Welcome to the North American Subaru Impreza Owners Club Monday May 20, 2019
Old 04-22-2014, 03:08 PM   #3976
TarmacDaddy
Member#: 327056
2016 STI
CWP
Originally Posted by colin1234567 View Post
More SBC?
Sexy all tucked up in there
TarmacDaddy is offline   Reply With Quote
Old 04-22-2014, 07:55 PM   #3977
JDMWerks
Member#: 379711
Originally Posted by rhinis23 View Post
summer is finally here!
wheel specs? spacers?
JDMWerks is offline   Reply With Quote
Old 04-22-2014, 08:11 PM   #3978
Turtlefart
Member#: 320054
2011 WRX
Turtlefart is offline   Reply With Quote
Old 04-22-2014, 08:24 PM   #3979
bassler
Member#: 167544
'12 DGM STi sedan
'14 Audi S6, '16 XC90
18x10 +38 RPF1s on 265/35 Dunlop z2s. 5 mm hub/wheel centric spacers in front with Arp extended studs. Tarmac2s with vorshlag plates at -2 degrees camber. Ride height will probably come down 1/4 inch this weekend.
bassler is offline   Reply With Quote
Old 04-24-2014, 09:45 PM   #3980
ScoobyFreak86
Member#: 338329
2017 STI
Lapis Blue
Second times a charm...
ScoobyFreak86 is offline   Reply With Quote
Old 04-25-2014, 06:01 AM   #3981
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
I found 3mm hub centric spacers. Pretty hard to find but allowed the camber to stay more neutral.
How difficult is it to replace the studs?
Louie is offline   Reply With Quote
Old 04-25-2014, 08:44 AM   #3982
bassler
Member#: 167544
'12 DGM STi sedan
Looking gooooood! Now go get us some better shots to lust over
Old 04-25-2014, 08:59 AM   #3983
bassler
Member#: 167544
'12 DGM STi sedan
custom 5mm spacers (http://www.motorsport-tech.com/wheel_spacers.html - they'll mill you 3mms too!) came with the wheel set so i used those. I knew it was more than i needed but i had them and didnt mind the idea of the extra clearance. I also knew i was increasing camber so that was not an issue either and i could adjust as needed later with the plates.
studs became a requirement due to the 5mm spacers. I could have gotten away without them on the 3mm spacers but i figured i should just get it all done. I had my mechanic do it all since it was so much work (fender roll, install coils, install LCAs/trailing arms, studs, set up, etc) and i dont have a garage or enough spare time to get it done reasonably as the car is my DD.
i ended up buying a 2nd set of hubs to have the studs installed into and then put on the car. It saved us from the efforts of extracting the old studs and installing the ARPs. It is definitely the more expensive route (almost $600 for new OEM hubs) but it was easier, took less labor time and now i have a spare set of hubs (14k miles on them) that i can do whatever i want with.
My understanding on replacing the studs is it is basically a 1 day job, less if you or someone helping you has done it before. I got a few quotes to do the work and they started at 5 hours of labor. The fronts are easier than the back. There is a method laid out in the forums where you can do the rears through a bolt hole one at a time but you have to grind down the head of the studs a bit to fit it through the hole. Call it a moderate job, nothing too tough but time consuming, repetitive, etc.
Old 04-26-2014, 06:53 PM   #3984
04ts
Member#: 57517
2010 Impreza WRX Ltd
Satin white Pearl
04ts is offline   Reply With Quote
Old 04-27-2014, 01:00 AM   #3985
Studmike02
Member#: 220095
Friend's wheel
Enkei RC-T4 by Mjbrownell02, on Flickr
Studmike02 is offline   Reply With Quote
Old 04-27-2014, 01:24 AM   #3986
dirtcrazy
Member#: 220831
2000 Impreza RS Sdn
Drk Blue
Enkeis on Old skool:
dirtcrazy is offline   Reply With Quote
Old 04-27-2014, 08:16 AM   #3987
bassler
Member#: 167544
'12 DGM STi sedan
Originally Posted by Studmike02 View Post
Friend's wheel
Love these, definitely on my short list for my next set
Old 04-27-2014, 09:10 AM   #3988
TarmacDaddy
Member#: 327056
2016 STI
CWP
Friend's wheel Enkei RC-T4 by Mjbrownell02, on Flickr
My favorite enkei wheels of all time
Old 05-01-2014, 05:19 PM   #3989
dreamwonder
Member#: 336133
2013 WRX
I got some Kojins incoming. Will post pics. I believe I am the first and only with this configure .
