Welcome to the North American Subaru Impreza Owners Club Monday September 24, 2018
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Services
Old 02-26-2018, 09:36 PM   #1176
Infamous Performance
Vendor Sales Rating: (7)
Member#: 275060
A 2011 WRX rolled into the shop today with smoke coming out of the tail pipe and the oil fill neck/dipstick. 18,740 original miles on the odometer. Living the Subie life can get expensive. Cylinder 2 and 4 are both in the 65-70psi of compression range now.
__________________
Infamous Performance is offline   Reply With Quote
Old 02-27-2018, 01:21 PM   #1177
Member#: 275060
Not quite a snow day. But, So Cal cold... hail storm at the shop this morning. We had most of the cars inside before it started to fall. The thunder gave us warning.
__________________
Old 02-28-2018, 12:39 PM   #1178
Member#: 275060
A bad week for low compression banks on EJ255 engines. This 2007 Legacy GT SpecB came in on a tow truck. Car was in a drive through when it stalled and would not start. Skipped the timing belt (118k and the tensioner was a re-used original). Zero compression in cyl #1 and #3 once we reset the timing to test.
New owner of the car. Supposedly the head gaskets were recently replaced. We see the signs of poor workmanship and low cost parts along with the re-used OEM timing kit. I attribute the failure to the previous work. Wonder why the previous owner put the car up for sale???
Its a buyer beware world, we do offer pre-purchase inspections.
__________________
Old 03-01-2018, 10:43 PM   #1179
Member#: 275060
2012 WRX put back to stock today (approx 90k). GS TMIC, Forge BPV, GS mstr cyl brace, Crawford AOS, GS 3 port EBCS, TurboXS down pipe, GS heat shield, Greddy CBE, Brembo front brake kit, Stoptech brake lines (all 4 corners), Cobb AP, Tein coil overs and more removed and replaced from this car today. Soon to be sold/traded in. A local owner left with a boatload of used aftermarket parts that should be hitting the "for sale" scene soon.
__________________
Old 03-02-2018, 11:14 PM   #1180
Member#: 275060
Performed a timing belt service on this 2008 STi today. A standard timing belt service at Infamous Performance consists of:
Replacement of the timing belt, tensioner, idler pulleys, water pump, thermostat and a coolant flush. Service is recommended between 100-110k miles. We use all OEM components and fluids and the price is $800 parts and labor out the door.
__________________
Old 03-07-2018, 09:44 PM   #1181
Member#: 275060
Today at the shop... Steve Gerhardt on the dyno tuning a MONSTER STi. Steve will be back tomorrow to complete this tune. So far Steve is up to 20psi (and north of 300whp/tq on the Mustang) and expecting to hit 32psi on ACN91 pump gas. Stay tuned...
__________________
Old 03-08-2018, 11:03 PM   #1182
Member#: 275060
A 2013 STi that was in today for a boost leak. Found it, fixed it and the car is back on the road with its rightful owner.
Gotta get back to the dyno, the monster STi needs a new oil control valve on one exhaust cam. It went "haywire" this morning on the dyno causing us to stop tuning. Cant risk having the cam advance far enough to make the valves contact the piston. Big cams and valves and we dont want to go over 40-42deg of advance. Plus the oscillating cam was causing the AFR to change. We should be back in business tomorrow morning and continuing with the tune.
__________________
Old 03-14-2018, 12:01 AM   #1183
Member#: 275060
3 generations of STi in the shop being worked on today. 2015, 2012, 2007. The 2015 is being tuned (flex fuel) by Bill Knose on the dyno tomorrow. The 2012 is a continuing tuning project with Steve Gerhardt. Steve says, "it takes time to get to 42psi". Yup, but your already making 330whp at 15psi, lol.
__________________
Old 03-14-2018, 11:50 PM   #1184
Member#: 275060
2015 STi. Stock turbo and TMIC (and clutch). Flex fuel supplied and tuned by Delicious Tuning (Bill Knose). The dyno graphs and the car. Very nice numbers on our heart breaker Mustang, especially with the stock clutch. 309whp, 407wtq on e60.
__________________
Old 03-15-2018, 01:48 PM   #1185
Member#: 275060
If you can hear the throw out (release) bearing, its time to address the situation. If you can feel the throw out (release) bearing you are playing with fire. If you drive the car until the entire assembly grenades, you get to replace the transmission. Not enough snout left in this 2013 WRX to even attempt a repair. Not a good day for anyone involved.
__________________
Old 03-20-2018, 10:11 PM   #1186
Member#: 275060
This 2008 WRX came in with a seized turbo. No wonder... 190k original miles on the clock. Single owner who obviously took care of the car and never hits boost. Thats how you make a Subie last. Engine over heated and took out the head gaskets prior to 40k miles. Dealership performed the warranty. Otherwise all original and original turbo with 190k. One of the rare turbo Subies to make it past 150k without needing a MAJOR repair/rebuild. Thanks to Pure Turbos for the fast turn around on the rebuilt turbo. The car is now back in the hands of the loving owner.
