Welcome to the North American Subaru Impreza Owners Club Wednesday October 16, 2019
Old 09-25-2016, 07:06 PM   #126
jonpers172
Member#: 393893
2002 impreza WRX
black
Dude, save yourself time and do an upgrade while your at it. Avcs really smooths out the power band, just leave all the components intact. Swap your intake manifold, do a tgv delete (using the jdm "spacer") while your there, swap in the usdm exhaust manifold and oil cooler, then swap in the usdm power steering, alternator and a/c compressor. Lastly the ever confusing timing components gets whacky. since you'll need the jdm ecu to run avcs you more than likely should leave the jdm timing components. Lastly you can do the AVCS wiring yourself and save money. If you text me I can send you wiring diagrams.
If you intend to do racing or power upgrades defiantly look at the ej207 (I hope I'm not insulting your intelligence) I wouldn't even mess with tearing into a perfectly good block. I would definitely install it before the warranty period is up though, my first jdm had a spun bearing.
Your welcome to text me, I recently finished up my swap. 8479753480
jonpers172 is offline   Reply With Quote
Old 09-25-2016, 07:13 PM   #127
jonpers172
Member#: 393893
2002 impreza WRX
black
Originally Posted by Ksnow95 View Post
I just have the stock to Usdm wrx ecu right now, my fuel is fresh just put some in during the this whole process, messed with the timing but seems right, I'm running the Usdm intake manifold and it does turn over with my foot on the gas. And I am not sure if it's a drive by wire or not how do I figure that out? Thanks kurt
Any updates?
I was just thinking your coil packs could be backwards or not connected?
Old 09-26-2016, 02:05 PM   #128
subierex929
Member#: 328122
2011 STI
2003 WRX. Looking to swap a complete jdm ej205 into the car. Both jdm dealers I spoke with advised me that my car does not have avcs setup. I can get the jdm ej205 non avcs for $1,000.00. Gonna use it with the usdm ecu and either the cobb accessport,which i already have, or get a dyno tune. I've noticed the non avcs jdm motors have red spark plug wires to where my current motor has coil packs. Not really worried about avcs since i will be getting a tune either way. Want to get my hands on a motor this week so i am trying to get everything figured out before making the purchase. I've searched everywhere and get mixed reviews. Any help would be greatly appreciated!! Thanks
Do i need to swap over coil packs with all the wires to the non avcs ej205?
Do i swap over all of the externals from my usdm motor onto the jdm ej205 non avcs when using the usdm ecu?
Would it be easier to just purchase one with avcs since the externals are similar to the current motor and just leave it unplugged instead of getting the non avcs?
Would the stage 2 cobb accessport map work with the swap or would the dyno tune be best?
Anyone running either engines with or without avcs and using the usdm ecu? If so, what kind of tune are you running? Cobb or dyno?
subierex929 is offline   Reply With Quote
Old 09-26-2016, 03:41 PM   #129
jonpers172
Member#: 393893
2002 impreza WRX
black
Please refer to my last comment.
Old 10-11-2016, 10:19 PM   #130
2000forester
Member#: 456264
Default Jen swap
Originally Posted by JoshP View Post
Swap the cam and crank gears, and intake manifold with all electronics on it and that's it. Your ecu can run AVCS with different roms but you would have to do some wiring. There's your good write up.
Not really there is a lot more needed? My 2004 forester XT doesn't have a drivers side cam gear sensor?? Just a plug where it should be but the JDM does so not plug and play!
2000forester is offline   Reply With Quote
Old 10-18-2016, 08:04 PM   #131
Scoobs17
Member#: 325965
2017 WRX
Crystal White Pearl
If my 02 Bugeye is currently wired for an EJ207 V7 with JDM ECU and AVCS wiring kit, can I essentially plug and play a JDM EJ205? Would it be worth going JDM over USDM when it comes to the 205? Thanks!
