Welcome to the North American Subaru Impreza Owners Club Wednesday October 16, 2019
Old 09-03-2014, 02:32 PM   #76
Chuck2012
Member#: 324568
2005 Wrx Sti
How are the CNT EL headers holding up so far? I'm very interested in these as a cheaper alternative to perrin's.
Chuck2012 is offline   Reply With Quote
Old 09-03-2014, 06:31 PM   #77
Bad Noodle
Member Sales Rating: (26)
Member#: 174442
2007 SuperWagon
I don't spell well
Default CNT performance Subaru STI Equal Length header
I have the eBay headers pictured above and so far I found that the slip joints leak like a bitch and the O2 bung stripped out when I dropped them to fix it. I only have 150 miles on them
The cheapness of the header comes from the poor materials used and poor assembly where you can't see it
Bad Noodle is offline   Reply With Quote
Old 09-03-2014, 07:17 PM   #78
Type2
Member Sales Rating: (30)
Member#: 200436
2004 Forester XT
The $99 ones I linked to above lol? Or the CNT ones? The $99 ones were posted as a joke
Type2 is offline   Reply With Quote
Old 09-03-2014, 07:33 PM   #79
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Na, the $500 ones that still sucked. I imagine the 99 are made of cardboard
Old 09-10-2014, 10:55 AM   #80
hakira
Member Sales Rating: (9)
Member#: 74211
SSM WRX 4DR
Originally Posted by Hellchaser View Post
No egt sensor. Got the rebuilt turbo and tgv deletes installed. Now waiting for a retune. Need to get a day off
Updates on any cracks? I noticed that CNT says wrapping the headers voids the warranty.
hakira is offline   Reply With Quote
Old 09-10-2014, 03:54 PM   #81
Hellchaser
Member Sales Rating: (7)
Member#: 278263
No leaks. Car is actually at PSI Proformance and I'm getting it built n tuned. Should be ready for pickup in about 20-25 days. Dropped it off today.
Hellchaser is offline   Reply With Quote
Old 11-12-2014, 03:34 PM   #82
Type2
Member#: 200436
2004 Forester XT
Updates? I still can't shake the thought of these headers...
Old 11-13-2014, 12:20 AM   #83
Hellchaser
Member#: 278263
Before the rebuild I was on 91 oct plus alcohol at 24 psi. 382whp/387wtq
After build I went without the alcohol (pump 93 only) at 20psi 396whp/370wtq
After I put about 5,000 miles on the block they said to come in for a 23psi map and should see 430whp/400wtq
The car definitely pulls harder and feels way more powerful. I did remove the alcohol kit, added TGV deletes, forged internals, gsc 272 cams,and ELH. Both numbers are from 2 different DYNO jets & tuners. Many variables came into play; different fuel & boost were the main 2.
Old 12-10-2014, 04:28 PM   #84
Weempster101
Member Sales Rating: (6)
Member#: 149720
2005 STI
CGM
anyone else have an experience with these header?
Weempster101 is offline   Reply With Quote
Old 12-10-2014, 08:18 PM   #85
bmxhotsauce
Member Sales Rating: (10)
Member#: 127099
02 IMPERZA WRX
BLACK
How have they been lasting and holding up ? Any leaks on the welds ?
Sent from my HTC One using NASIOC mobile app
bmxhotsauce is offline   Reply With Quote
Old 12-11-2014, 03:57 PM   #86
Chuck2012
Member#: 324568
2005 Wrx Sti
I installed mine and fit decent. No issues installing them. I did a ceramic coating and heat wrap.
Old 12-29-2014, 01:17 AM   #87
Trippinonjuice
Member#: 394951
2006 Impreza Wrx Sti
Gray
Installed mine 2 days ago. I can't complain so far, the car definitely feels like it picked up power with just bolting it on. The install didn't give me any issues, pretty straight forward. The only thing that annoys me is that it rattles at low rpms. Probably because it's thinner metal but other than that im happy with them for the time being
Trippinonjuice is offline   Reply With Quote
Old 12-29-2014, 01:55 AM   #88
bmxhotsauce
Member#: 127099
02 IMPERZA WRX
BLACK
Are you running that without a tune ??
