Welcome to the North American Subaru Impreza Owners Club Monday May 20, 2019
Old 04-16-2019, 03:22 PM   #126
Scuby04STi
Member#: 328635
2004 STi GTX3076R
Rally Blue
Originally Posted by PDXREALTOR View Post
I never thought about it too hard but, I think that line goes back to a charcoal canister or two and may even connect to the gas tank.
I just know i got the smell of gas after removing all that crap under the hood, and, capping that line made it go away.
There is a thread on here about deleting it all from the hood back to the tank.
Well I deleted the whole system but for reference there "should" be a breather on that line. I personally put the breather directly off the section at the rear of the car:
Originally Posted by Scuby04STi View Post
Sorry for the odd picture, it was the only one that had the breather in it that I have.
Scuby04STi is offline   Reply With Quote
Old 04-16-2019, 03:59 PM   #127
PDXREALTOR
Member#: 468393
2017 STI
If you leave the charcoal cans in place, don't they act as a breather?
PDXREALTOR is offline   Reply With Quote
Old 04-16-2019, 04:45 PM   #128
Turpid Porpoise
Member#: 476573
2008 Impreza WRX STi
Not that I’m aware of, they are just the “filter” for the evap system. The line to your intake manifold was the only vent and is now capped off. I just ran a 5/16 fuel line from the hard line down to the frame rail just above the front control arm. That way the pressure vents under the engine bay and gets pulled out under the car
Turpid Porpoise is offline   Reply With Quote
Old 04-16-2019, 05:16 PM   #129
Scuby04STi
Member#: 328635
2004 STi GTX3076R
Rally Blue
No, they use that hose you capped off to breath. The canister is to minimize the smell of fuel. Thank you EPA, lol. You can leave them on, take them off it doesn't matter just make sure the fuel tank has some type of vent connected to it.
Old 04-16-2019, 05:17 PM   #130
Waddlz
Member#: 395275
2012 STi
if you remove that/cap it. will that stop the "not able to fill tank all the way up" problem? I have all my OEM stuff still but currently the pump clicks off at right above 3/4 a tank
Waddlz is offline   Reply With Quote
Old 04-16-2019, 05:24 PM   #131
Turpid Porpoise
Member#: 476573
No, it is most likely not a solution to your issue. Deleting the Evap system can cause issues with filling up if done incorrectly.
Old 04-16-2019, 05:41 PM   #132
Waddlz
Member#: 395275
2012 STi
ah ok. just curious.
Old 04-17-2019, 09:32 PM   #133
PDXREALTOR
Member#: 468393
2017 STI
Thanks guys. I suppose the obvious answer to why would I want to vent the tanks is, BOOM. Also I guess there are vacuum issues that could become problematic
I keep my car in the garage which is finished and doubles as my gym, so venting it is kind of a PITA, no matter where the vent is.
The smell of fuel is annoying while working out. I don't have any issues while filling up.
Edit - I've never had a problem filling up, or with fueling, or anything else while having that line capped. I did read for quick second how pressure or vacuum could be problematic, but I've had that capped for months without issue. Even so, I removed the cap just in case.
Old 04-25-2019, 04:23 PM   #134
PDXREALTOR
Member#: 468393
2017 STI
I think my gauge and its included relay will work for map switching without adding any relays.
Here's the diagram I came up with - where should I put the ground off the TGV? Does the rest look OK?
ETA - I just tested the gauge and its fail-safe relay (as wired in the diagram below) with a 9 volt battery. Seemed to work as it should - put the gauge in fault mode and I get 0 volts - put the gauge in non-fault mode and I get 9 volts.
I think adding in a fuse on the 5 volt input line to the ECU is a good idea.
Now I just need confirmation on where to put the ground off the TGV plug...??
Old 05-12-2019, 08:37 PM   #135
brecks
Member#: 435142
2004 STi
Java Black Pearl
Hey PDX, what made you decide to copper coat the OEM gaskets?
brecks is online now   Reply With Quote
Old 05-13-2019, 08:06 PM   #136
PDXREALTOR
Member#: 468393
2017 STI
Builder does it.
