Welcome to the North American Subaru Impreza Owners Club Saturday October 19, 2019
Old 07-05-2019, 07:59 PM   #1
ikeryder13
Member#: 304728
09 WRX
Default New wheel help
I am looking to get a set of 18x8.5 +45 gramlight 57cr wheels but I want to make sure these will clear my brembos. I know it really all has to do with the spoke design because the size should be ok. I have 235/40/18 tires also. Will these fit without fender work? I have a 09 hatchback.
ikeryder13 is offline   Reply With Quote
Old 07-06-2019, 11:23 AM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
https://forums.nasioc.com/forums/sho....php?t=1945625
https://forums.nasioc.com/forums/sho....php?t=2208775
For questions of Brembo clearance with a specific wheel, my suggestion would be to contact the vendor. You effectively have an '04 STI - Brembos with 5x100 bolt pattern. If they can't tell you if the wheels will clear your brakes, they shouldn't be selling the wheels.
Old 09-14-2019, 12:56 PM   #3
ikeryder13
Member#: 304728
09 WRX
Yeah I agree.... still looking for some help with this
Old 09-16-2019, 04:26 PM   #4
ikeryder13
Member#: 304728
09 WRX
I contacted the vendor and they said no more than a +38 offset???? That cant be right can it?
Old 09-17-2019, 11:54 AM   #5
Mach V Dan
Member#: 12029
This page appears to indicate they will clear BRZ 4-pot Brembos. (The little black inverted triangle is listed as "IMPREZA (GDB 4POT), 86/BRZ Brembo".) BRZ Brembo 4-pots are the same calipers as STi Brembo 4-pots. Therefore, they should fit over your Brembos, assuming you've retrofitted STi Brembos to your WRX.
Dan
Mach V
FastWRX.com
Mach V Dan is offline   Reply With Quote
Old 09-25-2019, 10:18 PM   #6
ikeryder13
Member#: 304728
09 WRX
Dan thanks tons!!
Old 09-27-2019, 06:20 PM   #7
ikeryder13
Member#: 304728
09 WRX
Dan do u think there will be a issue in the rear?