Scoobs17 is offline   Reply With Quote
Old 10-28-2016, 03:56 PM   #132
whycantidrive
Member#: 255758
06 Wrx
Obp
Default What ecu
I have an 03 wrx 5spd. What ECU can i use to run the jdm ej205 with avcs in my car? Like does it have to be from a wrx and does it have to be a 5spd ecu.
whycantidrive is offline   Reply With Quote
Old 10-29-2016, 01:03 PM   #133
encryptedballa
Member#: 122189
02 WRX Wagon
ej207 and jdm ej205 should be the same avcs harness.
AVCS is a great upgrade and def worth it over a usdm ej205.
encryptedballa is offline   Reply With Quote
Old 11-17-2016, 03:34 PM   #134
thomkase
Member#: 439920
Default Looking for Insight
I have an JDM EJ205 with AVCS swapped into a 2004 Impreza WRX wagon. It runs, but not how it should. It was running super rich before I swapped over an uppipe sensor that I had left off, and now it seems the fuel level is normal, but it still doesn't run how it should.
I have checked the crank & cam pulleys for differences and, as far as I can tell, they are exactly the same number of teeth and the same diameter. I have swapped over the USDM intake manifold. I have also been working with a etuner, and that hasn't seemed to solve the problems fully.
I have read on the forums here that you don't have to make the AVCS functional to get good power out of the motor, and I am alright not having it, mainly because my budget doesn't work for the wiring harness or JDM ecu.
I am hoping to bounce off ideas and get some more info about what I can do to get it running right.
thomkase is offline   Reply With Quote
Old 12-06-2016, 09:01 AM   #135
JDM Racing Motors
Member#: 458534
Here's some ideas:
-Have you checked timing - Rotate engine clockwise till the engine is at TDC (See pic below)
-You should have no problems not running avcs if you're using the USDM intake manifold and ecu, although a clogged oil control valve, located on the top of the valve cover, could cause issues.
-Give us some more info on how its running: Is the engine having trouble idling? Does the engine run well at higher rpms or continue to run badly? Is it misfiring? Are there any CEL codes?
Hope this helps.
JDM Racing Motors is offline   Reply With Quote
Old 12-06-2016, 10:02 AM   #136
JdmRacingMotors
Member#: 193311
Here's some ideas:
Hope this helps.
JDM Racing Motors Inc
www.jdmracingmotors.com
JdmRacingMotors is offline   Reply With Quote
Old 12-06-2016, 04:26 PM   #137
thomkase
Member#: 439920
Yes I have checked the timing, me and a friend slipped the timing belt trying to remove the crankpully with a breaker bar, switched to and impact and then had to reset the timing. Pretty sure I got everything in the right place (matches the sweet diagram you posted).
And Like I said I've read over and over on here I can run the engine with out AVCS. Just to confirm Yes USDM intake and ecu with no other mods.
How can I check to see if the oil control valve is clogged or not?
I pulled the battery cable to reset the CEL to see what comes up after I added the sensor back to the system. Plan to drive and check them again tonight. I haven't had any feedback so its been awhile since I worked on it. It runs worst when starting to drive, improves as you are at mid rpms, and falls off again at higher.
CEL codes have been pretty consistent:
P0302 Misfire Cylinder 2
P0000 PASS CODE (NO DTC DETECTED)
P1491 PCV (BLOWBY) FUNCTION PROBLEM
I will run codes tonight when I pull it out. I have log capabilities would that be useful to post?
Old 12-06-2016, 08:11 PM   #138
thomkase
Member#: 439920
Alright so it gives me a blinking CEL when I push over 2500rpm its off when I am at idle and coasting around 2000rpm
Here are the codes it kicks out:
It Idles fine and sounds normal, but go to drive and it is sluggish starting out, runs pretty normal above 2000rpm, but accelerates terrible all around.
I'm happy to provide any more info or answer any questions, I ran some logs on the drive around tonight if anyone wants to take a look, no 3rd gear pulls though as I have several new inches of snow with more coming down.
