Welcome to the North American Subaru Impreza Owners Club Monday October 14, 2019
Old 10-09-2007, 07:03 PM   #201
Chris05STi
Member#: 88248
2005 Subaru STi
Sweet project....awesome to see how it turns out, good luck!
Chris05STi is offline   Reply With Quote
Old 10-13-2007, 01:59 PM   #202
Kanchou
Member#: 46936
2004 WRX
its... its beautiful... *sniff*
Kanchou is offline   Reply With Quote
Old 10-13-2007, 02:09 PM   #203
thejaredhuang
Member#: 86206
2006 WRX Wagon
Start that beast. I don't remember if you said it or not, but is the exhaust on? I'd take it off for the startup unless it was a pain.
thejaredhuang is offline   Reply With Quote
Old 10-13-2007, 07:56 PM   #204
Kostamojen
Member#: 2272
1999 OBS Camo Wagon
The exhaust is on there, but i'd be even more of a pain in the ass to remove it right now while trying to start it...
But yes, today I did try starting it! I want to know if the motor is good enough to keep or if I should go with something else (before I start dismantling the car)
Well it does crank, the starter is going fine, and the fuel pump is going fine, but its not getting spark I replaced the plugs, wires, distributor cap and rotor, so its not those... Could be the ignition coil or something else, not sure yet.
Old 10-13-2007, 09:16 PM   #205
Kostamojen
Member#: 2272
1999 OBS Camo Wagon
HUZAH!
It started!
One of the USMB folks suggested I check out the distributor points... I took a look at the points, notice it was just 2 screws and one wire... But that wire was frayed and not connected right. I replaced the points with the new ones I had purchased and reconnected that wire properly and it started right up!!!
Right now, its actually running BETTER than my '78 Wagon was! Its not backfiring, not making smoke (other than the burnoff from the hole in the muffler), not hesitating much (a little with slight throttle input, but revs VERY well!)
So, I guess I wont need a motor right away!
Old 10-13-2007, 09:39 PM   #206
xxxbelial29xxx
Member#: 67105
04 WRX rare WRB
Default XtotheZ
Time to call P.M.R.!!!
xxxbelial29xxx is offline   Reply With Quote
Old 10-13-2007, 10:01 PM   #207
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
That's awesome news!! ......a short video would be nice.
This has to be a good morale booster for ya.
Old 10-13-2007, 11:14 PM   #208
Kostamojen
Member#: 2272
1999 OBS Camo Wagon
Oh, and sorry about the lack of video of it starting up, I planned on making one but video camera has been having trouble this year... The lens seems to go in and out of showing an image, but now its 100% gone
I'll see what I can do about fixing it or borrowing someone elses camera...
Old 10-13-2007, 11:42 PM   #209
omega force
Member#: 131851
05 wrx
Gamblerz fo lyf Bboy Suby
swap the motor wit built internals wit gt35r!
omega force is offline   Reply With Quote
Old 10-14-2007, 12:26 AM   #210
NZ Kingpin
Member#: 161725
1997 Gravel Express
Green/sliver
looks liek your got your work cut out for ya mate...good luck
NZ Kingpin is offline   Reply With Quote
Old 10-14-2007, 07:58 PM   #211
Kostamojen
Member#: 2272
1999 OBS Camo Wagon
Day 7 (well its not really days at this point, but Ill stick with it)
I drove it!!!
I drove down the driveway into the court and around and back up. Parked on the street a second so I could clean the driveway under the car of all the dirt that came off of it, then put it back up.
I realized at first, there were no brakes! I checked the fluid and it was empty, so I filled it up and pumped the brakes a few times and much better *whew*
The shifter is really loose, needs some work for sure. Could probably use a new clutch. The rear tires hit the fenders of course on bumps (but I was driving carefully at this point anyhow). Steering is tough at low speeds same as the Wagon... Otherwise drove ok, but its not like I went more than 5mph anyhow...
I also took the liberty of removing the bumpers and rear tail lights/reflectors/etc. and covering up some of the holes that were exposed that shouldnt be to keep the rust from getting worse at those spots.
I have to say, without the bumpers on it looks more 510-esque in the rear than I expected.
Anyhow, couple pics from today... Once again, sorry about the lack of video, but the video camera lense is 100% gone now:
Old 10-14-2007, 08:14 PM   #212
Imprezard
Member#: 3016
CBA GH8
WR Blue
Good work!
I am really looking forward to see how it'll turn out.
Found some pics for reference.
Imprezard is offline   Reply With Quote
Old 10-14-2007, 09:13 PM   #213
sixtoo
Member#: 67603
2017 Forester
The project is looking good; wish you were SoCal so I could take a look in person. Here's an interior from a Triumph:
Just to give you some ideas for when you tackle the interior. Also, you should definitely look into getting a Nardi wheel; they're gorgeous. Keep up the good work!
sixtoo is offline   Reply With Quote
Old 10-14-2007, 09:35 PM   #214
Kostamojen
Member#: 2272
1999 OBS Camo Wagon
Originally Posted by Imprezard View Post
Good work!
Wow, where did you find those pics?
