Welcome to the North American Subaru Impreza Owners Club Monday September 23, 2019
Old 02-01-2016, 05:34 PM   #1
pigboat_2
Member Sales Rating: (22)
Member#: 247823
2006 Fxt
RBP
Default CNT V2 Equal Length header review
Pic heavy.
I've been wanting to get a set of equal length headers for my car for some time now, and I came across this set sold by CNT Racing. Not only were they half the cost of any other header, they offered a military discount and free shipping, so I pulled the trigger.
I wanted to get the best before and after of this header with only changing the header, and a slight re-tune for the new header. I did my best to keep controlled variables- gas (ethanol content), temps, current tunes, etc. This didn't work out quite so well, but more on that later.
The product arrived quickly and as anyone should I immediately threw out the gaskets and hardware that came with the header, as they are well known for blowing out quickly and not being quality parts. Here's some pictures:
Notable mods:
2006 wrx wagon w/181k miles (tuned conservatively as such)
Blouch 20g-xtr 8cm
Ewg
Turbo XS 4" catted downpipe, SPT axleback
E85
MKTuned (https://www.facebook.com/groups/MKtuned/?fref=ts)
So we have a solid foundation to do a before and after now.
pigboat_2 is offline   Reply With Quote
Old 02-01-2016, 05:34 PM   #2
pigboat_2
Member#: 247823
2006 Fxt
RBP
I'll get into the installation in this post. It certainly did not go as planned.
The first time I attempted to install the header, it completely wouldn't clear my oil filter. Annoyed and confused, I put my car back together with the stock header and got online to figure out what was going on. The 02-05 wrx have known issues with a lot of equal length headers hitting the oil pan, but the 06+ oil pan is supposed to not have any problems. However, apparently the 2006-07 wrx has some sort of angled adapter plate for the oil filter. I used a thread where a guy fitted a Perrin header to his 2006 wrx and ran into the same problem, and came up with a solution.
http://forums.nasioc.com/forums/show....php?t=2491429
As such, I modified my oil cooler's coolant pipes to clear the timing covers and found the correct rubber hoses to fit the new cooler's location.
Pic shows how I trimmed the coolant hard pipe to clear the timing covers.
Installed:
Quick test fit of the new header- I should note that it went on with no problems, great fitment in this aspect:
And some pictures of how the oil cooler looks reinstalled (with a new gasket), with the coolant lines hooked up, heat sheathing on, and oil filter on:
Alright! Time for the header! Except...
So that's where I am currently. I am looking into different options, smaller oil filters, oil filter relocation, and possibly reinstalling the angle adapter a clock it in such a way that the oil filter clears everything. I can't retune because my tuner is wary of oil temps.
But to feed anticipation, I have a first (cold) start video:
Old 02-01-2016, 05:35 PM   #3
pigboat_2
Member#: 247823
2006 Fxt
RBP
UPDATE April 6, 2016.
The solution to the problem of the header contacting the oil filter was solved by buying a JDM STi external oil cooler. What I did was purchase an aftermarket oil filter sandwich adapter to replace the factory oil cooler. It has 2x 3/8" NPT connections on it, and I used matching 3/8" NPT barb fittings. The JDM oil cooler fitted up beautifully and all I needed to do was run some 3/8" rubber hose between the sandwich adapter and the hoses coming off the oil cooler. Initially the NPT fittings leaked so I used a combination of Teflon tape and thread sealer to solve that.
My goal was to raise the oil filter up and away from the header, via a much thinner oil sandwich adapter as opposed to the very thick factory oil cooler. I not only achieved this goal, but I have about 2 inches of clearance now between the header and the filter- more than enough room to change the filter when I need to. Additionally, going to the external oil cooler will net me colder oil temps, an added perk.
The sandwich adapter used I ordered here:
http://www.summitracing.com/parts/DER-25772
And the barbs I used for the sandwich adapter I ordered here:
http://www.summitracing.com/parts/SUM-220184
The other modification I did alongside the CNT equal length headers is a different turbo back exhaust. Previously, I had a 4" catted TurboXS downpipe mated with an SPT axleback. You can hear the video in the previous post how it sounds- a little bit raspy. Well, I wasn't satisfied with it and I opted to go with something more free flowing. I picked up an Invidia catless downpipe with a Greddy Ti-C catback and bolted it up. Honestly I couldn't be happier with how it sounds now. It's pretty loud of course, but I went ahead and grabbed a stock STi catback to bolt up when I need it to be quieter (IE when I drive to California next month). I'll get a good sound clip of it soon and post it up.
And of course the part that everyone has been waiting for: the power gains. GAINZ. Well, they are extremely noticeable!
With the install of my CNT equal length header and my new turbo back exhaust, I was able to gain 25 whp and OVER 50 wtq!! WOW and man do you feel a difference! Here's a VD graph:
We stopped when my motor began showing the smallest hints of knock. Keep in mind this is on e85 fuel at Denver altitude, on a motor that has nearly 190,000 miles on it. I also put the car on a Mustang dyno, and the numbers were 100% spot on what the VD reads: 359 whp/ 402 wtq.
