Welcome to the North American Subaru Impreza Owners Club Monday October 14, 2019
Old 08-10-2019, 12:04 PM   #1
olazy
Member#: 263322
2011 WRX Limited
WRBP
Default 24 pin male connector for factory navi
Does anyone know where I can source a 24 pin male connector that would plug into the factory kenwood navigation harness? I'm try to avoid tapping into the existing harness to get the steering wheel controls to work.
I would reach out the svxdc but not sure if he still active.
simlar to the connector shown here:
olazy is offline   Reply With Quote
Old 08-14-2019, 09:52 PM   #2
WagonR
Member#: 160011
2010 WRX
What exactly are you looking for? I think you want two things:
1) A plug that replicates the factory male plug, with all of the associated wires, and
2) A plug that replicates the headunit's female plug, with all of the associated wires
You'll basically connect all of the wires between the plugs straight across, but you'll connect that canbus wires that go into the headunit to the steering wheel adapter.
You should be able to get the plugs for both on something like ebay. The second item is super common, but even the first should be available. For the 2010's the stereo plug was the same as the older (02-07) impreza's if you had Navi. Not sure if that changed in 2011 or not.
Edit. I'm dense. If you're doing this, are you doing it with an aftermarket headunit? If so, you don't need item 2, that will already be included with the headunit. As such, you just need item 1. You can get that on ebay, best buy, a car stereo store, etc.
WagonR is offline   Reply With Quote
Old 08-19-2019, 04:47 PM   #3
corlon
Member#: 352266
no one manufacturers the connections you are requesting. someone might offer the harnesses connected to one another, but their making the connections them self.
corlon is offline   Reply With Quote
Old 08-23-2019, 12:11 AM   #4
WagonR
Member#: 160011
2010 WRX
No. Not sure how any of this makes sense.
