put it back on in the proper place. It turned out that it wasn't necessary, the screw holes aren't slotted. It only goes back on one way.
I purchased all my door release parts from Lisa at Troncalli Subaru as a kit. She can be contacted here:
[email protected] or you can find the site in our links section.
Peaty
Old 01-05-2001, 10:15 AM   #7
Rez
Member#: 1958
1999 Impreza 2.5 RS
Rally Blue Pearl
Post
Rez-
Hey Peaty, ask Dutch555 for a flat door with no finger tab. $35US and $14US to ship. Add another $30US if you want it painted. Drop him a PM.
-Rez
Rez is offline   Reply With Quote
Old 01-05-2001, 10:08 PM   #8
V6
Member#: 2703
Y2K GC8
Silver forever
Smile
How many flat fuel door does he has?
I'd like to have one too.
^_^
Old 01-06-2001, 06:53 AM   #9
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
Post
I think it will be a lot cheaper to find a junkyard that will sell me one for around 5 or 10 bucks. The one with tab is working fine now so I'm just waiting till I find one. 80 bucks is a lot to pay for just a fuel door I think.
Complete Flat Fuel Door Kit (GC/GM/GF) and suede door panel kit for RS coupe Turbo_Twinky NWIC Private Classifieds 20 05-05-2010 02:21 AM
Anyone have install instructions Vishnu Fuel Rails cpu77 Normally Aspirated with bolt-on Forced Induction Powertrain 20 11-28-2002 11:34 PM
Who has succesfully completed the remote fuel door release? 98RS General Forum Archive 6 01-08-2001 09:40 AM
Anyone have installed the RAZO pedal on an automatic? V6 Interior & Exterior Modification 2 11-18-2000 01:42 PM
Remote fuel door install questions!! help!! BrianR Interior & Exterior Modification 3 11-18-2000 10:47 AM