Advice and recommendations would be appreciated greatly!
Old 10-08-2017, 01:34 PM   #139
KeifersWRX
Member#: 475150
Default In the middle of a swap, but...
Originally Posted by Offroadguy View Post
I just put a JDM ej205 NON-AVCS into my 2002 WRX. It runs great, but needs a tune. The crank and cam gears have to be USDM to use US ecu, as the signals are different. My JDM engine has 9:1 compression instead of 8:1 this is the main reason for the tune. 91 octane will detonate if overboosted into this engine. The shop that will be tuning my car ran the code on the timing cover of the JDM engine and verified the 9:1 compression and told me what year and car it came out of. I kept the JDM turbo and pretty much changed everything else outside the longblock. I cleaned and reused the coolant/oil cooler, contamination is not an issue because the oil is filtered AFTER the cooler. Exhaust and intake manifolds are different. If anyone has questions, let me know.
Did your turbo oil return come out the side or go straight up from the head? I can't install my stock exhaust becau se the JDM oil return comes off the side of the head and is in the way.
KeifersWRX is offline   Reply With Quote
Old 01-11-2018, 06:49 PM   #140
Timmaytoyota
Member#: 470158
Iíve been trying to figure out why people say th jdm ECU wont pass emissions. My 03 I bought already has a jdm ej205 swapped in with avcs. Currently using the usdm ecu. I pulled the timing covers off to check the cam gears. Iím pretty sure they are the jdm gears. Iím wanting to get the avcs working. But I donít want to have to swap the ECU for inspections. Is it possible to use a usdm sti ECU to control the avcs? That way I wonít have to swap the ECU for emissions testing
Timmaytoyota is offline   Reply With Quote
Old 02-25-2018, 03:20 PM   #141
02SWG
Member#: 482578
Any insight on swapping in a ej205 non avcs into a 02 wax wagon?. I've been researching for hours and found pretty much everything except how to deal with the different ignition system. Do I need to remove the ignition system from my USDM Engine?
02SWG is offline   Reply With Quote
Old 05-04-2018, 04:03 AM   #142
liuyiwei
Member#: 485542
1998 gc8
blue
nice is a good
idea
liuyiwei is offline   Reply With Quote
Old 08-01-2018, 09:17 PM   #143
Scoobydoobydude
Member#: 468311
2003 WRX wagon
World Rally Blue!
I just finished a v7 jdm ej205 swap into my 03 wrx. Cranks but will not start. It doesn't sound like it has spark. We also had the fuel lines messed up and hopefully now that's right, feed line to middle nipple?
There is some concern that it is a bad ground. Any ideas where we should start?
It was supposed to be plug and play and everything seems to be plugged in. USDM ECU AVCS not wired yet, just want to get it running. I do have the jdm ecu to swap in if necessary but I was assured it would start with the USDM one.
Please help. I'm spent. been at it for two days straight and go to turn her over and she won't catch!!?!?!
Ask me anything about what we have done and I will do my best to answer.
Scoobydoobydude is offline   Reply With Quote
Old 08-22-2018, 08:08 PM   #144
Cdhrnbstl7
Member#: 484595
Did you replace all the major sensors, crank, knock, cam position sensors, from the previous engine? All the sensors need to be usdm. And if you were originally a drive by cable and now using a drive by wire the usdm ecu wonít read the throttle body and wonít tell it to engage the butterfly. My use old intake manifold... you can leave the tgvs... you get more power with the jdm tgvs
Cdhrnbstl7 is offline   Reply With Quote
Old 08-22-2018, 08:20 PM   #145
Cdhrnbstl7
Member#: 484595
Wanna send me a video of what it sounds like starting up as well [email protected] both with no throttle and with full throttle while trying to start
Old 04-11-2019, 09:01 AM   #146
knightangle
Member#: 492769
2003 WRX Wagon
Sonic Yellow
Originally Posted by D-Rodman View Post
Yeh, you went to a v5 engine on an 02 wrx, completely different electronics platform. No wonder you can't make it work.
