Welcome to the North American Subaru Impreza Owners Club Tuesday October 22, 2019
Old 10-23-2018, 09:19 PM   #1
panel
Member#: 352704
1965 Vw panel van
EJ20 Turbo Swap/convo
Default Coolant header tank lid
Made up a new header tank lid for my conversion. Welded -06 AN's and filler neck.
panel is offline   Reply With Quote
Old 10-25-2018, 10:32 AM   #2
DEANORS
Member#: 474472
2000 Impreza RS
Looks great!
What type of paint/powder coat was used?
Whats the conversion? Are you using the stock bottom of the tank?
DEANORS is offline   Reply With Quote
Old 10-25-2018, 08:21 PM   #3
panel
Member#: 352704
1965 Vw panel van
Yup , same stock bottom tank. Also had an AN bung welded on and the lid is powder coated.
Old 10-26-2018, 11:48 PM   #4
panel
Member#: 352704
1965 Vw panel van
Old 10-29-2018, 12:00 PM   #5
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
nice work, how are you addressing the mating surfaces?, as far as i know the gasket is not available and only available as a whole tank unit.
fastnoypi is offline   Reply With Quote
Old 11-21-2018, 07:38 PM   #6
sackytar
Member#: 149262
03WR rallycarFXTleg
PrimerGrey
Nice where did you source the filler neck from. What size is it?
sackytar is offline   Reply With Quote
Old 11-21-2018, 09:28 PM   #7
atm0706
Member#: 279219
02 WRX, 06 STi
PSM, WRB
Nice piece, and nice bus!
My brother just got a 82 westy that needs a motor, and I have a spare wrx drivetrain collecting dust in storage.... hmmm
atm0706 is offline   Reply With Quote
Old 01-27-2019, 11:29 PM   #8
panel
Member#: 352704
1965 Vw panel van
fastnopyi......the mating surface has a big o ring recessed in the tank itself. It's basicallt the same surface as the stamped steel top.
sackytar
......eBay......https://www.ebay.com/itm/Outside-Wel...item3fa3404e96
