Welcome to the North American Subaru Impreza Owners Club Sunday January 20, 2019
Old 08-23-2006, 10:06 PM   #1
vitai0
Member#: 103245
1967 912 STi Spec C
Ivory White
Default Shifter return spring
im trying to find out what spring I can buy that is the same as the Subaru OEM return spring for a manual transmission. I can stand the slop i have in the shifter right now. Any tips or help would be great.
thanks.
vitai0 is offline   Reply With Quote
Old 08-24-2006, 12:50 AM   #2
seowitz
Member#: 9072
95 Legacy L
puke
how bout getting the stock spring if you can't sand the slop in the shifter.
seowitz is offline   Reply With Quote
Old 08-24-2006, 07:39 AM   #3
vitai0
Member#: 103245
1967 912 STi Spec C
Ivory White
Just thought Ive heard that there was an almost exact same spring that one can get at Ace Hardware. If there spring only costs a 1.50 then great. Just dont feel like paying 10 bucks or soemthing for a spring.
Old 08-24-2006, 08:27 AM   #4
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
^You can find a replacement spring from any home improvement store. I'd go with one which had a little more spring strength for added measure against slop.
xcntrk75 is offline   Reply With Quote
Old 08-24-2006, 08:31 AM   #5
ooberdoob
Member#: 70418
1968 Ford Bronco
Weld slag gray
or you can just get one from the dealer, it's like $3.
next time search. i made a thread about this.
the 1-2 to center PN is 33022ga081
ooberdoob is offline   Reply With Quote
Old 08-24-2006, 12:16 PM   #6
Wiscon_Mark
Member#: 94945
2015 Dodge Charger
AWD
I knew you had something about this, David. That's why I told Mike to go looking for your name.
Wiscon_Mark is offline   Reply With Quote
Old 10-02-2006, 09:15 PM   #7
Gil
Member#: 20872
t3h rubber-neckers
must die!
i concur with oooberdupe.
SOA PN 33022GA081, 89 cents when i got mine.
Gil is offline   Reply With Quote
Old 10-03-2006, 09:32 AM   #8
vitai0
Member#: 103245
1967 912 STi Spec C
Ivory White
Yeah i finally got it from the dealer. Much softer than I expected but its factory setting. I think i got it for like 1.89 or something close to it.
thanks again.
Shifter return-to-center dead ooberdoob Legacy Forum 15 03-19-2006 11:36 AM
Shifter return spring? wrx2 Transmission (AT/MT) & Driveline 7 04-01-2004 01:43 AM
How do I replace a shifter return spring? Mike Wevrick Transmission (AT/MT) & Driveline 9 05-18-2003 10:40 AM
MY97 2.2 clutch return spring P/N? OBSS Technical Forum Archive 2 09-07-2000 01:13 AM