Sent from my SM-N910T using NASIOC mobile app
Old 12-29-2014, 01:32 PM   #89
Trippinonjuice
Member#: 394951
Gray
im currently on a stage 2 open source map at the moment. Spoke to my tuner and said im completely fine with the way it's setup now but it's in my best interest to get a retune with the header to get the full potential out of it.
Old 12-29-2014, 01:56 PM   #90
Type2
Member#: 200436
2004 Forester XT
Good quote from Chris at Killer B:
http://forums.nasioc.com/forums/show....php?t=2391203
Originally Posted by KillerBMotorsport View Post
^ This
You don't NEED a tune, but we highly recommend them. Under low load it's no problem since the ECU is monitoring A/F, but once you go into heavy load (open loop) there is no A/F feedback to the ECU and fueling relies on pre-set parameters. Adding a header, thereby increasing the engine's efficiency, will cause the fueling to be more lean under heavy load, which can lead to detonations, which is bad.
A tune will resolve this issue via A/F moitoring on a dyno, and the proper fueling changes. Another benefit to these changes is more power
Old 12-30-2014, 07:00 PM   #91
SnakeEyez
Member#: 172752
I'm afraid of these.. I've always lived by the term you get what you pay for and these are by far one of the lowest priced pieces I've found.
SnakeEyez is offline   Reply With Quote
Old 03-28-2015, 04:18 PM   #92
OC_Nooby
Member Sales Rating: (3)
Member#: 311781
2003 WRX w STI V8
If these were the same price as the Agency Power would you pick the Agency Power or the CNT?
This is my pickle.
OC_Nooby is offline   Reply With Quote
Old 07-09-2015, 11:38 PM   #93
Specter86
Member Sales Rating: (1)
Member#: 300359
2013 wrx sedan
satin white pearl
Does anyone know if this quote " you do not NEED a tune" mean headers on a stock tune? Would it be better if running the Cobb ots stage 2? Which is the tune I have at the moment......
Custom tune will be optimal, This I know
Specter86 is offline   Reply With Quote
Old 07-09-2015, 11:54 PM   #94
Hellchaser
Member#: 278263
I don't know the answer for that but for an update,
My CNT el header is still running fine. Got a FP Red HTA and made 430whp on the same dynojet that my 20g made 396.
Old 07-10-2015, 08:29 AM   #95
Type2
Member#: 200436
2004 Forester XT
I can't remember if you said whether you wrapped it, coated it or nothing?
Old 07-10-2015, 10:10 AM   #96
Hellchaser
Member#: 278263
I wrapped them.
Old 01-27-2016, 01:48 AM   #97
pigboat_2
Member Sales Rating: (22)
Member#: 247823
2006 Fxt
RBP
Thread revival.
I just picked up this header and I'm trying to document a full before/after review of sound and performance. I have been doing a lot of back and forth e-tuning with my tuner to get the most out of my current setup, and then swap out the headers and retune. The goal is to have the headers be the only difference, not fuel, atmospheric differences, etc.
I got all tuned up yesterday and went to install the header today only to find that I ran into fitment issues with the oil filter on my 2006 wrx wagon. I found some good info on Perrin install that requires you to modify or replace the oil cooler, so I'm going to give that a go, but I had to put the car back together so I can still drive it.
I will post my own thread with pictures, videos, dyno graphs, etc and the most thorough review possible. And hopefully follow up with a long term review later on. If install goes smoothly, I plan to remove the headers to get them ceramic heat treated for better heat control, as CNT claims wrapping will void the warranty.
pigboat_2 is offline   Reply With Quote
Old 01-27-2016, 01:59 PM   #98
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
This will be cool
Old 01-27-2016, 03:38 PM   #99
Type2
Member#: 200436
2004 Forester XT
There is a version 2 of these headers I believe just released. Is that what you bought? If you do a video with sound and you get a strong itch to use a background music soundtrack please don't.
Looking forward to this!
Old 01-28-2016, 04:42 PM   #100
gurusan
Member Sales Rating: (5)
Member#: 258165
2006 WRX Wagon
Looking forward to your post pigboat....I am also considering these for my 06 wagon.
gurusan is offline   Reply With Quote