Of course I have a video for you guys, and will upload the Mustang dyno graph later:
So, final thoughts? For the money, equal length headers are worth every penny. I obviously ran into some fitment issues, but hey, these headers are sold as 04-07 STi fitment. So what did I expect? Along the way I was able to upgrade the oil cooler and of course I gained some serious power.
Here's a quick link to the header since they're actually not very easy to find on CNT's website here.
Old 02-03-2016, 08:35 AM   #4
edsonmassao
Member#: 291430
2006 WRX wagon
It doesn't look like a plug n' play header. Just curious to see how you will fit in your car and mainly, the results and your impressions after a proper re-tune.
I'm looking forward to an EL header too, just trying to see if it's worthwhile 'cause it costs a lot here
edsonmassao is offline   Reply With Quote
Old 02-03-2016, 02:00 PM   #5
pigboat_2
Member#: 247823
2006 Fxt
RBP
Well the 06-07 wrx is special for whatever reason...even a brand name header like Perrin comes with instructions to modify the oil cooler like this.
I believe I will be going with a thin sandwich plate adapter and an external oil cooler, to essentially raise up the oil filter and clear the header.
Old 02-03-2016, 05:20 PM   #6
subaru_sti293
Member Sales Rating: (5)
Member#: 167288
07 STI_Fpred_RaceC
STI_04 Winter Beater
That's really close to the oil filter compare to Perrin Equal length headers lot of room to remove the oil filter.
subaru_sti293 is offline   Reply With Quote
Old 03-17-2016, 11:32 PM   #7
Bosque2006
Member Sales Rating: (3)
Member#: 353169
2011 Sti sedan
Swp
Any more updates? Thinking about getting some.
Bosque2006 is offline   Reply With Quote
Old 03-30-2016, 11:02 AM   #8
gurusan
Member#: 258165
2006 WRX Wagon
With oil filter relocation there would be no issue with fitment, correct?
gurusan is offline   Reply With Quote
Old 03-30-2016, 04:17 PM   #9
pigboat_2
Member#: 247823
2006 Fxt
RBP
Update very soon. Just need to get some pictures uploaded.
To answer your question, replacing the factory oil cooler with a 1" thick sandwich adapter routed to an external oil cooler did in fact solve the fitment problems.
Old 04-06-2016, 03:30 PM   #10
pigboat_2
Member#: 247823
2006 Fxt
RBP
Post 3 updated with solving the fitment issues, power gains, results, pictures, dyno graphs, and dyno video.
http://forums.nasioc.com/forums/show...25&postcount=3
Old 04-06-2016, 03:55 PM   #11
Bosque2006
Member#: 353169
2011 Sti sedan
Swp
Thank you! This is what I've been waiting for. Gonna order my headers asap now. Your car sounds great
Old 04-06-2016, 03:57 PM   #12
gurusan
Member#: 258165
2006 WRX Wagon
Awesome results. I'll definitely be using this on my new build. I think I am going to try keeping the stock oil cooler in place to help warm up the oil on cold starts though and relocating the filter somewhere else.
Old 04-06-2016, 04:14 PM   #13
pigboat_2
Member#: 247823
2006 Fxt
RBP
If I had the extra money, I would get the Mishimoto oil cooler kit for our cars. It has a thermostatic sandwich adapter- meaning it controls the oil going to the cooler to keep oil temps constant. I might get one down the line, but this solution was less than $200 all told, and the Mishimoto cooler kit is just shy of $500.
Old 04-12-2016, 09:50 PM   #14
CursezZz
Member#: 414974
2006 Subaru WRX STi
Obsidian Black Pearl
I'm curious how these would fit on an 02-05 wrx hmmm
CursezZz is offline   Reply With Quote
Old 04-22-2016, 03:14 AM   #15
pigboat_2
Member#: 247823
2006 Fxt
RBP
Should only need the oil pan to do it. Great chance to upgrade the pickup.
Old 04-22-2016, 03:08 PM   #16
rain_on_me
Member#: 328416
nice. i'll check and see if this fits a 12 wrx. kinda interested with it.
rain_on_me is offline   Reply With Quote
Old 04-23-2016, 09:21 AM   #17
jonathan04_hybrid
Member#: 437763
http://www.youtube.com/watch?v=7onWPX4pXTM
I think I just posted on your youtube channel asking if you suggest these, not knowing you were the same thread on Nasioc haha...so worth every penny? I called CNT and they said they offer a 1 yr warranty as long as i just bolt it up and not heat wrap etc...seems like a decent deal. So many mixed reviews
jonathan04_hybrid is offline   Reply With Quote
Old 04-24-2016, 01:26 PM   #18
TypeSRT
Member#: 427588
2016 WRX
Crystal White Pearl
How would you comment on the sound difference? That must mean mo more rumble no?
TypeSRT is offline   Reply With Quote
Old 04-24-2016, 05:41 PM   #19
pigboat_2
Member#: 247823
2006 Fxt
RBP
Should, but not 100% My tuner has a super nice EL header that actually won't fit his car because it's designed for the newer GR wrx. If you might have interest in buying it, let me know.
