Welcome to the North American Subaru Impreza Owners Club Sunday June 24, 2018
Old 02-08-2018, 03:51 PM   #1901
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
What's A Head Gasket?
Originally Posted by Speed Assault View Post
Thank you and for offer.
, I need to find the 2018 rules
I think I reached the point of question , Do I continue with this 08 or bump to a 2010 sti or 2012 WRX
The 08 is at a disadvantage to the later cars with bigger fenders. The later cars have better turbos too.
Old 03-11-2018, 01:42 AM   #1902
MO REX
Member#: 52583
2002 WRX sedan ej207
I havenít attended an event in quite some time but the last time I did I was in SM. I have done a few things to my car and assumed I would be in SM but now Iím not so sure. Didnít have time to read all 77 pages so I apologize if this has been answered already.
Here is what I have purchased or already done to my 02 WRX since running an event classified as SM.
V8 ej207 (to be e tuned with Grimmspeed 3port EBC)
4.444 5mt
Whiteline roll center kit (shipped)
H6 rear rotors and caliper bracket (shipped)
Immediate plans depending on answers I get here.
ALK
Front control arm bushings
Whiteline adjustable rear control arms
Whiteline trailing arm bushings
Whiteline rear toe lock
TIC Unabomberís sexy rearend
Whiteline trans crossmember bushings
Beatrush Propeller Shaft Mount Bushings
Kartboy pitch stop
I bought the bugeye new and decided to drop a s***load into it rather than having a car payment. Are any of these things not SM legal like the roll center kit, ALK or ej207? Iím not thin skinned so Iím willing to take criticism on my parts selection. I donít claim to be an expert so tell me if anything on the list is a waste of money.
MO REX is offline   Reply With Quote
Old 03-11-2018, 03:28 AM   #1903
MO REX
Member#: 52583
Did a little more searching and found that subydude is running a 207 and an alk is not legal so I guess Ill just go with poly bushings rather than the alk. Still open to suggestions though. The post I was reading was 10 years old so if something has changed let me know.
If I could just sneak the alk passed the tech inspector I would dominate SM. LOL!!!
Old 03-11-2018, 08:47 AM   #1904
101rs
Member#: 38124
2000 Impreza RS
BRP
Your right on both points, the engine is pretty much unlimited. And the ALK is illegal, but you'd probably get away with running at local events.
Everything else looks good.
101rs is offline   Reply With Quote
Old 03-11-2018, 11:14 AM   #1905
subydude
Member#: 80649
Just an FYI, I've switched to an EJ257 but am still using the EJ207 heads. You can get most of the benefits of the ALK by using offset bushings.
Old 03-11-2018, 12:39 PM   #1906
MO REX
Member#: 52583
Thanks guys. Looks like I’ll go with the offset bushing. I’m guessing I’ll get the same caster as the ALK without the change in anti-lift. I’ve been reading through this thread and have a better understanding of the rules now. Can’t wait for the first event of the year. I got a safe tune on the 207 right after the last event of last season. Curious to see how it does. Hoping to not end up last in SM.
Old 03-11-2018, 12:50 PM   #1907
subydude
Member#: 80649
You'll get close to the same caster.
The EJ207 is a great engine and while it doesn't make the torque the 2.5 does you can still be pretty competitive with it. Just don't go big on the turbo if you swap. Autox is all about 3,500-6,500 RPM power. Also get a better oil pan on it. I lost the bottom end on mine because of oil starve at a track day that would have been solved with a better oil pan.
Old 03-11-2018, 02:30 PM   #1908
MO REX
Member#: 52583
Ive never been a fan of large turbos since Iíve always had a 2.0 I actually asked the guy that did my swap about running a different pan and he said I didnít need one. I think you had a v7 and I have a v8 so not sure if they have different oil pans. I donít think they do so I may have to look into that since my local track has a banked oval at one end.
A 257 with 207 heads sounds like a great combo.
Thanks for the advice
Old 03-11-2018, 03:21 PM   #1909
T-37
Member#: 175624
0304 WRX WRX
SY WRB
It's easy to check. If you have the square pan you should change it to the STI v-shaped pan (and put on a Killer B pickup while you're there.)
Old 03-11-2018, 03:52 PM   #1910
MO REX
Member#: 52583
Pretty sure it’s more v shaped but not at home to check. Saw a post by subydude in another thread that said the v8 has a better baffle than the v7. Getting ready to do the brakes on Thursday so I’ll take a look when I get it on jack stands.
