Welcome to the North American Subaru Impreza Owners Club Saturday September 26, 2020
Old 07-04-2011, 08:37 AM   #26
quazimoto
Member#: 70395
Seafoams Deepcreep isn't to bad. I like slightly better than PB Blaster but it's not cheap.
quazimoto is offline   Reply With Quote
Old 07-04-2011, 02:57 PM   #27
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
well.....after using the GM rust penetrant and inhibitor heat valve lubricant #1052627 for the $$$ stuff and the ATF + acetone for stuff......
I really see no reason to use much else unless ya run outa one or the other.
Most of this 'penetrant' stuff is WAY overpriced, anyway
Old 03-20-2019, 12:20 PM   #28
FollowMe
Member#: 499326
Originally Posted by jechlu View Post
I use AD3000 its not expensive for the best Penetrating Oils and works wonders on seized bolts and any type of mechanical mechanisms
Doors, latches.
I'm a believer in Kroil. Though a shopmate has brought in a couple cans of stuff by BG (Barry Grant, or carb guys?) that seems to work better......I forget the name of the stuff at the moment. We get alot of use from our penetrating oils up here in the land of orange barrels and salt.....
FollowMe is offline   Reply With Quote
Best penetrating oil? WD40, Liquid Wrench, PB Blaster... JoeTX Newbies & FAQs 42 07-02-2017 02:46 PM
Oil filter comparison, 4 top brand oil filters cut up and compared. Paranoid Fabrications Service & Maintenance 203 04-19-2016 07:43 AM
FYI oil comparison srad711 Service & Maintenance 5 03-30-2005 02:06 PM
Motor oil comparison guide by API Craig02WRX Service & Maintenance 5 12-24-2004 03:19 AM
3in1 penetrating oil works well to quite your sway bars ciper Brakes, Steering & Suspension 6 07-16-2003 08:06 PM
