Welcome to the North American Subaru Impreza Owners Club Monday July 16, 2018
Go Back   NASIOC > NASIOC Classifieds > Private 'Wanted' Classifieds
Old 02-06-2006, 01:10 PM   #1
slow99
Member Sales Rating: (6)
Member#: 103122
05 Sti
Default Looking for 2.5 engine
i was wondering if anyone had a complete 2.5 engine with wiring harness and ecu? if anyone knows where to find some or if anyone has one please inform me. Also i was looking for a manual transmission that will bolt to the 2.5.
thanks
slow99 is offline   Reply With Quote
Old 02-07-2006, 12:35 PM   #2
UTCiv
Member Sales Rating: (13)
Member#: 30695
BOOM , Get her to
sew THAT!
I have an engine/transmission/rear-diff from a 98 GT if you are interested in a bit of a project. All has 139k on it.
The trans works well (though I did have a small problem of finding it tough to go into reverse every once in a while). No grinds on the up gears or downshifting at all.
The engine has the infamous head gasket leak. I noticed it overheat once and tried to fix it with everything but the headgasket. It works its way to above normal temps after about 10 mins of driving, so I only have taken it on diagnostic runs around the neighborhood. Still starts and runs perfect, but will need the head gaskets replaced (easy to do outside of the car).
I also have the ECU, Engine Harness, 95% of the ECU harness (there are some power wires that needed to be cut to remove the ECU, they are common to all models), radiator w/ fans, crossmember, exhaust manifold (2), cat section, crossmember, fuel pump and sending unit, lots of extra wiring, and pretty much everything on the engine including cruise actuator and throttle cable. The A/C compressor is bad though.
Let me know if you are interested.
Thanks,
Matt
UTCiv is offline   Reply With Quote
Old 02-07-2006, 06:01 PM   #3
1rarewrx
Member Sales Rating: (2)
Member#: 79820
2004 Wrx/Sti
I have a 2005 STI motor complete Thats a 2.5
Lmk I have 2 in stock
Frank
1rarewrx is offline   Reply With Quote
Old 02-07-2006, 06:34 PM   #4
t3hWIT
Member Sales Rating: (21)
Member#: 58779
95 STi RA (rhd)
98 Tacoma (300k Club)
I have a 2.5 ECU. Engine too, in pieces. Spun a bearing, but the heads are out getting a "competition valve job"
t3hWIT is offline   Reply With Quote
Old 02-07-2006, 10:04 PM   #5
Hyper
Member Sales Rating: (32)
Member#: 15822
1999 WRB GM6
2.34 LR destroker
99RS engine, ECU, spare new MAF
~88k miles, changed oil regularly, stock
$450 + shipping since it's located in Toronto (canada)
Hyper is offline   Reply With Quote
Old 02-09-2006, 01:06 AM   #6
bugite
Member#: 81515
80-3 8 different sub
Default 2.5
2.5still in rolled outback w/84,k ran great+ecu in northern minnesota
bugite is offline   Reply With Quote
Old 02-09-2006, 01:43 AM   #7
richy_21
Member Sales Rating: (201)
Member#: 58670
2005 got muuuuu?
Sold..
richy_21 is offline   Reply With Quote
Old 02-09-2006, 11:55 PM   #8
Boost6924
Member#: 75605
2004 STI
I have EJ257 engine and wiring harness. Ecu no problem. Can supply also
all the rest of the parts needed. PM me if you're interested.
Boost6924 is offline   Reply With Quote
Old 03-04-2006, 08:50 PM   #9
ruskiyab
Member#: 55128
2007 Impreza WRX
pm sent
ruskiyab is offline   Reply With Quote
Old 03-09-2006, 05:39 PM   #10
shaggadelic
Member Sales Rating: (10)
Member#: 102475
Chapter/Region: HIIC
2001 impreza RS-T
white
i got an 02 rs 49598 miles with wiring/ecu and serice manual. it's an AT tho.pulgs were switched to fit the 94L.
shaggadelic is offline   Reply With Quote
For Sale Turbo XS Cat Delete and Cobb Access Port V2 for 2.5 engine mrtrex Engine/Power/Exhaust 24 03-05-2007 12:28 PM
Looking For 2.2t engine NJZ Private 'Wanted' Classifieds 0 10-07-2005 05:48 PM
Map for Link ECU for 2.5 Engine? Maecky Engine Management & Tuning 1 02-11-2005 05:39 PM
looking for 2.5 rs hood for gc8 4 door. gc8sti Private 'Wanted' Classifieds 0 01-24-2004 03:21 AM
looking for 2.5 RS bumber for OBS agxautosports Interior & Exterior Modification 1 11-12-2002 02:33 AM
