Welcome to the North American Subaru Impreza Owners Club Tuesday January 22, 2019
Old 12-09-2013, 07:41 AM   #51
TomiT
Member#: 163135
2008 WRX STi 2008
Red
Does any other Subaru got that same 24pin radio connector??
TomiT is offline   Reply With Quote
Old 12-12-2013, 12:39 PM   #52
TomiT
Member#: 163135
2008 WRX STi 2008
Red
Well one monkey brain here!!! Unika and SWC works just fine. I find the small black stick from the unika box and I just reset the UNIKA with that stick ( Small hole in the UNIKA ) then I just bush the buttons in correct order and I hold down that last button recommend 2 seconds and now all 6-buttons work just fine from STi steering wheel
Old 02-28-2014, 10:52 PM   #53
S1000RR
Member#: 377017
2014 WRX Hatchback
Ice Silver
Bump for those who have installed the Asteroid Smart... how do you like it?
I'm torn between installing the Smart, a Nexus 7 or one of the Chinese Android-in-a-box HU's.
S1000RR is offline   Reply With Quote
Old 03-25-2014, 07:42 PM   #54
swm04a
Member#: 385050
Could you please tell me which wires on the unika you connected the ACC and IGN too? You mention in your post that you had to do that to get enough power to the UNika but I am not clear on which wires need to be connected to the ACC and IGN....?
thanks
swm04a is offline   Reply With Quote
Old 03-26-2014, 02:44 PM   #55
El Wray
Member#: 303030
2009 STI
Following this advice:
So your quickest/easiest solution (in my opinion) will be to cut the ISO connector off of the Asteroid Smart HU's harness. For the UNIKA, don't use their ISO adapter -- take the other harness with the male/female 24-pin connectors, cut off the leg with the white 4-pin plug, and make your connections to that leg (so you can leave the UNIKA's main harness intact). Then solder or crimp the Asteroid Smart's and UNIKA's wires directly to my 20-pin Subaru harness.
I cut the ISO crap off:
Then soldered whatever Unika leads were needed to the Parrot harness:
Then used female bullet connectors on svxdc's harness to make an easy connection to the vehicle harness.
El Wray is offline   Reply With Quote
Old 03-26-2014, 03:33 PM   #56
swm04a
Member#: 385050
I see that you've spliced some wires from the 4 pin Unika connector into some of the wires coming from the Parrot connector... could you please tell me which wire is which on that 4 pin Unika connector and which Parrot wire needs to be connected to which Unika wire?
thanks
Old 03-26-2014, 04:53 PM   #57
El Wray
Member#: 303030
2009 STI
It's been a long time and my memory isn't the greatest.. But I'll give it a try. If I remember correctly, all but one of the wires on the Unika harness come apart. (Pictured here)
The only wire that didn't was ground, which I cut in my case. I believe only soldered POS(red), GND(black) and IGN/ACC (orange?) from the Unika.
Old 03-27-2014, 10:58 AM   #58
swm04a
Member#: 385050
... Now I am even more confused...
I left both those plugs you just posted a picture of in the Unika box because neither my Parrot HU nor my car (2009 Forester XT) have a matching plug...?
Any thoughts? Right now I have SVDxc's 20 pin grafted into the Parrot Asteriod plug with V1, Aux1, and GND from Unika also grafted into the 20 pin plug...
Old 03-27-2014, 12:12 PM   #59
El Wray
Member#: 303030
2009 STI
I apologize, I posted the wrong harness. Please read post #40 in this thread.
I cut off the "unused" harness on the left side in the pic of the UNIKA SWC. I cut it off nearer to the unused harness, meaning I kept the 4-pin power connector intact so I had the extra cable length if needed.
Old 03-27-2014, 12:27 PM   #60
swm04a
Member#: 385050
No apology needed, If I had not missed post #40 the first time I read through then I would never had bothered you in the first place. Thanks for your time.
Old 06-13-2014, 07:50 AM   #61
heath_303
Member#: 386092
i can't get this working and its quite frustrating.
im not too sure if the harness i have does not have the right connectors on it or something. i have a subaru to iso harness, i then connect this iso harness to the unika harness, then connect the unika harness to the parrot iso harness.
i have cut the steering wheel control wire and connected it to the unika V1,and ground to unika ground, the unika powers up and the head unit can see it.
however I'm getting on signals to the unika when i try to learn the steering wheel controller only an occasional red light flash.
what am i doing wrong ?
btw without the unika harness in path the head unit works flawlessly
heath_303 is offline   Reply With Quote
Old 06-25-2014, 11:55 AM   #62
JLBaja
Member#: 137951
2006 Baja Turbo Blue
Phat Botti Tuned
Default Parrot Asteroid Smart in Baja!!
Great thread. Will probably install the Asteroid Smart in my 2006 Baja Turbo. Would really like to swap the steering wheel with WRX/STI (with controls) but this will be much more $$$$ and work.
JLBaja is offline   Reply With Quote
Old 07-19-2014, 08:25 AM   #63
Bill_O
Member#: 396702
Default plug and play harness information
hello everybody,
first of, thanks for taking the time to share and help about this amazing parrot system, I just think that it's way beyond any other car system...
I am planning to install one in a 2009 subaru sti without blutooth and just stock 6cds player.
Parrot is proposing me this plug&play harness with the unika module:
http://www.paser.it/parrot/en/find-p...roducts_id=158
what is it? do I need it extra if I purchase the SVXdc's one?
thanks a lot for your help
Bill_O is offline   Reply With Quote
Old 07-21-2014, 03:29 AM   #64
Bill_O
Member#: 396702
nobody pls?
Old 07-21-2014, 11:46 AM   #65
El Wray
Member#: 303030
2009 STI
Kinda pricey for the $30 or so, but not bad - I'd give it a shot for plug & play functionality and not having to splice/solder. You would only need one - the paser or svxdc's, not both. Plus he seems busy these days, so options are: their recommended harness, customizing your own metra harness or waiting a while for steering wheel controls.
Old 07-21-2014, 02:49 PM   #66
Bill_O
Member#: 396702
great, thanks for the tip
Old 01-07-2015, 06:28 PM   #67
subiefan101
Member#: 410395
2013 Subaru WRX STI
Default Microphone location
Has anyone installed the mic in the factory location? If so how is the reception compared to attaching on the ledge under the tach/speedo?
subiefan101 is offline   Reply With Quote
Old 01-07-2015, 09:38 PM   #68
El Wray
Member#: 303030
2009 STI
I've tried the steering column before. Got a lot of complaints about noise. I moved it to the center/ceiling and heard fewer complaints. Whatever you do scrape off their crappy two sided tape and put some of your own industrial double-sided tape.
Old 01-08-2015, 11:22 AM   #69
subiefan101
Member#: 410395
2013 Subaru WRX STI
Default Parrot Microphone
Thanks for the info. This really is a good system once it is rooted and google maps, etc. are installed. Although I did recently see at CES that parrot has a new system (RNB6) coming out that integrates carplay and andoid auto.
http://www.cnet.com/news/parrot-rnb-...unit-ces-2015/
Old 03-05-2015, 02:41 PM   #70
x10x
Member#: 411684
2005 9-2x aero
News Parrot RNB6
Wow thx for this post! It was very informative. Any of y'all waiting for the Parrot RNB6? It won best of CES this year. I'm waiting for it to be released.
x10x is offline   Reply With Quote
