05-18-2018, 10:23 AM | #501 |
Member#: 485561
This build is just insane, I love it! Definitely following along for the rest.
05-22-2018, 10:55 AM | #502 |
Member#: 151895
Cluster temp issue has been resolved.
Managed to use the wires from the wideband harness that I decided not to use. Started wiring the Defi gauges... and this is my previous wiring job. And this is the remake. Based on that it was time to take a small break from all the wiring. Midnight sander in action. Was going to start with 1200 grit but 2000 seems to do just fine. Not looking for perfection here. Just an overall paint correction. More to come. |
05-22-2018, 11:48 AM | #503 |
Member#: 15822
Vehicle:1999 WRB GM6 2.34 LR destroker |
oooh I hate those defi connectors, they are so weak and impossible to fix
ended up gluegunning the replacement connector I got so it lasts |
05-22-2018, 01:41 PM | #504 |
Member#: 476573
Vehicle:2008 Impreza WRX STi Silver |
05-22-2018, 03:47 PM | #505 |
Member#: 15822
how do you mate them with the controller/units?
05-22-2018, 04:11 PM | #506 |
Member#: 93750
05-22-2018, 04:34 PM | #507 |
Member#: 93750
Amen! I could stare at his wiring all day. I'm so envious . I always wanted to teach myself millspec but never got around to it before parting out my track car
05-23-2018, 12:01 AM | #508 |
Member#: 151895
Thanks guys.
05-23-2018, 12:28 AM | #509 |
Member Status: Member
Member#: 46241
SWIC
Vehicle:- Can I get a wayo |
05-23-2018, 10:44 AM | #510 |
Member#: 151895
First time I saw a Sti cluster lit up was at one of my first rallies back in 2006.
I was sold right there and then. |
05-23-2018, 11:04 PM | #511 |
Member#: 151895
Trunk and wing have been sanded and polished.
Can you tell ? Driver's quarter and door sill done as well. Still some orange peel left. Gauges are hooked up.. just trying to see if I need EGT... Note.. Ebay mirrors dont frigging fit... Seems like the guy sent me wrong brackets.. and now its too late.. AOS is in with all its hoses. The PS pump came in and on the good note it fits. Belt also clears the radiator. On the bad note.. somebody dropped it and the pulley is bent and wobbles... |
05-24-2018, 01:01 AM | #512 |
Member#: 93750
I'll bribe you with milk and cookies to shoot some video while working on your car.... Or pizza and beer if that's more your thing
05-24-2018, 01:59 AM | #513 |
Member#: 314324
International
Vehicle:MY07 Lib GTB 6MT Wag OBP |
Did you research de-powering a power steering rack?
Iirc remove/turn down the internal pistons, pack with grease, seal the unused ports, viola! Heaps of how to’s online if you’re curious... |
05-24-2018, 09:50 AM | #514 |
Member#: 151895
That was the original idea to de-power.
I haven't opened the rack and greased it.. don't know how much is that going to help. Also planning to run bigger tires as well. |
05-25-2018, 06:47 PM | #515 | |
Member#: 314324
International
https://thefactoryfiveforum.com/showthread.php?5966-De-powering-the-steering-rack-plus-more-to-come-on-rebuilding-wrx-parts I’ll have to search the actual effects on a car with quick rack, wide tyres, extra caster and 365mm steering wheel lol. They like the feel here: http://www.rs25.com/forums/f105/t75177-diy-power-steering-delete.html#/topics/75177?page=2 Could be worth trying with a junkyard fast rack before committing to depowering a big buck quick rack. Last edited by bigBADbenny; 05-25-2018 at 06:56 PM. |
06-25-2018, 01:19 PM | #516 |
Member#: 151895
Back from a little vacation...
No work done on the car but visited a pretty cool place... (courtesy of 97WRXwagon) I'll let the pics speak for themselves... You know **** is real when AP Racing comes by the pallet. |
06-25-2018, 03:59 PM | #517 |
Member#: 327563
Vehicle:2018 Civic Type R 2008 N54 335i |
Very cool pics. Definitely have a hook up there. Lol.
07-14-2018, 12:14 AM | #518 |
Member#: 151895
Off we go then...
Here we are in the process of wet sanding ... 2000 grit as I didnt dare to go 1200 and then 2000. Rear bumper. And the right rear quarter. Roof in need of another go... Practice makes perfect they say... Rear bumper after the first 2 passes of rubbing compound. Here is a comparison with 1st pass on the right. Polishing part is done. I'll take some pics once it cools outside enough to open the garage door. Power steering pump has arrived. 2nd one as the first one had a damaged pulley and looked like **** on top of that. Install was a bitch as "somebody" probably used too long of a bolt and stripped the threads on one of the mounting holes. There was enough meat to go from M6 -> M8 thus saving on helicoils. All seemed good and I wanted to use the old PS tank. Seemed like I could make it work. With the charge pipe back in things just wouldn't align. Ports were pointing in the wrong direction so new tank has been ordered. |
07-14-2018, 12:14 AM | #519 |
Member#: 151895
Now.. for the main event..
Bit the bullet and got me a set of scales.. Figured... If I do my own corner balance few times it will just pay for itself. They came few days earlier!!! Heavy as **** .. each plate must weight at least 20lb. It didnt take me long to put the car up on scales... Now.. what do you recon it came at ? Had 1/4 tank of fuel and passenger's seat out. Post your guesses below.. |
07-14-2018, 07:58 AM | #520 |
Member#: 327563
2670lbs
07-14-2018, 11:32 AM | #521 |
Member#: 29292
SCIC
Vehicle:2004 WRX wagon silver |
2500 lbs
07-14-2018, 12:39 PM | #522 |
Member#: 328635
NWIC
Vehicle:2004 STi GTX3076R Rally Blue |
07-14-2018, 02:25 PM | #523 |
Member#: 151895
This was just a preliminary weight in to see if all my "engineering" paid off in any way.
Its OK if you go over but still be the closest to the number. |
07-14-2018, 09:32 PM | #524 |
Member#: 378600
TXIC
Vehicle:09 Subaru WRX STi Black |
2200lbs
07-15-2018, 02:09 AM | #525 |
Member#: 30669
Vehicle:1998 Legacy 2.5GT Silver Sleeper BK, 5MT |
As pictured above?
2100 lbs |
