Welcome to the North American Subaru Impreza Owners Club Wednesday October 16, 2019
Old 12-19-2018, 04:00 AM   #1
sammywrx267
Member#: 495376
Default Widebody Sealants- HELP
Hey, I've got a project widebody going on, I've had the rears re sealed twice now and it has cracked both times. I'm after some advice on what people have used to seal, Must be able to be painted on and must be able to handle the weather! Thanks
sammywrx267 is offline   Reply With Quote
Old 12-19-2018, 10:05 AM   #2
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
I don't know.....but......glass, CF or metal kit?
How are parts attached?
Are parts painted, and if so, what kind of paint?
Does the sealer also act as a filler between parts?
Old 12-19-2018, 04:42 PM   #3
GK1707
Member#: 373868
2004 STi
GK1707 is offline   Reply With Quote
Old 12-20-2018, 03:17 AM   #4
sammywrx267
Member#: 495376
Sorry, Fiberglass. And yes it would also act as a filler. I'm unsure of what paint, It wasn't me who painted it- Was a panel shop
Old 12-20-2018, 03:17 AM   #5
sammywrx267
Member#: 495376
Originally Posted by GK1707 View Post
No I haven't, I'll do some research on it. Thanks alot
Old 01-09-2019, 02:55 PM   #6
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
I have fiberglass widened rear quarters grafted to the factory steel quarters on my Fox Mustang. The guy who did the work used one of the Marine-Tex products; I can't tell you which one specifically. That was way back in 2007 and the panels are still in place with no cracking or issues that I can see.
In the years since the work was done I have seen Marine-Tex mentioned in discussions of bonding fiberglass and metal. I'm sure if you search around you can find info about which type is best to use.
Old 10-01-2019, 09:49 PM   #7
T Biggins
Member#: 378156
2008 WRX
16K Dark Grey Met
This is what I would use after properly prepping both surfaces.
https://www.amazon.com/3M-Adhesive-M...26468864&psc=1
T Biggins is offline   Reply With Quote
Old 10-01-2019, 09:53 PM   #8
T Biggins
Member#: 378156
2008 WRX
16K Dark Grey Met
I donít think that product would be strong enough. That product is just for sealing folded seams on metal parts so moisture doesnít creep under. (Door skins) It doesnít have any bonding strength. OP needs a quality panel bond adhesive.
Old 10-02-2019, 03:56 PM   #9
pistolpete44
Member#: 222125
2003 2003 wrx
black
What youíre wanting to use is 3M 8115 panel bond. You will have to sand down your cars body to bare metal for the sealant to where properly. Used it on my widebody and worked great. Itís also Sandable once dry.
pistolpete44 is offline   Reply With Quote
Old 10-02-2019, 05:10 PM   #10
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
Harbor Freight mig welder should do it.
Old 10-02-2019, 09:11 PM   #11
pistolpete44
Member#: 222125
2003 2003 wrx
black
fiberglass installed widebody with panel bond 8115