5x100 18x9.5 +45mm
Left side silver.
Right side black.
Federal 595 RSR 265/35/18
Hoping that it clears my front goldie brembos.
dreamwonder is offline   Reply With Quote
Old 05-01-2014, 05:43 PM   #3990
Let's Spool
Member#: 253231
2009 WRX Sedan SWP
1999 Legacy WarWag
^^ Judging by the 18x9.5 +38 rpf1s/ +40 nto3 needing 10mm spacers with brembos and the 5x114 kojins coming with a +30 offset, I'm going to guess they most likely wont...
I'd pm this person to see how much room they have...
Originally Posted by ksantarina View Post
Got these bad boys installed. No good pics, just iPhone stuff but I'm in love with her all over again. The concave on these is INSANE. Also big shout out to Ryan over at @moddiction for hooking me up!
Specs:
18x9.5 + 30 Enkei Kojins
245/40/18 - slight stretch with these
Stock struts, Epic springs (replacing with bilsteins + yellows soon)
Rolled rears (no rubbing!!)
Let's Spool is offline   Reply With Quote
Old 05-01-2014, 05:55 PM   #3991
shippy1
Member#: 7070
Originally Posted by D S WRX View Post
New wheels mounted!! Enkei TSP6's in Hyper Silver, 18x8.5 +45 wrapped in stock STi Dunlops 245/40/18
more pics please.
shippy1 is offline   Reply With Quote
Old 05-01-2014, 08:02 PM   #3992
-Rizzo-
Member#: 338724
2014 WRX Hatchback
World Rally Blue
I've looked at these for my 14. I assume they fit your car no problem. Has anyone run these on the 11 and up hatch
-Rizzo- is offline   Reply With Quote
Old 05-01-2014, 08:05 PM   #3993
-Rizzo-
Member#: 338724
2014 WRX Hatchback
World Rally Blue
Never mind found one with those wheels. Guess I'll ask how many people are running them on the 11 to 14
Old 05-01-2014, 08:37 PM   #3994
ZTSTI
Member#: 358679
2004 WRX STI
World Rally Blue
ZTSTI is offline   Reply With Quote
Old 05-01-2014, 09:15 PM   #3995
Bellipotens
Member#: 380646
2015 WRX Premium CVT
Enkei TSP6 Gunmetal 18x8 +35 with 235/40/18 Michelin tires
Bellipotens is offline   Reply With Quote
Old 05-01-2014, 10:25 PM   #3996
04ts
Member#: 57517
Satin white Pearl
Old 05-01-2014, 10:51 PM   #3997
dreamwonder
Member#: 336133
2013 WRX
Wheels came in today. Did a quick test fit. looks like its gonna clear with a 3mm to 5mm spacer. Hoping I just need to do 3mm.
Old 05-02-2014, 01:11 AM   #3998
jdmSpecC760
Member#: 151598
04 Flared STi
IG: @dallas_dunn
Limited white 18x9.5 +40 with 10mm spacers up front for the brakes. With 255/35/18 nitto NT05s
jdmSpecC760 is offline   Reply With Quote
Old 05-02-2014, 01:39 AM   #3999
cannon98
Member#: 187775
16 Sti
CWP
Originally Posted by 04ts View Post
These wheels ... So much win... Need To make these available again stateside
cannon98 is offline   Reply With Quote
Old 05-02-2014, 02:33 AM   #4000
JourdanWithaU
Member#: 146287
2011 Impreza WRX 5D
Satin White Pearl
Some glamour shots...
17x9+45 255/40/17 Direzza ZII
JourdanWithaU is online now   Reply With Quote
The Official Wheel Thread. Teh Legacy Legacy Forum 33 10-30-2016 03:14 PM
The wheel thread aakrusen Member's Car Gallery 94 03-08-2016 07:35 PM
The Colored Wheels Thread WRXSIG Member's Car Gallery 2882 03-08-2015 05:34 PM
The BBS Wheel Thread CTI-Distributing Wheels/Tires 7 02-17-2005 08:23 PM
The Gold Wheel Thread adam555 Member's Car Gallery 39 03-05-2004 02:15 AM
