Welcome to the North American Subaru Impreza Owners Club Tuesday October 15, 2019
Old 09-13-2019, 07:26 PM   #1
Mrnebitts360
Member#: 504111
Default ABS kicking in for no reason at low speeds
Hi Friends,
I have a 2004 STI and recently, my abs has been kicking in at low speeds on dry pavement.. even during very light braking. It kind of feels how it should in snow and ice. It make a very loud grinding sound when itís happening and I can feel the abs working on my foot, on the brake pedal.
I just replaced all 4 rotors and pads because my front driver side rotor was a little bit warped. The ABS issue continues.
Let me know what you all think, maybe sensors? Or the ABS module?
Thanks!
Mrnebitts360 is offline   Reply With Quote
Old 09-16-2019, 02:17 PM   #2
N3O9Pr
Member#: 484401
Does the issue persist when you disconnect the ABS sensor for the Front-Driver side?
N3O9Pr is offline   Reply With Quote
Old 09-23-2019, 12:20 AM   #3
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
sensor gap is too large, possibly due to a bad wheel bearing somewhere, or the sensor is covered in magnetic junk that's interfering with the pickup. The sensor is dropping out earlier than it is supposed to.
Nothing in the ABS system is likely to be broken - that would generally throw an error and turn the ABS light on. Try getting in there and cleaning the sensor and tone ring.
sniper1rfa is offline   Reply With Quote
