Welcome to the North American Subaru Impreza Owners Club Sunday November 18, 2018
Old 07-14-2018, 07:12 PM   #30726
von Wachtstain
Member#: 52726
Does anyone know what P2270 code is? Just got it today. Second time already this year I get check engine light. 2015 Subaru Impreza 2.0.
Edit. In case somebody else have the same problem. Part number is 22690AA960 (fuel air ratio sensor)
von Wachtstain is offline   Reply With Quote
Old 07-14-2018, 08:31 PM   #30727
theoutbackdream
Member#: 301179
2013 WRX Limited
Yea, here you go.
theoutbackdream is offline   Reply With Quote
Old 07-14-2018, 09:18 PM   #30728
von Wachtstain
Member#: 52726
Originally Posted by theoutbackdream View Post
It mostly leads to Impreza STI
Old 07-14-2018, 09:23 PM   #30729
Commander Keen
Member#: 319157
2012 Impreza 4DR 5MT
Make/model doesn't matter.
Bank 1 sensor 2 stuck lean.
Your post-cat O2 sensor isn't producing voltage. Either it's dead, the wiring is damaged or you have a significant exhaust leak.
Commander Keen is offline   Reply With Quote
Old 07-24-2018, 08:55 PM   #30730
repsolgamma
Member#: 388569
2013 Impreza Sport
Have done much to reduce sound in my 2013 sedan, installed a oem hood liner insulation pad from a later model that made a huge difference in sound in the cabin.
Tell me more about the blower cover mod?
Thanks
Michael
repsolgamma is offline   Reply With Quote
Old 07-24-2018, 10:44 PM   #30731
Commander Keen
Member#: 319157
Motor cover is P/N: 66066FJ010
I'd call it more of a retrofit than a mod.
Traps noise originating from under the dash and firewall.
Easy installation and well worth doing in my opinion.
Old 08-06-2018, 12:18 PM   #30732
Pelco
Member#: 435599
2016 Impreza Sport
Has anyone installed an after market pitch stop? How did it affect your car? Worth it? Yay or nay? I have a CVT btw.
Pelco is offline   Reply With Quote
Old 08-06-2018, 03:48 PM   #30733
CalTech87
Member#: 348055
2013 Impreza 5MT
ISM
Noise reduced by 1/4, 1/2, dBs, wellWorths, etc?
CalTech87 is offline   Reply With Quote
Old 08-06-2018, 08:17 PM   #30734
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Im happy with my group n (full set).......quite a lot more vibration when ac kicks in at idle. not sure it made it faster or more driveable
Old 08-06-2018, 08:17 PM   #30735
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Its quieter, its not luxury car quieter, but quieter
Old 08-06-2018, 08:19 PM   #30736
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Ordered caliper rebuild stuff today, i think one of my pistons has rusted or has corrosion under the dust seal which is why it is hanging up once they are hot
Old 08-06-2018, 08:54 PM   #30737
DieselDorf
Member#: 454773
2012 Impreza Sport
Pearl White
PSA-
I used my tow hook for the first time today as a tie down for a surfboard. The threads of the hole were a little sticky/rusty. Probably not a bad idea to put some lubricant like fluid film or anti seize on them.
Probably no big deal where it doesn't get salty but in a few years I could see it getting hard to get the hook on.
DieselDorf is offline   Reply With Quote
Old 08-08-2018, 02:03 AM   #30738
Pelco
Member#: 435599
2016 Impreza Sport
Nay it is!
Old 08-13-2018, 04:16 PM   #30739
Angelus911
Member#: 89967
2012 Impreza Sport
So over the past 2 weeks or so, I've developed another clunk coming from what seems to be the rear. Last time it was the RSB, seems like the endlinks are all intact and still tight, so not sure what the issue is.
From what I've been able to notice, seems to clunk when turning left or right and lower speeds, ie turning onto a road etc. Tried to get under the car to look but had an accident that involved stairs and me missing a few, so mobility has been impaired for a little while. Any other things to check to see what it could be?
