Welcome to the North American Subaru Impreza Owners Club Friday May 24, 2019
Old 09-26-2018, 09:37 AM   #576
KeithS05RS2.5
Member#: 306422
2005 Impreza 2.5RS
Dark Blue
HA! Would never have thought to remove the abs sensor to do that. Good stuff.
KeithS05RS2.5 is offline   Reply With Quote
Old 10-24-2018, 07:10 PM   #577
remski
Member#: 151895
So.. seems weee have been neglecting the thread...
Good news..
TIC came through and made things right. Got a set of longer and thiner helper springs for free.
Thats what you call a proper customer service.
Front studs looking shiny.
Rear spacers installed. Here is comparison.
vs
Old 10-24-2018, 07:10 PM   #578
remski
Member#: 151895
Next up was the cam replacement.
This was just for peace of mind.
Patient is ready. Decided to do in-car change as sourcing an engine lift would have only complicated the procedure.
Drivers side was first. Old cams actually looked very good.
My "Clean room".
New cams are in. Lobes are thiner than the previous 6x part.
Used the vendor supplied assembly lube, which looked like was a molly paste.
Few days later it was time for the passenger's side.
This is the side that had the scoring.
Always photograph all the timing marks !!!
Crappy gates racing belt leaves blue residue on the bearings.
They never align perfectly but those timing lines on the belt make things so much easier.
Something different for a change.
Went to a local car show.. and this was the coolest diesel truck i've seen.
Talk about creativity and attention to detail.
Another car show.. Few skylines inside and seats made from old drag slicks.
Old 10-25-2018, 05:38 AM   #579
Hyper
Member#: 15822
1999 WRB GM6
2.34 LR destroker
so you just swapped cams without measuring the clearance?
also I see you are running chase bays ps can, if that thing is non-baffled I would ditch it, I had a lot of issues with mine which eventually killed my pump
Hyper is offline   Reply With Quote
Old 10-25-2018, 05:38 AM   #580
Hyper
Member#: 15822
1999 WRB GM6
2.34 LR destroker
double post
Old 10-25-2018, 12:01 PM   #581
remski
Member#: 151895
Guilty as charged. I know its not perfect.
Old 10-25-2018, 12:52 PM   #582
Hyper
Member#: 15822
1999 WRB GM6
2.34 LR destroker
it doesn't have to be perfect but it has to be within the allowed range, otherwise you are looking for trouble
drop the valve covers once more and measure with a feeler gauge what clearances you have in there
Old 10-27-2018, 12:26 AM   #583
DoubleYouArrrEx87
Member#: 493257
Wow.. absolutely stunning..
DoubleYouArrrEx87 is offline   Reply With Quote
Old 10-27-2018, 01:51 AM   #584
JDMJNKY
Member#: 253498
05 RSTI
MURK'D
This build is very motivational. Glad I clicked on it, seeing and understanding the love pumped into this over 4yrs as reshaped the goals for my car. Truly awesome thread, build, and cast of friends.
JDMJNKY is offline   Reply With Quote
Old 11-22-2018, 08:18 PM   #585
remski
Member#: 151895
Alrighty then...
Since the master disconnect resets the cluster's shift light and I didnt feel like shelling out $150 for one that I liked. I made my own.
Right in yo face.. Green, Orange and Red.
Vipec config took no longer than 1 minute.
Now.. speaking of trophies..
Went to Daytona Subaru show.. and well.. took best of show..
And.. made a friend as well.
Old 11-23-2018, 12:58 AM   #586
JMande09
Member#: 493037
Absolutely Incredible build. I just moved from Jax in February, I wish I had seen this earlier so I could have checked it out in person.
JMande09 is offline   Reply With Quote
Old 11-23-2018, 09:31 PM   #587
Shipman
Member#: 312847
2006 WRX STi
2008 Legacy/2003 Forester
Bro, do you have an IG? I hate coming to this dead ass forum for updates.
