Welcome to the North American Subaru Impreza Owners Club Friday October 18, 2019
Old 11-02-2006, 10:19 AM   #1
bleuquila
Member#: 31922
03 wrx wagon
78 brat
Default Is it possible to splice a FM radio antenna wire?
This is for a Legacy GT, the stock headunit has a thick wire running out of the back of it, that you can't unplug - it leads to the external antenna for FM reception. During an XM install a year or so ago, that antenna wire was cut. Well, now the XM is coming out and the car is being sold, so I'm looking for ways to get the FM back. Basically, there's a length of wire coming out of the back of the radio, and it needs a female connector to hook up with the existing male that's connected to the antenna. Is it within the realm of reason to somehow .. crimp / solder that sort of connection on? There's 2 layers of wire, I think, making it bit more challening than the usual wiring job.
bleuquila is offline   Reply With Quote
Old 11-02-2006, 02:14 PM   #2
Daishi00
Member#: 78952
2005 WRX
CGM
sure, just make sure to match up what wire goes where and you sould be fine.
Daishi00 is offline   Reply With Quote
Old 11-02-2006, 04:06 PM   #3
lowranger
Member#: 124370
03 wrx?
Pro tuned by Cobb Tooning
if its like many antenae wires, then its split up into 2 areas. just like a cig lighter. the pos. is the single wire in the middle, and the sheething is the neg. IF its what im thinking about. otherwise i have no idea. i dont think u can. *shrugs.
lowranger is offline   Reply With Quote
Old 11-02-2006, 05:25 PM   #4
Judge
Member#: 15380
Its just a coax cable. The braided outter layer is the ground and the inner wire is signal. strip the coating back a ways...wrap the outter layer into a single strand on both ends and solder together. do the same for the inner wire. Use plenty of heat shrink and make it solid and you will be fine.
Judge is offline   Reply With Quote
Old 11-02-2006, 05:32 PM   #5
thedaddyb
Member#: 64374
07 WRX SWP *SOLD
03 2.5ts BRP long gone
Who installed that . . . and why would they cut the antenna wire? Stupid stupid stupid.
The antenna plug can be found at the amplifier on the GT (and sometimes on the back pillar on the wagons)
You would just have to get the antenna adapters to be able to plug it in.
What's done is done though . . . so the antenna wire is just a standard coax cable. The tiny inner wire is you + signal and the shielding is your - connection. There is also an antenna turn on wire but that should not have been cut, depending on where the wire was tapped.
thedaddyb is offline   Reply With Quote
Old 11-02-2006, 05:39 PM   #6
bleuquila
Member#: 31922
03 wrx wagon
78 brat
Ok, thanks for the feedback. Wasn't me that cut it up Just trying to save the owner the cost of buying a freaking all-new 6-disc changer to get a working radio.
I know there are specific coax crimpers you can buy for $20-odd dollars, would that be helpful? I'd rather solder it up, personally, so what you've suggested, judge, makes sense. Is there a reason that the ground is in the form of a shield? - i.e. should I try and make the stretch where the signal wire is not shielded as short as possible?
Not that .. I wouldn't anyway, I'm just curious now.
Old 11-02-2006, 06:16 PM   #7
thedaddyb
Member#: 64374
07 WRX SWP *SOLD
soldering it is the best way to go. i've repaired a few that way before. the inner wire is going to be a pain, usually it is 30 gauge or smaller. tape it up so the shielding won't touch it and then I usually attach the shielding back over the inner wire as best as possible. Loosing an inch of shielding shouldn't affect the reception too much.
Old 11-03-2006, 03:46 PM   #8
MTX05STI
Member#: 86547
2005 Subaru STI
I have spliced 2 in my day, only because of accidents. Both times, it was a clean splice but you can tell that the signal quality suffers.
MTX05STI is offline   Reply With Quote
Old 09-20-2019, 05:31 PM   #9
Mzsinko84
Member#: 480585
I was in the process of switching radios and I found out that what I needed to switch the head units and keep the ac, heater, the front windshield and the rear window defogger I had to order the proper piece meant for switching CD players in that era of US Legacies from Japan. I ordered that piece, I have a poor CD player installed but now I need to find the wire that is ment for ac, heater, radio and clock memory because every time I start my car I have set the radio, ac and the heater. I don’t worry about the clock but I want to get that corrected. As far as I know, there’s 2 yellow wires and there’s 3 red wires.
Mzsinko84 is offline   Reply With Quote
Old 09-20-2019, 05:32 PM   #10
Mzsinko84
Member#: 480585
is it possible to be depressed and not know it? WrxWonderWagon Off-Topic 15 05-12-2006 11:32 PM
is it possible to not take it personally, career related vile Off-Topic 10 11-30-2004 04:41 PM
Tint Ticket... Is it possible to get out of it? zperkins Bay Area Impreza Club Forum -- BAIC 6 08-21-2003 07:47 PM
Is it possible to increase radio reception? TrunkMonk Car Audio, Video & Security 3 01-24-2003 03:12 AM
Is it possible to wire aftermarket amp/sub into stock HU? Schleppy Car Audio, Video & Security 2 03-02-2002 10:16 AM