__________________
Old 03-21-2018, 11:34 PM   #1187
Member#: 275060
Preparing this 2007 STi for return to the customer. 60k service, new South Bend stage 2 clutch, new Invidia catted down pipe installed. Possibly going on the dyno for a custom tune prior to be returned. Where to find a clean 2007 STi with under 60k on the odometer???
__________________
Old 03-23-2018, 12:02 AM   #1188
Member#: 275060
This 2002 WRX is almost ready for pick up. So far we have performed a compression test, replaced the coils, replaced the fuel filter, replaced the fuel pressure regulator, performed a timing belt service, replaced the clutch and are now going to replace the valve cover gaskets.
150k miles on the odometer. All original. Another keeper.
__________________
Old 03-23-2018, 09:38 PM   #1189
Member#: 275060
Replaced the clutch on a 2015 BRZ today. When the car came in from the sound the release bearing (throw out bearing) was already seized. Once we removed the transmission the suspicion was verified. 60k miles on the odometer. Clutch disc still had life left in it. Release bearing is destroyed. Transmission snout survived.
Dont risk irreparable damage to your transmission. Get your clutch replaced before it is 100% gone.
__________________
Old 03-27-2018, 12:05 AM   #1190
Member#: 275060
60k mile scheduled service completed on this 2014 WRX today. We offer competitive pricing, fast turn around and top quality parts/fluids for all your standard Subaru service needs.
__________________
Old 03-27-2018, 09:07 PM   #1191
Member#: 275060
Break in driving has begun on the fresh rebuilt engine in this 2007 Legacy GT SpecB. This car should be ready for customer pick up tomorrow or Thursday. Another dead turbo engine back on the road, stronger than it was before.
__________________
Old 03-30-2018, 08:26 PM   #1192
Member#: 275060
All of us here wishing you and yours a Happy Easter!
__________________
Old 04-02-2018, 04:30 PM   #1193
Member#: 275060
Something different today. Very different. 2013 AMG CL 63. The car belongs to another local shop owner. We performed baseline pulls today for comparison. Next up is pulls with the custom tune.
With the car making 600lbft of torque on the Mustang dyno in stock form, you need more??? No, but you want more. LOL.
Expectation from the new tune is +100whp over stock. If you too have over $150k to play, you can get this performance stock. The tune is another $3k.
__________________
Old 04-04-2018, 09:53 PM   #1194
Member#: 275060
This 2013 BRZ went for its first drive on the fresh engine today. Outfront Motorsports closed deck block, OEM crankshaft, King Performance bearings, CP pistons (12.5:1), Carrillo rods, ARP 1/2" head studs, Custom JE Proseal head gaskets, JDM oil pump internals, Supertech valves and springs, Jackson Racing C38 Supercharger with the small (hi boost) pulley, Delicious Tuning Flex Fuel kit and Tune (and more mods too). This car should be ready for customer pick up on Friday.
__________________
Old 04-06-2018, 11:59 PM   #1195
Member#: 275060
We went to replace the serpentine belt on this FRS. The v-band clamp on the JDL headers was at an interesting angle. We had to reposition the clamp in order to replace the belt (and for good measure) as it was too close for comfort.
__________________
Old 04-10-2018, 06:48 PM   #1196
Member#: 275060
We have been seeing a lot of these lately. 2008-2010 WRX (and occasionally an STi as well) with broken firewall spot welds. We have plenty of experience fixing the firewall, but now a new twist on the old problem. The pivot tube for the pedal assemblies are cracking. We have had to replace 3 in the past month all with the exact same crack. FYI, if you hear it "squeaking" rather than "popping" it is most likely the pedal assembly pivot tube.
__________________
Old 04-10-2018, 07:23 PM   #1197
redrex009
Member#: 337456
2009 wrx
lightning red
I'm currently dealing with this on my 09
redrex009 is offline   Reply With Quote
Old 04-12-2018, 07:36 PM   #1198
Member#: 275060
Unfortunately, an all too common occurrence.
Completed a decent amount of maintenance and repairs on this 2008 WRX this week. Next stop... they dyno. Steve Gerhardt (formerly of 7L Autosport) will be providing the tuning services on our in house Mustang dyno tomorrow.
We are now officially offering pro tuning services with Steve Gerhardt. Appointments available M-F.
__________________
Old 04-13-2018, 11:56 PM   #1199
Member#: 275060
Busy Friday at the shop. Steve was working on the dyno most of the day. Hope you have a great weekend! Personal projects this weekend, so we will be back to customer cars on Monday.
__________________
Old 04-16-2018, 11:17 PM   #1200
Member#: 275060
Completed a head gasket replacement on this 2008 Outback today. Car should be ready for customer pick up tomorrow.
__________________
PTUNING Service Thread -- Tuning, Alignments, Installs, Clutch Packages, Servicing! Ptuning.com MAIC Vendor Classifieds 6 10-31-2011 12:14 PM