Old 03-11-2018, 09:03 PM   #1911
subydude
Member#: 80649
The later pan is better for sure and is fine for the odd track day or autox. I had the square pan on my V7. I like the killer b pans for the extra capacity though and if you get to big r comps it's worth it to have the extra oil. The pick up is more important IMO, but both together are best when staying with a wet sump.
Old 03-11-2018, 11:26 PM   #1912
MO REX
Member#: 52583
Im all about spending a little to save a lot. I found a killer B kit with pan and pick up for $688. Ill make sure to do that before my next track day and throw some new motor mounts in while I’m at it if the swap didn’t include group N mounts. A dry sump would be nice but I never do more than 1 track day a year and my local track isn’t too crazy. I usually take it relatively easy through the banked oval portion. I don’t mind risking going off in the infield but don’t want to end up in the wall.
Don’t think Im going to attempt pressing the offset bushings into the control arm. Gonna leave that to someone with a press.
Old 03-12-2018, 06:43 AM   #1913
subydude
Member#: 80649
Harbor freight presses are cheap and work well. I just pressed some control arm bushings a week ago with my HF 12 ton
Don’t worry about the dry sump.
Old 03-12-2018, 11:18 AM   #1914
Thorium06
Member#: 254372
The Killer B pan is absolutely worth the insurance. I have personally starved at an autox with an overfilled STi pan with the Killer B pickup and baffle. Several others in our region have also starved with the STi pan. I wish I could go to a dry sump..
Thorium06 is offline   Reply With Quote
Old 03-12-2018, 12:25 PM   #1915
subydude
Member#: 80649
I've seriously considered a dry sump, but there's not a lot out there that's not already more than a new engine. It's definitely better than the wet sump pan though, and if I were going on track with the car hard core I'd likely do it.
The killer b with a IAG AOS that drains back seems to keep things in check though for me.
Old 03-12-2018, 12:36 PM   #1916
Thorium06
Member#: 254372
Yup, I have the same setup on mine now. Have not starved since lol
Old 03-12-2018, 09:58 PM   #1917
smoky
Member#: 221439
2004 STI
Say hello to my new friend:
Can't wait to see how it will perform on E85
smoky is offline   Reply With Quote
Old 03-12-2018, 10:11 PM   #1918
Homemade WRX
Member#: 33782
96 3MI Racing LLC
search FIRST, then PM!!!
New G-series....NICE!!
Makes me want to trade all of my EFR turbos.
Old 03-12-2018, 10:13 PM   #1919
Leafy
Member#: 330625
2006 WRX
We'll see how it performs in transients.
Old 03-12-2018, 10:34 PM   #1920
subydude
Member#: 80649
It's pretty. I don't think I'd switch, but I think it'll push BW to do more updates since Garrett basically mimic'd them.
Old 03-13-2018, 08:18 PM   #1921
smoky
Member#: 221439
2004 STI
I was running a very old HTA68 with a 10cm hotside and EWG, should make a good upgrade! Original winter plan was to buy a BW, but since they just released it, let's try them out. Probably still 2-3 month before it's in the car, I'm late on my rebuild this winter, but I'll post result once it's done.
Old 03-13-2018, 10:15 PM   #1922
subydude
Member#: 80649
550 or 660?
Old 03-14-2018, 03:25 PM   #1923
AustinTX
Member#: 23954
06 STU STI
'15 BRZ
Thoughts on the Moroso pan and pickup? Is Killer B the only choice?
AustinTX is offline   Reply With Quote
Old 03-14-2018, 04:07 PM   #1924
Thorium06
Member#: 254372
Does the Moroso fit with your Killer B header? if not, than there is your answer.
Old 03-14-2018, 05:17 PM   #1925
AustinTX
Member#: 23954
06 STU STI
'15 BRZ
I can't seem to find an answer to that. Do you know?
Will my trans swap put me automatically in Street Mod? RebelINS Autocross 6 07-22-2013 05:24 PM
I'm still legal for Street Mod right?(list inside) Davenow Motorsports 4 05-24-2003 03:21 AM
street mod tire question Jaxx Motorsports 2 02-20-2003 07:59 PM
Autocross class... Street Mod? Motohead1 South East Region Forum 11 06-26-2001 10:11 AM
Street Mod news Eric Technical Forum Archive 5 05-31-2000 02:33 PM
