Welcome to the North American Subaru Impreza Owners Club Monday July 23, 2018
Old 02-19-2014, 02:32 AM   #1451
outfrontmotorsports
Member#: 220204
Originally Posted by spoolinsti05 View Post
Oh so these are welded in voiding an air gap altogether? Very interesting, Please do tell more!
who said anything about welding? there is no welding. the notch is kissed so the insert will have a perfect mate with the insert.
maybe we're talking about two different things
outfront
outfrontmotorsports is offline   Reply With Quote
Old 02-19-2014, 03:04 AM   #1452
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
Originally Posted by outfrontmotorsports View Post
who said anything about welding? there is no welding. the notch is kissed so the insert will have a perfect mate with the insert. maybe we're talking about two different things outfront
I was just trying to figure out how you keep an air gap seal without welding? Is it just that tight of a machine fit?
spoolinsti05 is offline   Reply With Quote
Old 02-19-2014, 03:40 AM   #1453
outfrontmotorsports
Member#: 220204
the close deck strengthens the cylinder radially and is not intended to seal in the manner that you are thinking, just think of the block before/without the insert. It's all "air" (how does that work?) hope that helped
Old 02-19-2014, 09:02 AM   #1454
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
Do you do this to open deck blocks also?
Old 02-19-2014, 09:47 AM   #1455
jnorth85
Member#: 76785
2000 580Whp The RSTI
SRP
why would they modify an open deck block? or even use one? open deck blocks are either found on NA cars or on an EJ205 both of which are not commonly used when trying to make any sort of power.
jnorth85 is offline   Reply With Quote
Old 02-19-2014, 09:56 AM   #1456
Layvon
Member#: 195711
PART OUT. PM ME
02-07 Goodies
Did you think about perhaps someone does not want to try finding more EJ207 blocks if they close in 205s? You can get 205s for dirt cheap. 207s not so much.
Also 205s have thicker OEM walls so if they were making them they could either mill that away or make one special for the 205. I think it was a great question to be honest.
Layvon is offline   Reply With Quote
Old 02-19-2014, 10:43 AM   #1457
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
outfront
They are press fitted into the block with loctite kind of like sleeves
Crystal_Imprezav is offline   Reply With Quote
Old 02-19-2014, 10:53 AM   #1458
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
What about the ej207? Have you closed a deck on one of those yet? I think the ej205 is plenty durable for power with the correct internals and setup.
Old 02-19-2014, 10:58 AM   #1459
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4+ hybrid STi
Because they were closing decks on the N/A blocks and boosting them long before the 257 was available in the states.
Remember, their background is sandrails not Suby street cars
Old 02-19-2014, 11:00 AM   #1460
jnorth85
Member#: 76785
SRP
I understand this for the closed deck process, but modifying them and NOT closing the deck would be pointness..
I am aware that outfront started by closing the deck on NA blocks, and also that they offer closed deck 2.0's that were previously open deck motors.
the EJ20K and V6 EJ207 can be had pretty cheap.
Old 02-19-2014, 11:04 AM   #1461
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
Isnt the difference between the 205 and 207 the semi closed deck on the 207?
At that point wouldnt it be easier/cheaper to close the 205?
slowgenius is offline   Reply With Quote
Old 02-19-2014, 11:12 AM   #1462
2000subie
Member#: 207638
2004 WRX
Yellow
Outfront does make a closed deck for the open deck blocks. It's still the original version, but they told me they haven't had any issues with it cracking.
And in talking with crystal about building a 2.0 before I went 2.35. He thought that the power capabilities were as good as the ej255/57 blocks, because of the thicker walls. That's all if I understood him correctly. So layvon is absolutely on the right track with his statement IMO.
2000subie is offline   Reply With Quote
Old 02-19-2014, 11:15 AM   #1463
2000subie
Member#: 207638
2004 WRX
Yellow
Originally Posted by slowgenius View Post
Isnt the difference between the 205 and 207 the semi closed deck on the 207? At that point wouldnt it be easier/cheaper to close the 205?
As far as differences in the case halves, yes that's the only difference.
Old 02-19-2014, 11:24 AM   #1464
jnorth85
Member#: 76785
SRP
he for sure is. once you close the deck, open deck or semi closed deck no longer matters from the start. at that point all that matters is cylinder liner thickness.
Old 02-19-2014, 12:11 PM   #1465
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
Another nasioc epidemic lol
Old 02-19-2014, 12:14 PM   #1466
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
Yes but you already have a structurally sound platform going with a semi closed ej207
Old 02-19-2014, 01:51 PM   #1467
outfrontmotorsports
Member#: 220204
we mainly do the 257 block, we feel its the strongest platform,
we now also have the late model 25rs block, core casting "Z25" in stock, this was a full open deck block and is a cheaper alternative for a closed deck 25 hybrid as you don't have the center block vent. this block is a rear thrust, phase 2 and we sell the core for $200.
we have some 205 blocks in stock but this was our first design. this design has never had an issue with cracking as the walls are so thick to begin with. we have not done a 207 block to date
Outfront
Old 02-19-2014, 03:14 PM   #1468
2000subie
Member#: 207638
2004 WRX
Yellow
Yes but if your looking to go closedeck your probably going to go fully forged new rotating assembly. So if your starting from scratch the 205 is a cheaper route and the bottom end will be equally as capable once there closedeck. Stock for stock 207 is 1000000000000000 times better, but built and closedecked no reason to spend the extra cash. Unless you buy one of the 207 blocks with the thicker liners!
Old 02-19-2014, 04:20 PM   #1469
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
At the end of the day the 207 will always be the best based on obvious factors like oil squirters in the block for piston skirts and for cam lobes. Granted if it's not meticulously maintained these can become clogged causing more harm.
Old 02-19-2014, 04:23 PM   #1470
cnstman
Member#: 9548
2004 WRX STi
10.154 @139 @ 7,000'DA
the block has squirters for cam lobes?
cnstman is offline   Reply With Quote
Old 02-19-2014, 05:03 PM   #1471
MartinSTi05
Member#: 145145
2006 wrx STi
Also for the muffler bearings.
MartinSTi05 is offline   Reply With Quote
Old 02-19-2014, 05:05 PM   #1472
jnorth85
Member#: 76785
SRP
Old 02-19-2014, 05:10 PM   #1473
2000subie
Member#: 207638
2004 WRX
Yellow
Forgot they had squirters for the skirts. And I was basing just off the shortblock. Obviously there is no comparing any other Subaru head to a 207 head, especially the v8 big ports.
Old 02-19-2014, 05:23 PM   #1474
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
The heads. But the oil is delivered from the block yes.
Old 02-19-2014, 05:26 PM   #1475
bettner12
Member#: 56179
05 LGT 407hp/372tq
Tuned by [email protected]
If the 207 block would be better to do, why not just get a ej22t block, sleeve it and be done with it?
The point of these is to make what everyone has in the US (255, or 257) into something much better. Not trying to reinvent the wheel...
bettner12 is offline   Reply With Quote
