Welcome to the North American Subaru Impreza Owners Club Friday June 22, 2018
Old 02-21-2010, 11:36 PM   #1
ncarn8
Member#: 71419
Default is brake bleed order the same for abs and non abs?
as above... i have the fsm order of
Brake fluid replacement sequence; (A) Front
right (B) Rear left (C) Front left (D) Rear
right
This is for a car with abs and tcs... so is it the same for my car? i have the braking system from a 1999 wrx sti ra that has no abs. just a 4 port master cylinder and the distro block.
So do i just go ahead and bleed in the same order as the abs car?
thanks
ps have searched.. thats how i got the fsm info. thanks
ncarn8 is offline   Reply With Quote
Old 02-22-2010, 12:57 PM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Yes, bleeding sequence is the same between abs & non-abs cars.
With ABS, you may want to cylce the ABS motor a few times to get any trapped air out. Then rebleed the brakes.
Legacy777 is offline   Reply With Quote
Old 03-13-2018, 07:19 PM   #3
00_imprezaoutback
Member#: 452713
How do you cycle the abs motor?? I just put new front left and right rotors, pads and calipers and tried to bleed but nothing came out of the front right. Yes the calipers are on the right side the bleeder valve is on top. I just canít seem to get any fluid out. Btw itís a 2000 Legacy Outback 2.5l w/ABS. Also the abs light has been on for a while now not sure why thou. PLEASE HELP NEED CAR FOR WORK TM AT 5:30am lol
00_imprezaoutback is offline   Reply With Quote
Old 03-13-2018, 08:06 PM   #4
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
https://mnsubaru.com/threads/how-to-...r-bleed.39415/
remove the bleeder, make sure it has holes.
yarrgh is offline   Reply With Quote
Old 03-13-2018, 10:35 PM   #5
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
Originally Posted by 00_imprezaoutback View Post
How do you cycle the abs motor?? I just put new front left and right rotors, pads and calipers and tried to bleed but nothing came out of the front right. Yes the calipers are on the right side the bleeder valve is on top. I just can’t seem to get any fluid out. Btw it’s a 2000 Legacy Outback 2.5l w/ABS. Also the abs light has been on for a while now not sure why thou. PLEASE HELP NEED CAR FOR WORK TM AT 5:30am lol
You shouldn't need to cycle the ABS pump just to bleed a caliper.
If you wanted to do a full fluid flush, some scanners can do it, good shop scanners can do it, crude is to go on a wet road, snow, gravel and hit the brakes hard.
But, as stated, just bleeding a,caliper shouldn't need to cycle the pump.
Great point. I have not had that issue, but similar ones that are easy to just skip over.
Crappy short term alternative is to bleed through the banjo bolt.
Is the starter the same for Impreza and Impreza Outback Sport? Ptero Service & Maintenance 2 05-28-2010 06:32 PM
Is E85 really not the same blend everywhere and not regulated by the government? Red Rexx General Community 48 01-02-2009 01:47 AM
is the foglight relay the same for jdm and usdm fogs? steve Electrical & Lighting 2 04-01-2006 10:24 AM
are the roof rails the same for wrx and forester? SacWagon Impreza Forum 4 02-04-2004 10:50 PM
Difference between ABS and non ABS Brake Lines? AKGC8 Brakes, Steering & Suspension 1 12-30-2002 09:24 AM
