Welcome to the North American Subaru Impreza Owners Club Friday October 18, 2019
Old 07-31-2019, 04:18 PM   #1
SightsSetStudios
Member#: 499997
2001 Impreza OBS
Default Diy Single Port UEL Headers
Looking to weld up my own from some mandrel bent since it seems the only place to get a set is Inferno Fab. Just wondering if anyone had any tips? Does the ratio between the length of the two unequal pipes up to the collector matter, and if so does anyone know what it should be? Any other insight is welcome as well. Thanks.
SightsSetStudios is offline   Reply With Quote
Old 08-01-2019, 01:00 PM   #2
SightsSetStudios
Member#: 499997
2001 Impreza OBS
Anyone?
Old 09-25-2019, 11:32 PM   #3
PWpaperweight
Member#: 474256
I had built my own a long time again and just went for it, it had a pretty good rumble, I did not measure the lengths just followed what I thought was the best route. It was similar to the turbo car routing but on the opposite side. I also tacked all of it on vehicle to get everything lined up properly then removed it and finished the welds. There may be some magic length but over the equal length you may loose power it just won't be noticable on this engine. Have fun with it and go for it and keep the old ones incase something doesn't work out!
PWpaperweight is offline   Reply With Quote
Old 10-14-2019, 02:23 PM   #4
Hellzbellz123
Member#: 506998
1997 Impreza Outback
Red
Outback Sport Reply to DIY UEL Headers
Dirt Cheap daily has a good video of doing this.
i plan on doing something similar when i have the mony
cheers
Hellzbellz123 is offline   Reply With Quote