I scoured the internet for hours looking for FF-1 pics... I got a few dozen, but nothing that detailed!
Old 10-14-2007, 09:37 PM   #215
Kostamojen
Member#: 2272
1999 OBS Camo Wagon
Alright, time for my first official Design Photochop
I went through, cleaned up some things, plus tried out some different paint colors in spots to see how it looks... I plan on going with black accents in terms of paint color, with the Satin white, but of course none of that is set in stone right now.
Let me know what you think...
Here is the photo it was based on for reference...
Old 10-14-2007, 11:36 PM   #216
thejaredhuang
Member#: 86206
2006 WRX Wagon
Looks great in that color scheme. It has the feeling of classic 70s/80s econoboxes; it reminds me of an older VW. Simple and nothing flashy, I like it alot.
Can you replace the distributor with one that doesn't have points or would you have to go with electronic ignition if you did that too?
Old 10-15-2007, 01:02 AM   #217
rice h8r
Member#: 94524
driving your car without checking all your fluids FTL!!!
it lives... FTW!!!
so what exactly did you have to do to get this thing running [everything]?
rice h8r is offline   Reply With Quote
Old 10-15-2007, 01:45 AM   #218
Kostamojen
Member#: 2272
1999 OBS Camo Wagon
Supposedly theres an electronic distributor from the mid-80's EA81 FWD cars that is actually an upgrade for motors like this... I will probably go that route.
Actually not that much...
I flushed the coolant (used Subaru coolant with the additive), replaced the oil and oil filter of course, replaced the spark plugs, spark plug wires, distributor cap and rotor and points, and plugged in the battery from my car, and added a gallon or so of gas...
Honestly, it probably would have started if I just fixed the distributor points, but I played it safe, and all those parts cost like $60 total so its not like its expensive
(actually, the cost of parts for EA motors is so damn cheap I'm surprised more people dont do this for kicks... You can buy an EA scoob, upgrade the engine, fix it all up so that it runs fine, all for well under what it would cast to buy a new turbo back for a wrx/sti )
Old 10-15-2007, 01:57 AM   #219
thejaredhuang
Member#: 86206
2006 WRX Wagon
Nice, no 10k tuneups.
I just noticed the front grill badge has a red background, like a red Honda badge .
Are you going to keep those wheels?
Old 10-15-2007, 02:00 AM   #220
Kostamojen
Member#: 2272
1999 OBS Camo Wagon
For the forseable future unless something pops up, yes.
There are only two kinds of cars with wheels with the 4x140 bolt pattern... 70's and 80's Subarus, and some models of Peugeot's. These are 15" Pug wheels, kind of hard to come by... And Subaru doesnt have any 15" wheels with this bolt pattern.
Old 10-15-2007, 02:28 AM   #221
thejaredhuang
Member#: 86206
2006 WRX Wagon
Oh wow, 4x140.
What can we expect from Day 8?
Old 10-15-2007, 02:32 AM   #222
remowgn
Member#: 41149
09 FXT
SSM
I don't know if it was mentioned here yet, but you could get some mean lookin' steelies from diamond racing for a reasonable price. They do custom steel wheels in whatever configuration you're looking for, including bolt circles. They don't have 4x140 (or 4x5.5") but they say they can accomodate most requests.
http://www.diamondracingwheels.com/WheelSeries.htm
(edit) How bout these? http://boston.craigslist.org/sob/pts/446232031.html
Or these: http://cgi.ebay.com/ebaymotors/White...spagenameZWD1V
Looks like weld makes some 4x5.5" wheels.
remowgn is offline   Reply With Quote
Old 10-15-2007, 02:43 AM   #223
Imprezard
Member#: 3016
CBA GH8
WR Blue
I usually do my search on Subie stuff in Japanese. Even with that I didn't find too many good FF-1 pics. I got a magazine with some pics of an awsome FF-1 rally car. I'll put it up when I can get it scanned.
Old 10-15-2007, 06:42 AM   #224
Rapid_Roo
Member#: 31511
03 GD2 95 GM4
www.ITNRally.org
Eventually, the goal is to get it to look somewhat like this:
Kudos to you sir, and good luck with your project.
Rapid_Roo is offline   Reply With Quote
Old 10-15-2007, 07:18 AM   #225
dbcooper
Member#: 161702
2007 WRX Wagon
Well you certainly have some "before" pictures.....
dbcooper is offline   Reply With Quote
Help decide the 1970 FF-1 Project Car color scheme: Round Three, FINAL ROUND!!! Kostamojen Member's Car Gallery 41 09-10-2010 10:13 PM
Help Choose the 1970 FF-1 Project Car color scheme: ROUND TWO!!! (Poll inside) Kostamojen Member's Car Gallery 33 11-13-2008 06:48 PM
FYI, the 1970 FF-1 Project car is here on NASIOC too... Kostamojen 'Old School' Subaru Forum 0 10-26-2008 01:22 PM
OT: Help decide the color of the 1970 FF-1 Project Car! (Link to Poll inside) Kostamojen Off-Topic 68 08-29-2008 11:32 PM
The rarest Subaru in North America Gambit General Forum Archive 36 06-19-2000 08:58 PM
