Welcome to the North American Subaru Impreza Owners Club Monday September 24, 2018
Old 07-07-2002, 03:07 PM   #1
Shag-e
Member#: 8168
2013 WRX Limited
Default any help? how do you install a rear swaybar where one never existed?
I have a 1997 Impreza Brighton and the car doesn't come with a rear and probably not a front swaybar.
I was wondering how difficult it would be to install an RS sway bar.
Anyone have experience or advice?
thanks
Shag-e is offline   Reply With Quote
Old 07-07-2002, 03:39 PM   #2
DjRez4
Member#: 18155
1985 4runner
AWD Pirates, Unite!
I'm pretty sure MRT sells kits to install swaybars on cars that didn't come with them from the factory. check out http://www.mrtrally.com.au/performance/ ....it's in there somewhere.
DjRez4 is offline   Reply With Quote
Old 07-07-2002, 05:14 PM   #3
Shag-e
Member#: 8168
2013 WRX Limited
looked but couldn't find anything.
Old 07-08-2002, 01:33 AM   #4
Kostamojen
Member#: 2272
2017 GTI/1999 OBS
Digital Desert Camo
Ive done it on my 95.
Note: We DO have front sway bars, same as the RS in fact.
But for the rears you need to get:
2 Endlinks
Swaybar
2 swaybar mounts to mount to the chasis
bolts to bolt the endlinks to the swaybar and control links...
And, the Control links themselves, which are THE hardest to find out of all the stuff... You have to get some from an RS or some newer Impreza that actually has the control links with the mounts for the endlinks to bolt into (Control links are the little o-----o part that connects the suspension together). I got these used at a salvage yard for $70... Everything else I got for free exept the WRX wagon sway bar ($40) and some of the bolts they didnt have at the recycler yard... (like $2-3 each at a Subaru dealer)
If you actually find everything THEN ask how to do the install Its really not that hard btw.
Old 07-08-2002, 03:52 AM   #5
DjRez4
Member#: 18155
1985 4runner
AWD Pirates, Unite!
well they used to have stuff on MRT....if you want, i'll send you my WRX wagon sway bar. just pay shipping and it's yours
Old 07-08-2002, 11:23 AM   #6
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
If you are really going after a low cost but well performing I suggest the following recipe.
Whiteline adjustable sway bar
Whiteline "heavy duty" mounts
Whiteline end links
Mrt Adjustable lateral links
Home Depot Bolts
My Legacy had a rear sway bar but the mounting points on the rear lateral links were a pin type. The 92+ legacy uses the normal type so I could have found used lateral links from them.
But lets see, you pay about 200 for used links or 250 for fully adjustable links? You can see why the MRT option is far better. Especially since you now have rear CAMBER and TOE settings! Plus the MRT models come with brand new bushings.
ciper is offline   Reply With Quote
Old 07-08-2002, 01:10 PM   #7
DoinkMobb
Member#: 3787
2008 Gay
Car
Yeah I've been wondering about the rear swaybar too. What kind of effect would a good sized rear swaybar have on a FWD Impreza? Better turn in? Looser back end?
I was planning on getting a Whiteline rear strut tower bar also. The body roll is pretty bad going around even mildly sharp corners.
DoinkMobb is offline   Reply With Quote
You got the "200" STI 6speed swap lists now, how do you install? wrx03.4wz Transmission (AT/MT) & Driveline 9 07-16-2009 11:32 AM
How do you install rear upper spoiler on obs??? hunter15 Interior & Exterior Modification 10 01-30-2008 12:26 PM
ok, this may sound dumb, how do you install a cusco rear strut tower brace? 1WikdWRX Brakes, Steering & Suspension 2 05-22-2003 06:14 PM
('93-'01) how do you search for old posts??? where is the search key?? RimRockaz Impreza Forum 7 06-15-2001 10:09 AM
How do you install a rear strut tower bar in the wagon? Bahumut Technical Forum Archive 2 05-17-2000 02:41 PM