Well worth the benefits, yes, to go to a EL header. My year wrx threw some curveballs at me fitment wise, but I can't comment if a different brand header would have fit better.
Nope, no more Subaru rumble. Currently the header is off getting ceramic heat coated and I have the stock UELs back on. And as it is now, I really miss the EL sound. I've come to associate the unequal length rumble as imperfections in design, because I've gotten such good improvements from the new equal length.
I'd say it sounds unique, there aren't many cars on the road that sound anything like mine. It's certainly nothing like a Honda. I'll try to get a really high quality sound clip of the UEL header next to the EL.
Old 01-11-2017, 07:54 PM   #20
nine8wrx
Member#: 374962
1998 Impreza 2.5RS
Micha Pearl Blue 74F
Thank you for the awesome right up and great pics I might add. I'm gonna relocate my oil filter all together to cooler location. Although the sandwich does work. Thank you for the post. I was able to get all the information I needed. I also was weary of the CNT racing header because the price was super low for equal length header. I did research on cntracing. They only build Subaru's. That alone gets my attention. Forums in Australia even talk the header up as far as fitment and craftsmanship. Welds look awesome and 1 year warranty to boot. I'm in. Only 325.00 shipped on eBay. Just ordered it. Woot woot.
nine8wrx is offline   Reply With Quote
Old 01-19-2017, 12:52 AM   #21
bewarethebear
Member Sales Rating: (11)
Member#: 167825
2005 STi
Cgm
Any more long term impressions on this? These are currently my front runner for a two bolt equal length manifold due to bang for the buck and simplicity (vs fab work on my APS equal length headers), but I'm also interested in long term quality!
bewarethebear is offline   Reply With Quote
Old 01-19-2017, 10:03 AM   #22
pigboat_2
Member#: 247823
2006 Fxt
RBP
Well, not too much to report on my end. I was having continuous issues with the external oil cooler and the oil lines failing. Long story short, I would buy the Mishimoto external oil cooler if I did it again. Or find the matching sandwich adapter for the JDM cooler to make it 100% complete.
Ultimately I decided to get the header ceramic coated and then I wrapped it in the DEI titanium. I actually can't remember if I ever reinstalled it on my car after doing that, but I blew my transmission and circumstantially chose to sell the car.
I sold the header on this forum and to the best of my knowledge, the buyer removed the oil cooler completely and has had no other issues since.
If I did it again, the only thing I would do differently is get a proper oil cooler. I would still buy a CNT header.
Old 01-19-2017, 10:53 PM   #23
bewarethebear
Member#: 167825
2005 STi
Cgm
Wow, that sounds like quite the process 😮 but thanks for the information, I'm hoping that having an 05 STi means that there will be no major fitment issues!
Old 01-23-2017, 12:23 PM   #24
CursezZz
Member#: 414974
2006 Subaru WRX STi
I have had them on MY05 WRX for almost a year now and I like them a lot. I did have to dent the header a little where it was contacting the filter lol but no other issues they are holding up well
Old 02-02-2017, 11:18 AM   #25
Miggs1337
Member Sales Rating: (2)
Member#: 379581
2014 WRX
Gloss Vengeance Red
I just picked this header up and had the install done in about an hour or so. I like the header because of the price point, but also because it does not have the slip joint. I had the old perrin header and it leaked from there, so it was nice to pick up a header that eliminated that piece.
Overall the welds were fine except for the weld where the two pipes meet and connect to the up pipe 2 bolt flange. The welds weren't atrocious, and it'll flow just fine. This to me was the only flaw, but for $325, I was completely okay with that. This was installed on a 2014 WRX and I did not have any oil filter issues as stated with the older WRXs. It did take a little force to have the flanges slide into the header studs, but I had this happened with the old perrin header as well. The only real issue that I had was the passenger inside bolt. Due to the design of the header (Perrin header had the same issue), and the location of the oil filter, I wasn't able to get my 12mm socket onto the nut flush. I wasn't able to get enough room to turn a wrench to tighten the bolt either. I ended up buying a swivel socket and from there I was able to tighten the bold no problem. You could do an oil change at the same time and dropping the filter would give you enough room to turn a wrench in there. Once the header was on, it lined up with my grimspeed EWG up pipe perfectly. CNT also provides two longer up pipe bolts due to the flange on the header being thicker than the stock header. You can use the stock bolts if you'd like as they are still long enough to secure the flanges together.
I have yet to get tuned, but that will change this week. I have a single exit exhaust and it does seem a little more quiet than with the stock header, which i'm okay with. I have an upgraded clutch and it is pretty prone to chattering, but with the new header that has gone away. The chatter isn't as sensitive, and my guess is the engine is breathing much better so initial acceleration is easier. Overall I'm very happy with the header. I've used CNT racings catted downipipe and two different exhausts from them as well all of which were great products. I'm hoping the header is another one of their products I can refer my friends as well.
Miggs1337 is offline   Reply With Quote
