Welcome to the North American Subaru Impreza Owners Club Friday September 18, 2020
Old 11-15-2018, 05:49 PM   #1
CarmelValleyWRX
Member#: 453872
2005 wrx wagon
48w
Default overly complex IWG bracket
here is my over built bracket to hold my WG shut while running EWG. made of 303 SS + 6061
still have to make the bracket to turbo.
made the tie rod today.
hopefully the spring will keep its strength. its super strong (yz250 clutch spring)
https://i.imgur.com/XDl8qCq.png
https://i.imgur.com/25h6Adq.jpg
https://i.imgur.com/q6Ov0Lk.jpg
CarmelValleyWRX is offline   Reply With Quote
Old 11-15-2018, 07:35 PM   #2
TDagen
Member#: 163648
V9 6mt R180 Brembos
Excellent craftsmanship.
TDagen is offline   Reply With Quote
Old 11-15-2018, 08:05 PM   #3
CarmelValleyWRX
Member#: 453872
2005 wrx wagon
48w
i like purdy things
Old 11-16-2018, 11:43 AM   #4
Hyper
Member#: 15822
1999 WRB GM6
2.34 LR destroker
beautiful
Hyper is online now   Reply With Quote
Old 11-16-2018, 03:04 PM   #5
CarmelValleyWRX
Member#: 453872
2005 wrx wagon
48w
Old 11-16-2018, 04:25 PM   #6
rtv900
Member#: 428511
2016 STI
did you turn that rod up first?
no lathe pics?
rtv900 is offline   Reply With Quote
Old 11-16-2018, 05:42 PM   #7
CarmelValleyWRX
Member#: 453872
2005 wrx wagon
48w
sorry. was trying to keep it cool/adjusting the tailstock because of growth/adjusting feeds and speeds. im still learning stainless...
seems to work good. the car spools like a mofo.
Old 11-18-2018, 09:19 AM   #8
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
Originally Posted by CarmelValleyWRX View Post
I like purdy things
Why kill something when you can overkill it!?!?
Looks nice.
Old 11-18-2018, 09:02 PM   #9
CarmelValleyWRX
Member#: 453872
2005 wrx wagon
48w
the funny thing though is it probably would have taken several tries to make a crappy sheet metal one just right so it would hold. if you overkill things they CAN work first time if done right
Old 11-18-2018, 09:42 PM   #10
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Oh, I am not complaining at all, trust me. I appreciate the design and effort, I was attempting to be humorous, but I am also a Dad. We think our jokes are funny, not many others do though.....
Old 11-18-2018, 09:52 PM   #11
CarmelValleyWRX
Member#: 453872
2005 wrx wagon
48w
thanks my friend.
im loving the EWG spool up and torque gain! its quite amazing TBH how much difference it makes. only problem is i have to redo my VE
first time it opened i was like..
Old 11-19-2018, 08:34 AM   #12
rtv900
Member#: 428511
2016 STI
good ol stainless
just going slow as hell is usually a good starting point, although a small diameter like that you can get away with some pretty high rpm
Old 11-19-2018, 02:20 PM   #13
CarmelValleyWRX
Member#: 453872
2005 wrx wagon
48w
luckily 303 does not work harden too bad. it machines kinda more like mild steel. but 304 is an absolute beast to machine. eats drill bits for breakfast. i used to have to drill thousands of holes in SS to build cable railings at my last fab job. i would run the mill at minimum speed/very hard feed and keep the bit cooled and still would only get maybe 15-20 holes before having to sharpen them. band saws also don't like 304
Old 11-19-2018, 02:54 PM   #14
rtv900
Member#: 428511
2016 STI
yeah drilling is painful
just did some 17-4 ph on a lathe with no through tool coolant, just a hose, and had to drill 2.75 inches into a blind hole.
Numerous diameters, counterbores, radii, etc and the drilling was still 75% of the whole cycle.
I'd kill for through tool coolant.
Old 11-20-2018, 01:09 PM   #15
isotopesope
Member#: 265783
2017 Forester XT
Niner ROS 9
damn, really nice work.
isotopesope is offline   Reply With Quote
Old 11-24-2018, 05:18 PM   #16
CarmelValleyWRX
Member#: 453872
2005 wrx wagon
48w
thanks
Old 11-25-2018, 11:27 PM   #17
Bariga
Member#: 179846
07 STi Limited
EFR 8374 TS EWG
great to see people invent new things, sad to see that big vendors are not doing **** or any RND. All they can do is scan oem part and make it out of better material .....
Bariga is offline   Reply With Quote
Old 12-16-2018, 03:41 PM   #18
stu
Member#: 25768
2003 GEN2 GTX35 40++
2.3 slobaru
That is a great idea, but why would you use a spring where the gate could still open under boost?
stu is offline   Reply With Quote
Old 12-16-2018, 05:08 PM   #19
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Assuming a stiff enough spring......last ditch overboost safety? Or, maybe allows for some thermal dimensional changes without breaking things.
Old 12-16-2018, 07:14 PM   #20
CarmelValleyWRX
Member#: 453872
2005 wrx wagon
48w
its plenty stiff enough to hold it closed no problem. my thinking is it always maintains tension. if it was a fixed distance it might be tight when cold but open up under heat or vice-versa. even the GS one is basically a spring. but they are using the "springyness" of the sheet metal instead of making the parts stiff and adding a spring into the mix.
