09-16-2013, 04:00 PM | #76 |
Member#: 341113
SCIC
Vehicle:2013 WRX Dark Grey Metallic |
09-17-2013, 12:25 PM | #77 |
Member#: 335013
RMIC
Vehicle:2013 Premium WRX 5dr WRB |
09-19-2013, 03:54 PM | #78 |
Member#: 275899
Vehicle:2013 BRZ/16FozXT Lightning Red / White |
I just bought a BRZ head unit to go into the Subaru XV. I assume the install will be the same since the base XV uses the same crappy head unit.
10-12-2013, 11:24 AM | #79 |
Member#: 275899
10-19-2013, 02:55 PM | #80 |
Member#: 275899
10-21-2013, 10:02 PM | #81 |
Member#: 309196
NESIC
Vehicle:2012 Hatch wrb |
Well I finished the install of the FW602US in my wrx. A few little pbs along the lines but thanks to a good friend, we fixed the issue. VSS works, but it appears to read 20mph +/- above what the speedo shows on my cluster (when driving and looking at VSS input in the diagnostic menu)... Odd?!
I also realized to my dismay that I couldn't read the mp3 files directly from my usb as I was able to do right before I made the switch! I had no idea the FT didn't allow this. My friend plugged in his nano and it worked, so I now the usb/aux functions work, I just don't understand why my usb stick won't be read anymore (it worked fine before). But all in all, GPS, BT, VSS, rear camera, HDradio and everything else minus the sat works great! I need to finish my camera install and continue to get familiar with the FT's functions. |
10-22-2013, 02:17 AM | #82 |
Member#: 25837
South East
Vehicle:1996 SVX L AWD Laguna Blue Pearl |
Download Subaru's user manual for this HU. See link to owner's manuals in my 'Subaru stock HU info' thread. The manual has a section that spells out what file formats and folder organizations are acceptable.
10-22-2013, 07:12 AM | #83 | |
Member#: 309196
NESIC
Edit: it was a fluke. tried a 16Gb drive, and worked just as it should. Not sure what happened if the other one, ehh... all working just fine Edit: any hack to skip the two 1st screens after you power up unit? Last edited by jojo69; 10-22-2013 at 08:00 AM. |
10-22-2013, 03:54 PM | #84 | |
Member#: 25837
South East
On all of these HUs that read USB flashdrives, they have a very simplified "operating system", not at all like Windows. For example, most don't sort filenames -- they see the list in the same order that the files physically appear in the flash drive's table of contents. This is why people have often posted about being surprised that the HU doesn't display the list in the order they expected (and you have to use a utility to copy files to a flash drive to make sure they're written in the desired order). So some of these HUs can get confused when they run across a file that they don't like (e.g., too large, unsupported encoding, flash drive too large, etc.). Last edited by SVXdc; 10-25-2013 at 07:28 AM. |
10-23-2013, 10:41 AM | #85 |
Member#: 309196
NESIC
Love the nav thus far. The only grip i have about this FW602US nav system is that it's a wee bit slow at times, and same with registering my touch. I guess my opinion is biased as the only comaprison I have is my tablet or phone. Not a deal breaker, just my experience thus far.
Here are some pics of the rear camera setup (CCD2000/cut some trim to make it more subtle location) and inside shots (and yes the correct bezel would be better, i'll get to that eventually): Last edited by jojo69; 10-23-2013 at 10:46 AM. |
10-23-2013, 12:25 PM | #86 |
Member#: 370524
International
Vehicle:2003 Legacy 2.0R Silver |
Wow! Good job!
10-23-2013, 12:36 PM | #87 |
Member#: 309196
NESIC
11-16-2013, 04:05 PM | #88 |
Member#: 335013
RMIC
Yeah nice job on the camera install. I thought about doing it but having to run wires through the whole car makes me sick May be next summer when I install my amps and component speakers I'll do it at the same time.
Also I was wondering how you guys deal with the ground cable. I can't seen to find a place to ground it. |
11-18-2013, 07:33 AM | #89 |
Member#: 309196
NESIC
Other than the grommet part between the hatch and body (a pain. Used grease to make it easier to slide), a little grinding of the driver plastic license plate housing to fit the cable nice & snug, the wiring from rear to front was SUPER easy! Just pass it via the roof/upper window seal trim (as opposed to lower trim). Total time: 10mn.
