Welcome to the North American Subaru Impreza Owners Club Wednesday July 18, 2018
Old 12-27-2013, 01:53 PM   #1151
Homemade WRX
Member#: 33782
96 3MI Racing LLC
search FIRST, then PM!!!
Originally Posted by spoolinsti05 View Post
Does the eg or ez feed two rod bearings from a main like the ej?
Same feading style as the EJ.
Old 12-27-2013, 02:10 PM   #1152
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
I see so they risk spinning bearings too when things don't play nice? huh
spoolinsti05 is offline   Reply With Quote
Old 12-27-2013, 02:31 PM   #1153
25rsti
Member#: 166324
Originally Posted by Chucktownsti View Post
Crystal_Imprezav...you have this posted somewhere...but are you running the stock crank or have you gone to an aftermarket with better oil feeds?
Pretty sure it's an after market crank. Either in the one he's running now or one of his many side/spare motors. I think Manley.
Old 12-28-2013, 04:57 PM   #1154
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
Cage work is starting tomorrow. Been trying to get the turboback exhaust fabbed in the the mean time. Tight squeeze for sure.
I have a Manley crank in the current motor. Most likely another Manley crank in the next one but i wouldn't hesitate to use a standard oem crank. New custom pistons are being made right now. In the mean time working on the heads.
Crystal_Imprezav is offline   Reply With Quote
Old 01-01-2014, 07:29 PM   #1155
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
Started on the cage. Base plates for the main hoop are fabbed as well as the main hoop. Ran out of material to mock up the roof hoop so we will get the remaining material tomorrow and hopefully finish up this weekend.
Old 01-02-2014, 09:47 AM   #1156
02WRX2.5
Member#: 63192
02 wrx
161mph Trapspeeds
Please tell me the roof hoop is not a halo bar type. So dangerous! And I don't think legal anymore.
02WRX2.5 is offline   Reply With Quote
Old 01-02-2014, 03:54 PM   #1157
25rsti
Member#: 166324
Are you using a flux core welder!?
Old 01-02-2014, 04:15 PM   #1158
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
It appears so? Harbor freight?
Old 01-02-2014, 05:45 PM   #1159
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
We were just tacking the floor box together and that was with a Miller Mig. Everything will be tig welded as it is a chrome moly cage.
Matt, not sure if I will be doing long A-Pillars or using a roof hoop. I don't think there is any rule against using one. MD05STi has a roof hoop in his cage.
Old 01-02-2014, 05:47 PM   #1160
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
Getting much better with my Tig too
Old 01-02-2014, 06:40 PM   #1161
25rsti
Member#: 166324
Nice bead. Nice and clean. What type of Tig welder you using?
Old 01-02-2014, 06:49 PM   #1162
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
Miller Diversion 180
Old 01-02-2014, 09:16 PM   #1163
norexyet
Member#: 39149
What? I'd say 90% of cars with cages run a halo with regular a pillar bars. If it were my car i would make the a pillars start at the main hoop and tie them together with a windshield bar.
What do you have going on with the floor plates? Why not use some 6x6 by 1/8th plate. Not trying to criticize just trying to offer some input as it's what I do on a daily basis.
norexyet is offline   Reply With Quote
Old 01-02-2014, 09:42 PM   #1164
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
The pic shows what I am doing with the main hoop mounting as I am building a box for them due to the floor shape/contour and the increased strength with the box.
Was going to run a-pillars to the main but the roof halo will install much tighter and cleaner to keep a more stealth look.
Old 01-02-2014, 10:23 PM   #1165
02WRX2.5
Member#: 63192
02 wrx
161mph Trapspeeds
Halo bar the weakest point is right over the.drivers head. And when it meets the a pillars it usually not at a optimal angle for a.roll over. Putting alot of stress at that weld/joint. Then halo ends up pinning the driver in to the seat or worse. This of course is worst case scenario. But unfortunately I have seen it happen. Halo is very easy to fabricate is the main reason you see it so much especially in drag cars.
Old 01-03-2014, 03:21 AM   #1166
norexyet
Member#: 39149
You can run them really tight as long a pillars to. I did an 04 sti awhile back for meetmrglock on these boards. Not sure if he still around but it came out really nice but both work.
Old 01-03-2014, 03:23 AM   #1167
norexyet
Member#: 39149
I guess it's possible but I usually gusset them to the hoop and haven't had issues but I'd rather make long a pillar bars with a windshield bar over a halo any day.
Old 01-03-2014, 11:05 AM   #1168
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
Love the fitment on Bruces car. I was going for the same thing but was able to get the halo to hug the windshield and roof liner much better with the halo.
And lets be realistic, following the NHRA CMoly rules for max weight savings, the cage isn't that strong to begin with. 1-5/8 .083 wall the pipe flexes like crazy and has some crazy spring back on the bender and the spec for a 1-1/4 harness bar just boggles my mind but hey, if it makes tech happy and is pretty much as light as my old POS autopower then I am ok with it.
Old 01-03-2014, 11:25 AM   #1169
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
On another note, who knows how to wire a master battery disconnect correctly to kill the alternator. So far I have 0 gauge from battery in engine bay back to switch, and another 0 gauge from switch back to OEM connector. This takes care of the starter and fuse box. I have a small jumper on the switch to the smaller pin and am supposed to run the other side of the pin to the alternator "field" wire. Is this the #1 wire on the green connector?
Old 01-03-2014, 04:01 PM   #1170
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
BTW just check with my local NHRA tech and there is nothing prohibiting the roof halo.
Old 01-03-2014, 04:26 PM   #1171
bswilmington
Member#: 217563
2006 Sti 12.68 @ 108
321WHP 422WTQ dynojet SAE
Will the car only be used for drag racing under NHRA rules. You plan on any type of rally/hill climb or other drag events? If so then I would verify there rules to before building cage. Would be a lot of work to have to redo in future.
bswilmington is offline   Reply With Quote
Old 01-03-2014, 09:35 PM   #1172
norexyet
Member#: 39149
Almost every cage you see for drag racing will have a halo. 95% of our mail order cages use a halo because they are usually easier to get a tig torch to and way cheaper to ship then a 75" long a pillar bar.
Looking forward to see how it comes out. Cage work is some of my favorite stuff to do. More of road race stuff but drag stuff is sweet.
Old 01-13-2014, 12:54 PM   #1173
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
Cage is done. Time to start sanding/clear-coating it and getting the car back together. Then off to NHRA for a chassis cert and getting the remaining required junk in the car and running it in Febuary.
Old 01-13-2014, 05:00 PM   #1174
25rsti
Member#: 166324
Look good, Jeff! February is when the track your way opens? Wow, nice California. NE sucks, so cold.
Old 01-13-2014, 05:14 PM   #1175
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
Sweet! Those are the only pictures on this forum that deserve a hashtag.... #becauseracecar
Lol
Hoping good things for you... Ive been reading this for a bit!
2Fast4U1DAY is offline   Reply With Quote