Shipman is offline   Reply With Quote
Old 11-24-2018, 12:20 AM   #588
remski
Member#: 151895
I do, but I dont post much.
remski_remski
Old 11-24-2018, 01:15 AM   #589
Shipman
Member#: 312847
2006 WRX STi
You're the man. Gonna need you to put the updates there my guy
Old 12-08-2018, 11:25 AM   #590
GC8_4_EVER
Member#: 495008
2000 Impreza GC8
This has to be the best thing I have ever seen in my life... Thank you!
Any plans regarding the wheels or are they staying?
GC8_4_EVER is offline   Reply With Quote
Old 12-09-2018, 11:46 AM   #591
remski
Member#: 151895
Thanks.
As for wheels they are temporary.
I need to find the ones I like (Advan RG2 for the moment).. in the proper size and offset..
Old 12-09-2018, 12:55 PM   #592
GC8_4_EVER
Member#: 495008
2000 Impreza GC8
Seriously, the most inspiring project I've ever seen.
I'm not necessarily referring to the build itself which is UNBELIEVABLE, but not giving up through out all the years of hard work and difficulties!
Keep it up. It's amazing.
Originally Posted by remski View Post
Thanks.
Old 01-23-2019, 02:47 PM   #593
MGigantelli44
Member#: 234591
2004 STI
any updates? im come to nasioc just to see if this thread has been updated
MGigantelli44 is offline   Reply With Quote
Old 01-23-2019, 08:36 PM   #594
remski
Member#: 151895
Hi.
Sorry... Nothing really new. In the process of moving.
Old 04-29-2019, 07:09 PM   #595
remski
Member#: 151895
So... finally an update.
I have an imaginary tapping issue and needed to put it to rest.
Thus I had to do over the 1/2 ass job I did before.
Off to drain the radiator...
Meet the patient.
Left side was first.
And the results are in:
And the right side.
And the results are:
Right
Intake
1 - 229 - 9
2 - 203 - 8
3 - 254 - 10
4 - 229 - 9
Right
Exhaust
1 - 279 - 11
2 - 305 - 12
3 - 330 - 13
4 - 356 - 14
Left
Intake
1 - 254 - 10
2 - 203 - 8
3 - 229 - 9
4 - 229 - 9
Left
Exhaust
1 - 305 - 12
2 - 305 - 12
3 - 330 - 13
4 - 330 - 13
GSC S2 cam card says:
7 - 9 thousand for intake
9 - 11 thousand for exhaust
Some builders do prefer to run a slightly bigger lash.. (so I read)
Except that 14 on the Right exhaust #4 I dont see any issues..
Then I am not an engine builder..
Old 04-29-2019, 07:22 PM   #596
remski
Member#: 151895
After much thought I've decided to re-set the valve lash.
I found a "hidden" .0015 feeler gauge and re-did the measurments.
Now measurements we are within 0.0005" ...
Looking at the cam card I've decided to go with 0.009" lash on the intake and 0.011" on the exhaust.
With the new garage having more space, it was the first time really I got to fully utilize the cart.
That Gates "ricing" belt keeps on leaving marks..
New buckets are on order... lets hope I got my math right.
Old 05-01-2019, 05:59 PM   #597
GC8_4_EVER
Member#: 495008
2000 Impreza GC8
It's great to hear you're still looking after your piece of ART!
Looking forward to the next updates =)
Old 05-01-2019, 11:07 PM   #598
remski
Member#: 151895
Thanks
Old 05-12-2019, 09:14 PM   #599
remski
Member#: 151895
A bucket here.. and a bucket there..
and looks like we are done.
Specs call for
.008 Intake +/- .001 (goal was .009)
.010 Exhaust +/- .001 (goal was .011)
Here are the final results.
For those that are interested I found this easy bucket calculator made by some guy on Nasioc..
Here is a link to the xls.
WRX & STI Valve Clearance Calculator.xls - Google Drive
Old 05-16-2019, 10:50 PM   #600
Nohedge
Member#: 501701
wow
Nohedge is offline   Reply With Quote