Angelus911 is offline   Reply With Quote
Old 08-13-2018, 04:37 PM   #30740
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
sway bar, other suspension things, brakes.
my car has a clunk once the brakes are hot and you press and release the brakes, currently rebuilding the front calipers, one of the pistons on the FR wheel has a decent amount of rust corrosion buildup which I am 99% sure is my clunk.
Old 08-13-2018, 10:27 PM   #30741
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
So my dragging brake issue that just started after new brakes is so far gone now that i rebuilt my calipers...........there wasnt much corrosion but 1 piston per front caliper had some corrosion inside the dust seal and i guess that was enough.
It it needs to be done again i am just buying new calipers, it isnt that it was tough because it was super easy and relatively quick, rather that there was a decemt amou r of corrosion starting and i dont have a sand blaster to really really clean them up and then powder coat them or something.
I did have caliper paint so all the bare steel is partially protected, time will tell how long.
Left = drivers side pair, right = pax side pair
Drivers side
Pax side (worst side, corrosion went 1/2 way around this piston!)
Old 08-13-2018, 10:46 PM   #30742
bruno516
Member#: 490099
Smile Hello. Possible new 2012 Impreza Owner needs advice
Hi guys. I've been in talks with the salesman for a 2012 Impreza.
I have never owned a Suburu, but my brother owns a 2017 WRX and its gorgeous and FAST.. nIm actually in the market for a new car. my CRAP 2011 Jeep Patriot gave up on me AGAIN. I came across a 2012 Impreza which is noted as "rare" as it has moon roof and navigation.
I'm planning on seeing this car tomorrow. Can you guys tell me more about the pricing on this vehicle? Is it negotiable?
Ive been wanting a Suburu for years now and I think I will pull the trigger on this one.. https://www.camelbacktoyota.com/used...c375933e9b.htm
Cheers and thanks for your time. Any PMs or replys are appreciated. I'm new to the forum as of today and hope to stay
bruno516 is offline   Reply With Quote
Old 08-14-2018, 12:06 AM   #30743
Commander Keen
Member#: 319157
Moon roof and nav aren't in themselves rare.
Those coupled with manual transmission makes it rare.
Sedan body? Even more rare.
Old 08-14-2018, 09:56 AM   #30744
Angelus911
Member#: 89967
2012 Impreza Sport
Default 2012 Impreza thread
As an owner of a 2012, I wouldn’t buy a 2012
If interested in the Impreza I would look for a 2014 or 2015, just my 2 cents
Old 08-14-2018, 12:15 PM   #30745
CalTech87
Member#: 348055
2013 Impreza 5MT
ISM
As an owner of a 2013, I love my car, but I would do the same.
Old 08-14-2018, 02:35 PM   #30746
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
As the owner of a 2012 with an engine from a 2013 I concur
Old 08-15-2018, 01:17 PM   #30747
Ladeef
Member#: 318753
2012 Impreza
Dark Grey
Not a single thing wrong with my 2012, they did iteratively make them better over the years, but you'll pay more of course. I think first model year of vehicles always have their issues however.
Ladeef is offline   Reply With Quote
Old 08-15-2018, 08:50 PM   #30748
DieselDorf
Member#: 454773
2012 Impreza Sport
Pearl White
I've hadn't nothing wrong with my 2012 so far, literally done nothing but oil changes and filters pretty much.
Those option being "rare" means absolutely nothing on an econo-box.
I wouldn't pay more than 12k for it
Old 08-22-2018, 08:42 PM   #30749
Angelus911
Member#: 89967
2012 Impreza Sport
So just hit 101k miles, going to bring my car to a mechanic next week to get a couple things done (front diff, brake fluid, check out suspension).
Anything else that is worthwhile to do at this point? Was thinking about fuel filter, if I do it now, it will probably be good til I get rid of the car at 200k+
Spark plugs were done about 40k ago, so they're probably good for now.
Old 08-23-2018, 09:49 AM   #30750
DieselDorf
Member#: 454773
2012 Impreza Sport
Pearl White
I wouldn't change your brake fluid. It isn't near old enough.
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 03:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 08:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 05:09 PM
Possibly looking into a 2011 or 2012 Impreza? xenonk Mid Atlantic Impreza Club -- MAIC 1 08-05-2010 10:48 PM