12-30-2013, 08:49 PM | #90 | |
Member#: 341113
SCIC
12-30-2013, 08:50 PM | #91 | |
Member#: 341113
SCIC
03-01-2014, 02:31 PM | #92 |
Member#: 320175
Vehicle:2013 WRX Premium Silver |
Oem sub
So far it's been idk 8 months since I retro'd the nav and couldn't be happier. Yea it's got quirks (takes a little time to find a satellite from time to time being my only real complaint) but I'm not using a stock GPS antenna so I can't fault the system. Another rather funny quirk, which I'm assuming has something to do with the disconnected vss is the "phone connected" block covering the screen while in reverse, completely blocking the camera view at the worst possible moment lol.
Wanted to know, if I want to add the oem trunk or under-seat sub, do I buy the nav or non nav unit? Common sense tells me to get the unit with the non nav harness but I'd rather get a second opinion before making a $$$ mistake. Thanks all! |
03-02-2014, 03:57 PM | #93 | ||
Member#: 25837
South East
You definitely don't want a sub with harnesses for cars with the older OEM Kenwood nav (14-pin). But if Subaru has versions with either the 20-pin (non nav) or Toyota-style (FT nav) harnesses, you could go either way. I'd recommend the 20-pin, since more people would be interested in that if/when you decide to sell it. In a few years, if Subaru continues switching their HUs to Toyota-style harnesses (and assuming they don't switch to yet a different style of harness down the road), then at that point it might be better to go with the Toyota style. BTW, it looks like some of Subaru's under-seat sub kits still include both the 20-pin and 14-pin harnesses. There are always people who are interested in buying the one you don't use, either for a used sub they got without harnesses, or to use for an aftermarket sub. Last edited by SVXdc; 03-02-2014 at 04:07 PM. |
03-06-2014, 06:57 PM | #94 |
Member#: 341113
SCIC
Anyone know what the difference will be in the FV619US?
What are all the compatibale fujitsu ten models? There seems to be soo many different models. Last edited by pkluong; 03-06-2014 at 07:33 PM. |
03-09-2014, 04:02 AM | #95 | |
Member#: 25837
South East
Yes, there are quite a few different variations on the FT nav HU. It seems that almost every different Subaru model and year gets a different model number. All of the ones I've seen look virtually identical from the back (except for the model number sticker). The main differences that I've found are:
04-25-2014, 01:20 AM | #96 |
Member#: 388947
Vehicle:2014 WRX WRB |
This might sound super ignorant- but this unit, or at least a version of it, is available for the 2014 wrx, which is what I own. Even if I bought that exact FT model would i still have to rewire everything? I guess I'm just surprised that there are that many differences like the usb and everything. Id think it would be more cost effective to use the same ports in all of them.
I just bought a 2014, my first subaru after owning 3 audis. I did not get the premium as there wasn't one available unless i really wanted to travel far (I drove two hours each way to get the one I have). I was hoping to put the OEM Navi in easily on my own and not spend the 2k+ the dealer wants. I want to stay as stock as possible. I figured I'd have to add the gps antenna and everything but I guess Im just surprised that all of the harnesses are THAT much different. so- is there not a navi that is pretty much plug and play with my car? Im so lost and Ive been reading for about 5 days. |
04-26-2014, 10:56 AM | #97 | |
Member#: 335013
RMIC
05-07-2014, 03:01 AM | #98 |
Member#: 335013
RMIC
Finally installed my JBL MS-A1004 to power a set of JBL-MS62C component speakers and Infinity Kappa 63.9i. This amp is amazing. Super easy to set up. Connected to my FT unit without a LOC and the built in DSP accepted the line level input perfectly.
05-19-2014, 09:22 PM | #99 | |
Member#: 372043
Vehicle:15 sti WRB |
Help me please
SVXdc, Need your help please. Just bought 2015 sti launch edition. Doesn't have the navi option and the dealer didn't really help me at all. Said they couldn't install it. Boooo So I bought a Subaru navi (fa601us) from brz, hoping that I could just buy the harnesses I need, then plug and play. I though it was a dealer option and they would have that, but I'm told its factory only. I'm not very good at electricals (figuring out what goes where), but good with my hands and following instructions so should be able to do it no problem. The car already has a backup camera and I got the antenna with the radio. But the rest is a mess. Last edited by FunRuSSkiMAN; 05-19-2014 at 10:49 PM. |
05-24-2014, 04:34 PM | #100 |
Member#: 391186
all of this home modifying looks like a quick way to void the warranty
If anyone is looking for a Subaru Nav unit fujitsu ten FM601US I have one in really good condition that I would like to sell. email me here |
