Welcome to the North American Subaru Impreza Owners Club Sunday September 23, 2018
Old 07-21-2013, 03:44 PM   #1226
ThinkWitUrDipStic
Member#: 299024
2005 WRX Sedan
Originally Posted by johnblahuta88 View Post
Cheap $5 paint thinner from lowes works great for dissolving PD. I use it to fix any tears and for feathering any lines.
This wont affect the stock 2005 wrx rim color?
As i was pressure washing my rims i had to much PSI and completely removed the silver paint from the center cap.
Live and Learn
-Im sure this is somewhere in thread but say I wanted a gloss coat on top of dipped wheels. What would be my best product choice to you more experienced plasti dip users?
ThinkWitUrDipStic is offline   Reply With Quote
Old 07-21-2013, 05:11 PM   #1227
HAL1
Member#: 58926
2013 WRX 5dr ISM
2011 Infiniti EX35
Live and Learn
Um, let me think about this one, how about the Plasti Dip Glossifier? Okay, seriously, everything I've read says that anything else over PD is going to make it a pita to remove
HAL1 is offline   Reply With Quote
Old 07-21-2013, 05:14 PM   #1228
HAL1
Member#: 58926
2013 WRX 5dr ISM
2011 Infiniti EX35
Soo my nightmare with plastidip has come true, i made the mistake of not applying enough coats to have it evenly peel off.
I hit it with a pressure washer and there is a bit that will not come off and is being quiet stubborn
Anyone know of a de greaser and or tar removal that works best for this stuff?
I think bug and tar remover should may work.
Old 07-21-2013, 05:45 PM   #1229
Gecko5
Member#: 355471
2014 WRX Hatch
Originally Posted by Sgt.Peppers View Post
My custom teal wrx
Really nice looking
Gecko5 is offline   Reply With Quote
Old 07-21-2013, 06:39 PM   #1230
mm41108
Member#: 356237
Tried my car in white after blaze yellow for a few weeks
mm41108 is offline   Reply With Quote
Old 07-21-2013, 07:06 PM   #1231
Trustkevin13
Member#: 259184
2008 Subaru WRX
^^^ you must be from Australia.....
Trustkevin13 is offline   Reply With Quote
Old 07-21-2013, 07:11 PM   #1232
mm41108
Member#: 356237
Trust. It uploaded that way from tiny URL , then I did find it amusing so I left it for you.
Old 07-21-2013, 07:22 PM   #1233
HAL1
Member#: 58926
2013 WRX 5dr ISM
2011 Infiniti EX35
Uh Oh, I turned my laptop upside down to see it and half my data fell out.
Old 07-22-2013, 11:25 PM   #1234
johnblahuta88
Member#: 221614
Dude your car can fly. I want that PD mod.
johnblahuta88 is offline   Reply With Quote
Old 07-22-2013, 11:30 PM   #1235
johnblahuta88
Member#: 221614
I sprayed my taillights with 8 layes of PD SMOKE and it was just a tacky feeling so I put a few layers of clear coat on it. It turned out great and the overspray on the edges was super easy to get off. Just don't put thick coats on th PD and you will be fine.
And About the PD on brakes. I have been testing out its heat capacity. I painted my exahust tip black and PD white just to see if it would stay up to the heat. After a couple days it is still white and the black isn't faded . It looks like a skunk exhaust.
Old 07-22-2013, 11:47 PM   #1236
corvid
Member#: 300097
Ive had my exhaust dipped for a year, the exhaust is irrelevant to how it will react to brake temps.
corvid is offline   Reply With Quote
Old 07-23-2013, 12:07 AM   #1237
johnblahuta88
Member#: 221614
Ok. why is that. I would suspect the calipers to not get as hot as the exhaust. especially with air flowing past the brakes plus the calipers shouldn't get as hot as the rotors.
Old 07-23-2013, 12:23 AM   #1238
mcmikecruz
Member#: 162177
Brakes get way hotter than cat backs
mcmikecruz is offline   Reply With Quote
Old 07-23-2013, 12:53 AM   #1239
corvid
Member#: 300097
This, they can get several times hotter than your exhaust tips very quickly. All it would take is at most a few hard/high speed stops and you'll be way past the upper threshold of plastidip.
Old 07-23-2013, 06:50 AM   #1240
cheeseyfella
Member#: 286941
you can't use plasti dip on calipers, the temp of the brakes, and the duration of the heat will melt the dip. There are a few threads on the DYC forum about this, and every time it is a fail. exhaust tips get no where near the temps of brakes.
cheeseyfella is offline   Reply With Quote
Old 07-23-2013, 08:57 AM   #1241
johnblahuta88
Member#: 221614
ok thanks guys. Im debating painting my exhaust tip black. If I do my car will be a true panda.
Old 07-23-2013, 09:29 AM   #1242
flippymcbean
Member#: 198546
2003 Evolution VIII
Lightning Yellow
If your going to paint exhaust black just buy a can of high temp paint. And if you want to the original finish back sand it or buy aircraft remover paint.
flippymcbean is offline   Reply With Quote
Old 07-23-2013, 10:58 AM   #1243
johnblahuta88
Member#: 221614
I just want to paint the tip black. maybe the canister white lol
Old 07-23-2013, 11:12 AM   #1244
johnblahuta88
Member#: 221614
Either way white or yellow your car looks clean.
Old 07-23-2013, 04:21 PM   #1245
Soobiecabra
Member#: 259527
2016 STi
Pure Red
Originally Posted by flippymcbean View Post
...if you want to the original finish back sand it or buy aircraft remover paint.
Or use dip and peel it off.
Soobiecabra is offline   Reply With Quote
Old 07-24-2013, 04:04 AM   #1246
God
Member#: 148482
2085 CRYSMORE
LE BARON
It's an 05 2.5rs, originally crystal grey metallic. I used the gunmetal plastidip and a pearlizer. I used the gun they sell at dipyourcar.com and am overall pleased with the results. It seems to be holding up well so far, although it's only been on there for a week.
This one has a bit more light, so you can see the effect of the pearlizer a little better.
God is offline   Reply With Quote
Old 07-24-2013, 08:02 PM   #1247
05subysti
Member#: 268190
2005 STi
Looks good GOD lol
One things that peeves me is the badges on the trunk..
Should've debadged it.
What wheels are those, they look like newer maxima wheels.
Car needs better stance like ASAP
05subysti is offline   Reply With Quote
Old 07-24-2013, 09:08 PM   #1248
loudnlow
Member#: 44723
'13 WRX Sedan
'17 Fozzy
As you can imagine the amount a brake dust that accumulates on these wheels.. has anyone had any luck getting brake dust off of PD? I tried a wet cloth, but the brake dust seems to just dig itself deeper.
Thanks
loudnlow is offline   Reply With Quote
Old 07-24-2013, 09:30 PM   #1249
jimbosv650
Member#: 261307
04 wrx wagon
Spray it with simple green as soon as you start to see brake dust.
jimbosv650 is offline   Reply With Quote
Old 07-24-2013, 09:41 PM   #1250
cheeseyfella
Member#: 286941
I use mothers chrome wheel cleaner and a wheel brush. Or brake dust pro and a brush if they are really dirty
