05-23-2013, 11:13 PM | #2926 |
Member#: 98210
Vehicle:2016 Forester XT CWP 2002 WRX SRP 2016 Sienna |
unless you are using dino oil its totally pointless
05-24-2013, 12:43 AM | #2927 |
Member#: 284420
SWIC
Vehicle:2011 WRX Sedan SWP |
My 2011 came with the free 2yr 24k maintenance including oil changes, they only give you enough oil changes to equal out to doing one every 7500. If you do them every 3000 then you run out of them in half the time. I wouldn't think dealerships would vary in that department.
05-24-2013, 12:49 AM | #2928 |
Member#: 98210
Dealerships are all over the place with this stuff
05-24-2013, 01:21 AM | #2929 | |
Member#: 300097
05-24-2013, 09:42 AM | #2930 |
Member#: 284420
SWIC
That's cool, I have been doing my oil changes at 3k since I got the car. I personally will look into at least slightly longer intervals if the oil is still doing what it needs to do after 3k. In my mind that 3k oci was accurate for the Dino oil back in the day when synthetic didn't exist but it doesn't seem like it applies to today's synthetics. In the other hand piece of mind is a very important thing, I will be doing a Blackstone test before I do that for my own piece of mind.
05-24-2013, 04:58 PM | #2931 |
Member#: 284420
SWIC
Anyone else have the annoying clutch squeak? Mine sounds like it's coming from the firewall. I tried to spray some white lithium grease but did no good. It only squeaks after I've driven it around for a little bit and its only at the last inch of the clutch pedal being pushed in. Doesn't sound like a throwout bearing or the firewall flexing.
05-24-2013, 05:19 PM | #2932 | |
Member#: 259591
Vehicle:2011 WRX sedan WR Blue |
05-24-2013, 09:28 PM | #2933 |
Member#: 284420
SWIC
I think I'm reverting back to stock tomorrow and taking it in for it. Doesn't seem like it's the firewall but I'd rather take it in while I still have a warranty.
05-24-2013, 09:29 PM | #2934 |
Member#: 284420
SWIC
Is their anyway to get a look at the welds without removing the entire dash?
Edit: nvm actually found your YouTube video (xabre) . I will check that out first, thanks for the info |
05-24-2013, 09:41 PM | #2935 |
Member#: 259591
Ah yeah I was going to make an entire video of the process but I had no idea what I was doing lol. Pretty much just take off the windshield wipers, remove the plastic clips that hold the plastic panel to your car that's right under your windshield wipers, remove the bolts that hold in the windshield wiper motor and you can see all the welds. It should be pretty obvious is your welds are broken but id have someone go in and step on the clutch. A tip is to take your time removing the little plastic piece that hold the larger plastic trim to the left and right side of your car. They are very easy to break... Which is why my right side is being held in by double sided tape (
05-24-2013, 09:56 PM | #2936 | |
Member#: 284420
SWIC
05-24-2013, 10:12 PM | #2937 |
Member#: 284420
SWIC
Here is a pretty good write up- http://www.wrxforums.com/forums/84-d...olt-style.html
Maybe I won't jump the gun and revert back to stock yet. Will be checking on this in the morning first. |
05-25-2013, 01:30 AM | #2938 |
Member#: 259591
You don't have to but it's only 3 bolts so I think you might as well just to be certain since there are some welds in hard to see places.
05-25-2013, 11:03 AM | #2939 |
Member#: 280691
RMIC
Vehicle:2008 2012 WRX Ice Silver Sedan |
Do you guys think that if I get the lid on my cobb sf intake box powder coated it would hold up? I'm also thinking about the top side of my Grimmspeed turbo heat shield but I don't know if it will hold up. I do have a turbo blanket and the underside on the heat shield with DEI gold tape. I was told that powder coated is good for up to 400 F. I think it will be ok. What do you guys think?
05-25-2013, 12:16 PM | #2940 | |
Member#: 284420
SWIC
05-25-2013, 12:19 PM | #2941 |
Member#: 284420
SWIC
Yeah I'm going to take it out and look at it. I am think the rod on the master cylinder is the issue actually. It's just really hard to get a can of lubricant in that area.
05-25-2013, 05:45 PM | #2942 |
Member#: 284420
SWIC
The spot welds are fine, I think it's the master cylinder. Will probably take it in sometime soon.
05-25-2013, 08:27 PM | #2943 |
Member#: 276611
Vehicle:2011 STi 5-Door Plasma Blue Pearl |
Got 4th gear tuned by Nuke at NF today!
05-26-2013, 01:52 AM | #2944 |
Member#: 280691
RMIC
Yeah it will just be to add some bling to the engine bay!! I sure hope the tip side of my heat shield doesn't reach 400 F. Yeah but I'm not sure. I'll have to ask the coater guy and see what he thinks. I tried searching for pics but couldn't find anyone who powder coated the heat shield. Just ceramic coat and VHT paint.
05-26-2013, 01:59 PM | #2945 | |
Member#: 284420
SWIC
05-26-2013, 03:03 PM | #2946 |
Member#: 280691
RMIC
I understand that the turbo gets that hot. But my turbo is wrapped in thePTP blanket and the underside of my Grimmspeed heat shield has the DEI gold tape so I believe the top of the heat shield doesn't get that hot. I mean I can touch it after hard driving. So it might be ok to powder coat. I guess I will see.
05-26-2013, 04:04 PM | #2947 | |
Member#: 284420
SWIC
05-29-2013, 11:43 PM | #2948 |
Member#: 284420
SWIC
Update on the clutch squeak. I found a "mod" friendly Subaru dealership and ended up taking my car in this morning with the dp+tune on it. I told them that the clutch had a squeak in it and they ended up calling me later today and said that the clutch was harder to press than it was supposed to be and that is causing the squeak due to the higher strain on the clutch pedal assembly (not sure the technical term for each little component) so they are replacing the clutch, throwout bearing and flywheel under warranty. The service writer also told me that SOA will replace your clutch no questions asked if they find something wrong with it and you are still under your 3yr/36k but only once during that time and the extended warranty doesn't cover the clutch after the 36k is up. They are even covering my loaner Chevy Cruze for the next day or two for them to finish the work. Hope that info helps someone.
05-30-2013, 12:57 AM | #2949 |
Member#: 98210
Good to hear
05-30-2013, 04:32 AM | #2950 | |
Member#: 300097
Similar Threads | ||||
Differences of 2011 wrx motor and 2011 sti motor | stpkenton | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 3 | 03-06-2012 11:03 AM |
Differences of 2011 wrx motor and 2011 sti motor | stpkenton | Newbies & FAQs | 3 | 05-12-2011 09:27 PM |
2011 Subaru shifter fitment! All TWM Shifters still fit! | TWM Performance | Vendor Announcements | 14 | 02-28-2011 03:27 PM |
iPod 3g DLO Jam Jacket (clear) and Radtech 3g Indigo Podsleev 10gb/15gb | agentmaxwell | Private 'For Sale' Classifieds | 1 | 05-24-2006 07:41 PM |
Attn: Clayton, Ben and all others involved in the 6MT discussion. | sherifx | Mid West Subaru Owners Club Forum -- MWSOC | 1 | 07-31-2002 03:00 AM |
