Welcome to the North American Subaru Impreza Owners Club Friday January 18, 2019
Old 07-31-2018, 10:46 AM   #1
charlesbx99
Member#: 412167
Default 2.0 limited wheel size?
The stock tire is 205/50R/17 with stock rim size 17x7.5 with 48mm offset
I'm wanting to run a separate set of winter tires for the car. I want to run a 235/45R/17 and was wanting to know if I can run that size and if I can also run 17x8 with 48mm rims
charlesbx99 is offline   Reply With Quote
Old 07-31-2018, 03:22 PM   #2
DieselDorf
Member#: 454773
2012 Impreza Sport
Pearl White
That size is fine height wise, not sure about width.
Usually you want a skinnier winter tee not a fatter one.
Also I would recommend getting a smaller daimeted rim for winters they will be able to take more abuse and you won't have to pay to mount tires every season.
The stock tires are 8" wide so no issue there
Compare here. https://tiresize.com/comparison/
DieselDorf is offline   Reply With Quote