Op, a Jdm ej205 with avcs will run with your usdm ecu but you will not have functional avcs. You will need the correct Jdm ecu and additional wiring to make the avcs functional.
I Jdm swapped my 03 wrx with an ej205 that has avcs, i got the wiring harness to run avcs and the correct jdm ecu, all but the harness was from Jspec in VA. I am having issues with how the car runs when boost builds up. it sputters quite a bit. I have been told that i need to get it calibrated, just brought to shop to get it to run properly. in the time being, since im at school would i be better off running the Usdm ecu?
knightangle is offline   Reply With Quote
Old 04-13-2019, 04:15 PM   #147
oscar_90601
Member#: 500330
Default Engine cranks but wonít start.
Hey guys, Iím new to the forum and Iím looking for help.
I have an 03 wrx that has had two JDM ej20 swapped in within one month. Here is a quick backstory.
I bought the car with a blown engine, took it to a shop to swap a used JDM engine. First engine turned on no problem, the shop took it for a spin the verify everything was fine. Came back and the car was throwing a CEL for a missfire, shop said it was due to a boost line not being plugged in. They plugged the line in and took it for another spin. Car randomly turned off on them, they said it was because the car ran out of gas. Gas was put into the car and now it wonít start. The shop said maybe the engine skipped timing so just to be sure they will swap in another engine. Second engine is in and still the car wonít start. It cranks but does not start. Iíve replaced the timing belt and all sensors and still nothing. The car has been parked for almost two months and I donít know what else to do, I need help.
oscar_90601 is offline   Reply With Quote
Old 06-05-2019, 02:42 AM   #148
Mlaguna96
Member#: 502885
Default Non avcs
So if Iím reading everything correctly to use a non avc jdm EJ205, in a 2003 usdm wrx I donít have to do anything but change the cam and crank sprockets ? And also sensors ? Iíve seen mixed opinions about that. Why does the usdm intake also have to be swapped over in some cases ? Thanks
Mlaguna96 is offline   Reply With Quote
Old 07-18-2019, 12:00 PM   #149
DE DADDY
Member#: 504382
Default Ej2.0 into a usdm 2005 forester xt
Originally Posted by elijah.botez View Post
Hi everyone! I have put a good amount of time in research about my issue here but still didn't find a solid answer.
I have 2003 WRX with all stock ej205. What happened was my turbo decided to go kaboom in the middle of a freeway. After I realized that it might of took out my internals I took the engine apart to see.
Sure enough I had a hole in piston 4. Also looked like it had a cracked camshaft. Basically a full rebuild is needed, which would cost me no less than 2k. On the other hand I've seen some good JDM ej205 engines for about $1k.
Let's say a JDM engine will have AVCS - will I need extra wiring or JDM Ecu to work properly?Or will it work with my USDM Ecu? I've seen people say yes and no so I am kind of confused. I am not considering any big power upgrades, so far I just want to go stock and make sure everything will work like it should. And yes I want to be able to pass emissions. I am a student so my budget for this project is minimal. Please help!
I have a 2005 forester xt that i need to do an engine swap or rebuild on. Due to time and only having one car presently, i wanna do a swap. I was looking to get a jdm 2.0 with the avcs since my car is equipped with this. My other concern are the 2 cam sensors at the back of my engine, are those on the jdm motor and would my harness and ecu work with the jdm ej2.0. Sadly its automatic. Oh and one more thing i have the cobb v3 correctly running would i still be able to use the cobb with the jdm motor?
Thanks in advance
DE DADDY is offline   Reply With Quote
Old 07-23-2019, 10:23 AM   #150
knightangle
Member#: 492769
2003 WRX Wagon
Sonic Yellow
My knowledge is very limited but if your going to do a jdm swap youíll want to us the jdm ecu with it which is HIGHLY recommended. Unfortunately that means no COBB access port because the software doesnít support JDM ECU for some reason
