Welcome to the North American Subaru Impreza Owners Club Monday October 21, 2019
Old 07-13-2019, 03:16 PM   #1
archer1.8
Member#: 148335
2018 STi Type RA#454
Default Remote Oil Pressure/Oil Sensor Firewall Mount Questions
So I plan to install a remote oil line from the rear galley plug and mount a billet distribution block somewhere on the firewall that will have both the Oil Temp and Psi sensors. Here is the block I plan to use
Now I know there is ALOT of different theories of where oil temp should be measured and I get that. My question tho, if I have a "16" stainless braided line going to this distribution block with both sensors will the temp readings be way off because its not the probe directly in the flow path of the engine oil say if it were directly in the oil galley plug. Or am I over thinking this.
archer1.8 is offline   Reply With Quote
Old 07-13-2019, 08:09 PM   #2
motorbykemike
Member#: 273868
oil temp readings will be in another universe off
drill/tap oil drain bolt and install it there if you want the best spot
motorbykemike is offline   Reply With Quote
Old 07-13-2019, 09:50 PM   #3
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Yeah you don't want to do that. oil temps will not even be close. You can use one of our adapters in the pan drain port and pull pressure from the gallery port under the alternator; we have adapters for that port as well.
Old 07-13-2019, 09:53 PM   #4
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
Temps will be way off as stated, pressure will read correctly...but I'd question the integrity of the hose ends over time. The constant movement of the engine will put a lot of stress on the line and ends. Tough choice between line integrity and mounting sensitive sensors directly to the buzzing metal engine, lol.
2slofouru is offline   Reply With Quote
Old 07-14-2019, 05:58 AM   #5
archer1.8
Member#: 148335
Ok thanks for the advice. How about the sandwich adapter plate. Not ready to go drilling holes in my oil pan or upgrading to a killer B oil pan
Old 07-14-2019, 01:09 PM   #6
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
I think you misunderstood what I said. We have adapters that screw right into the OEM pan drain plug.
Not a fan of sandwich adapters unless you have to (remote oil cooler, relocated oil filter, etc...) due to the higher probability of having issues.
Old 07-14-2019, 04:33 PM   #7
archer1.8
Member#: 148335
Not at all. I dont think the threaded sensor into the oil pan is how I want to go. And I agree 100% with the sandwich plate. I guess I will have to use the rear galley plug location.
Old 07-14-2019, 05:10 PM   #8
Hyper
Member#: 15822
1999 WRB GM6
2.34 LR destroker
I am running one of those KillerB pan drain plug for the temp sensor, works great!
Hyper is offline   Reply With Quote
Old 07-15-2019, 02:02 PM   #9
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
For temp? You can do that, but keep in mind for comparative data, it will be different. Why don't you want to sense oil temp from the pan like most others do?
Old 07-15-2019, 04:06 PM   #10
car_freak85
Member#: 13530
EA63 , EA81T, EJ20G,
EJ205
This location places the temp sensor directly in the largest volume of oil in the engine. This is THE PLACE to pull oil temp from.
If you measure on the rear of the block, you will never be able to directly compare your oil temps to that of other Subaru owners. Practically EVERYONE pulls temp from the pan.
car_freak85 is offline   Reply With Quote
Old 07-15-2019, 09:33 PM   #11
motorbykemike
Member#: 273868
only the ones that care to know the difference
op asked
doesn't want to hear it
kb even has a swipe the card and bolt it on option because he cares to know
betcha he asked and edjumicated himself about it this one time at car camp
Old 07-16-2019, 09:07 PM   #12
archer1.8
Member#: 148335
I was just looking to hear all possible options for a temp sensor. Yes the pan is the correct and best place for sure. Just seeing what others did
Old 07-17-2019, 03:10 PM   #13
car_freak85
Member#: 13530
EJ205
Sometimes it's not worth the effort to think outside the box... The sun will rise and it will set and oil temperature shall be taken from the oil pan.
