Welcome to the North American Subaru Impreza Owners Club Monday October 14, 2019
Old 09-04-2014, 03:58 PM   #926
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Originally Posted by xluben View Post
Are you going to run yours? We could race!
My motor is hopefully going back in tonight, but I won't be able to make it with the car this weekend. Will probably need some fine-tuning before it's good to go anyway. I may try to swing up on Saturday though, we'll see! My massive ego can't handle a loss to you anyway, so it's for the best.
Matt Beenen
Engineering
GrimmSpeed is offline   Reply With Quote
Old 09-04-2014, 04:07 PM   #927
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Matt Beenen
Engineering
Put it in and tune during frumrolls on Sunday
xluben is offline   Reply With Quote
Old 09-05-2014, 11:33 PM   #928
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Two broken axles and one 10 second pass.
Old 09-06-2014, 01:10 AM   #929
SenorDucK
Member#: 327511
13' WRX 6 Speed
11sec VF52 EL-EWG-E85
very nice! congratulations.
Video to follow?
SenorDucK is offline   Reply With Quote
Old 09-06-2014, 06:17 AM   #930
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Thanks! Yes, I have speedo vids and side line video. I had an in car video setup but it didn't work. My SD card was full and I didn't check it
Old 09-06-2014, 06:37 AM   #931
BURNING4ORCE
Member#: 356215
Congrats man on that 10sec pass and on the driving! What was the highest trap speed of the day?
BURNING4ORCE is offline   Reply With Quote
Old 09-06-2014, 06:47 AM   #932
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
That 126mph was the highest. I had a couple in the high 125mph range that I did soft launches. My axles were not holding up so I got very few passes in. All of the passes were on a full fuel tank as well
Old 09-06-2014, 07:02 AM   #933
SenorDucK
Member#: 327511
13' WRX 6 Speed
what tire were you on here?
Old 09-06-2014, 07:04 AM   #934
BURNING4ORCE
Member#: 356215
Your cutting 1.6s so you're definitely getting off the line pretty good. I'm guessing the rear axles were the ones snapping. At the end of the day you got that 10sec pass which is no easy feat by all means with or without a full tank gas. Well documented journal too man with stellar results to back it up that never disappoints. Good read here so congrats to you and Nuke.
Old 09-06-2014, 08:47 AM   #935
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
235/45R17 Federal 595 RS-R
Thanks! You are correct that it is the rear axles. I broke one on each side yesterday.
Old 09-06-2014, 11:19 AM   #936
2011rex18
Member#: 321728
2011 WRX Limited
So Ben what do you do to stop breaking the axles now? I mean the obvious is to not launch the car but for you going for more power and faster times, do you just continue to bring spares to the track or is there a fix lined up?
2011rex18 is offline   Reply With Quote
Old 09-06-2014, 11:58 AM   #937
toph
Member#: 78640
19 Tundra
04 STi
Probably end up cheaper getting DSS rear axles at this point. If you're snapping an axle or two every time you go out, eventually you'll make up the difference.
toph is offline   Reply With Quote
Old 09-06-2014, 12:23 PM   #938
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
DSS rear axles and an r180 would cost me well over $1000 but it should take care of it or at least make it much less likely. But I think I've spent about $10-15 on each replacement axle so far. So I could do a LOT more stock axles before the cost evens out. The downtime at the track is the real issue.
Old 09-06-2014, 12:41 PM   #939
Ultimateone
Member#: 48025
17 BMW M2
AW
Damn, awesome job Ben!
Ultimateone is offline   Reply With Quote
Old 09-06-2014, 03:13 PM   #940
toph
Member#: 78640
19 Tundra
04 STi
Oh, just rebuilding them, I see. The second time I had to do that at the track I wouldn't bring it back until I got something beefier. More power to ya.
Old 09-06-2014, 03:20 PM   #941
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
No, I'm not rebuilding. Just swapping in a spare stock WRX axle and throwing out the old one. If I got 20+ passes before breaking (like last time) I'd be OK swapping in a $10 axle. But if I am only getting 1-2 launches then it's not worth it.
Old 09-06-2014, 03:33 PM   #942
toph
Member#: 78640
19 Tundra
04 STi
Forgot you were still on WRX axles. Those are much easier to come by (and cheaper) than STi axles.
