View Poll Results: What should I do next? | |||
Continue with Meth Kit |
15 | 22.06% |
Intercooler Spray |
3 | 4.41% |
Screw the 2.5iT, swap it for a WRX or STI (Or motor swap) |
41 | 60.29% |
Nothing, anything further is going to push the internals too far |
9 | 13.24% |
Voters: 68. You may not vote on this poll |
#101 |
Member#: 265006
E. Canada
Vehicle:2011 2.5i 5MT World Rally Blue |
![]() Not going to argue. Math isn't hard. Try it out.
#102 |
Member#: 301676
Vehicle:2009 Forester XT Silver |
#103 | |
Member#: 265006
E. Canada
![]() Quote:
#104 |
Member#: 305380
![]() So how much is the kit itself? I would love to turbo my 05 2.5 RS.
#105 |
Member#: 287184
Vehicle:05 RS-T & 16 FRS |
#106 |
Member#: 259013
RMIC
Vehicle:2007 Impreza 2.5i Greyish- Boosted |
![]() How many miles on your car? How has clutch been holding up?
#107 | |
Member#: 305650
South East
Vehicle:2016 WRX Dark Gray Metallic |
![]() Quote:
http://www.avoturboworld.com/avoshop...kit-p-139.html |
#108 |
Member#: 305650
South East
#109 | |
Member#: 236866
Vehicle:2013 Charger SRT8 white |
![]() Quote:
#110 | |
Member#: 305650
South East
![]() Quote:
#111 |
Member#: 323170
NESIC
Vehicle:06 impreza 2.5i silver |
![]() nice job
#112 |
Member#: 257921
TXIC
Vehicle:2006 Wrx SGM |
![]() if you get a good, i mean good tune on e85 with atleast 600cc injectors and fuel pump at 6-8 psi youll get around 250-260awhp stock 2011 sti's have 212awhp read straight from the dyno so youll be keepin up with alot of cars
#113 | |
Member#: 305650
South East
![]() Quote:
#114 |
Member#: 321935
RMIC
Vehicle:2008 Outback Sport Black Obsidian Pearl |
![]() What are the advantages of doing this kit as opposed to sourcing used wrx parts such as exhaust mani, up and down pipe and turbo and crossmember? Would the extra money spent be wiser even if you get everything the kit comes with for much cheaper? No disrespect to the thread just really wanting to turbo my obs. Those 245 tires look sick by the way.
#115 | |
Member#: 305650
South East
![]() Quote:
If you are thinking turbo, I would ask you to ask yourself, do you really just want some more power, or do you want a WRX/STI. I would have just done the swap to begin with if I had known, but I enjoyed the experience. Also, thanks! They use to rub a little because I lowered it a hair with coilovers as well, but we are all good now! ![]() |
#116 |
Member#: 301676
#117 |
Member#: 187834
Vehicle:06 2.5i impreza Red |
![]() Quick question due to fueling what did you do about your FPR I have a 2006 2.5i that's supercharged and seems that even with IPW's increased at 4k I still don't have enough fuel. So I guess my question is did you install a wrx fuel pump, a RRFPR, or an AFPR . Actually anyone that can answer this feel free to do so. Not trying to take over your post but you might want to check and see what is what cause I'm running 2006 wrx injectors 550-560cc so those are fine but fuel delivery is low. So what did you do to achieve more fuel
#118 |
Member#: 187834
![]() What I mean by fuel pump is complete fuel intank unit, see the 2.5i's have regulator in tank and actually fuel cut WOT anything above " 8 psi"so they say but I'm at 9 psi and at 4k already don't have enough fuel. So if tuner spotted that what did you do too achieve proper fueling. Walbro isn't enough if regulator is holding required psi of fuel back it just means it can deliver it if needed
#119 | |
Member#: 349649
![]() Quote:
#120 |
Member#: 351124
![]() should had gotten sti
#121 | |
Member#: 187834
![]() Quote:
Even tried to raise the IPW's at the rail with no prevail... ![]() |
#122 |
Member#: 187834
#123 | |
Member#: 349649
![]() Quote:
Assuming you are 10 or less your set up should be adequate. You might be getting a restriction from the filter. If it is indeed causing a restriction you'll be running the canister dry which could cause your lean condition up top. Once you swap the filter out post back and here the results. If it's not the filters the next thing to do is double check the lines for kinking/pinching. |
#124 |
Member#: 348562
Vehicle:07 Impreza 2.5i Silver |
![]() Ok I have read just about all of this post and I have a couple questions. I just bought a 2007 Impreza 2.5i and was eying this turbo kit up. My car has 76k miles on it now and was thinking how would it effect reliability further on down the road and also if there were and hidden costs excluding the fuel system upgrade and ecu tune? To anyone about to tell me save the money and time to get a WRX or STI please save your breath. even after the $3,400 for the kit i am still Sub 12 grand price tag and just about equal maybe a little more power than a stock WRX. This is pretty much the only thing I plan on doing to it. Would you recommend this kit for both reliability and power increase?
#125 |
Member#: 352827
Vehicle:08 Impreza 2.5i Silver. |
![]() I don't think it's as simple as buying a turbo and pitting it on there's a lot of other stuff u need to upgrade to your engine so it can handle the extra power.
2.5RS avo turbo kit | Alpha_32 | Private 'Wanted' Classifieds | 1 | 02-19-2005 05:34 PM |
AVO turbo kit for 2.5RS FS | Brood | Private 'For Sale' Classifieds | 7 | 07-21-2004 12:06 AM |
AVO Turbo kit for 2.5 for sale locally | Brood | Rocky Mountains Impreza Club Forum -- RMIC | 12 | 07-19-2004 11:30 AM |
AVO Turbo Kit Stage 2? | fukamoto | Normally Aspirated with bolt-on Forced Induction Powertrain | 4 | 06-08-2004 01:31 PM |
AVO Turbo kit - Stage 2 | NYCshopper | Normally Aspirated with bolt-on Forced Induction Powertrain | 0 | 04-24-2003 11:49 PM |