Old 09-06-2014, 03:34 PM   #943
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Exactly. Cheap and plentiful. And snap like twigs.
Old 09-06-2014, 08:18 PM   #944
SenorDucK
Member#: 327511
13' WRX 6 Speed
jeez I too for some reason was thinking of your GR drivetrain and also thought you had the r180 and STI rears!
the first after so many passes I was like fine, then saw these two I thought you must be wheeling hopping something fierce! the wrx axles make sense now! hahaha!
Old 09-07-2014, 02:12 AM   #945
2011rex18
Member#: 321728
2011 WRX Limited
Where are you continuously sourcing them just off here or? Only wondering in case this happens to me some time
Old 09-07-2014, 03:10 AM   #946
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Locally from wrecked or upgraded cars.
Old 09-08-2014, 04:14 PM   #947
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Full details on the runs from Proving Grounds:
Event: 1/4 Mile at MAPerformance Proving Grounds 2014.2
Ambient Temp: 70F
Elevation: ~1200ft
Weather: Sunny and Clear
Tires: 235/45R17 Federal 595 RS-R Tires on 2004 STI BBS Wheels
Car: 2002 WRX Sedan
Tuner: Nuke @ NF Performance
Transmission: 2012 STI 6 Speed
1/4 Mile ET: 10.99s
1/4 Mile Trap: 126.0mph
60': 1.67s
Target Boost: 30psi
Target AFR: 11's
Fuel: E85
10.99s @ 126mph with 1.67s 60' (street tires)
I drove the car ~2 hours up to BIR on Friday and made my first pass in the afternoon/evening. I was launching at around 5,500rpm's and only building a few psi of boost off the line (fuel cut launch control), but it was still enough to spin the tires hard and I broke an axle on the very first launch (driver rear). Spent an hour or so swapping in another OEM WRX axle.
I did a few passes with no launch and was trapping around 126mph consistently. It did mid-11's even with a ~2sec 60' time. I did another pass with launch control and it did a 1.6s 60' but I missed third gear. On the next launch it had a little hop, but it did another 1.6s 60' and I made a pretty clean pass which resulted in the 10.99s slip.
On the 10 second pass I shifted the car into 5th to make it through the traps. I had been going through in 4th for my earlier passes but the car didn't feel like it was pulling quite as hard up near 8,000rpm's so I decided to shift instead. It was almost time for the track to shut down at that point but I decided to do one more pass. Spun hard and broke the passenger rear axle.
I swapped the axle (I had 4 spares with), but then I decided not to run drag on Saturday and Sunday. It cost more money and I was tired of changing axles. On Sunday I did roll racing. I was neck and neck with several other cars in the same power range and I pulled on a stock GTR. Then I drove the car back home. Overall a great weekend and I'm happy to be in the 10's!
Old 09-08-2014, 05:02 PM   #948
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
Nice work Ben!
Wish I could have made it up but I spent the whole weekend swapping in a new clutch and turbo setup to get ready for the Subaru shootout coming up.
Have you tried the drag anti-lag in the carberry tune to see how it works? Maybe a little MORE spin would move the car and avoid some hopping if that's what is happening. Just taking a guess at it though. What tires are you running? I might have missed it if you mentioned it somewhere.
WRXt4cy is offline   Reply With Quote
Old 09-09-2014, 11:06 AM   #949
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Originally Posted by WRXt4cy View Post
Nice work Ben!
I don't have the anti lag setup on this car, but I've seen it on other cars and it does launch very hard. I drove one that had it setup last year and made 15+ psi on the line. That's all but useless on street tires. Even with fuel cut LC and only a couple psi I could still spin really hard if I slipped the clutch a little.
Excessive spin was when I would break axles. The spin leads to hop and hop leads to breakage. When it grips well (and launches hard or bogs) I haven't had any breaks. I think with slicks they tend to spin a little more smoothly, so that might actually help if it reduces hop.
Right now I'm running the cheap-o Federal 595 RS-R tires in the 235/45R17 size.
PS. New thread title! Thanks to the mod who took care of it for me!
Old 09-09-2014, 09:33 PM   #950
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
