Welcome to the North American Subaru Impreza Owners Club Tuesday January 16, 2018
Old 11-23-2012, 03:48 PM   #1
ripman
Member#: 305707
1999 WRX
WRC Blue
Default Hairline cracks between spark plug and valve seats?
I'm having trouble trying to find a decent set of '99 wrx heads for my build. They seem OK until I have them chemically cleaned, then there are hairline cracks exposed between the spark plug entry and the valve seats.
I had a set pressure tested and the came up fine, but I noticed in a couple of threads here that more experienced engine builders are not prepared to use these heads.
I spoke to the machine shop about it. They said they could last forever/or they could be fixed but we looked at the process together and it was time consuming.
My question is what issues have people found and at what sort of boost and hp levels?
Have people used heads like this on high hp builds without any issues?
ripman is offline   Reply With Quote
Old 11-23-2012, 04:19 PM   #2
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
You like that! and I still run it
Old 11-23-2012, 04:43 PM   #3
ripman
Member#: 305707
1999 WRX
WRC Blue
I'm not seeing anything that bad Fuji. Are you saying it has not been a problem for you?
Old 11-23-2012, 06:21 PM   #4
Ryan314
Member#: 82989
Hybrid EJ257
My machine shop would NOT service any heads with these cracks. It took us quite a long time to find a set of EJ205 heads without these cracks. It is very common. However, once we finally found a set, they reinforced the areas where it's prone to crack so they would not crack in the future.
After that, they went ahead and opened up my chambers and did a full valve job. You can't really blame them for not wanting to put work into heads with these cracks.
Ryan314 is offline   Reply With Quote
Old 11-23-2012, 07:08 PM   #5
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
There are other manufacturers of engines with heads that develops the same cracks and will drop a valve seat. Any machine shop would not let this pass. They don't want to be held liable.
For Subaru, i haven't heard of anything happening yet since these engines die in some way or form before the cracks become an issue. If anyone who has experienced more issues as a result from these cracks, i would like them to share their experience.
I actually would like to buy some "cracked heads" to do long term tests.
Old 11-27-2012, 04:40 PM   #6
NW2TONE
Member#: 212509
unde your hood makin
your **** go faster
you would like to buy some crack?????
NW2TONE is offline   Reply With Quote
Old 11-23-2012, 07:29 PM   #7
eg33GC
Member#: 206851
56 Belair
Pro Street
Fuji, I've never seen any cracks on the phase1 engines I've had over the years.
I wonder if this is unique to the phase two heads.
Old 11-23-2012, 07:52 PM   #8
ripman
Member#: 305707
1999 WRX
WRC Blue
For some reason I can not post attachements so unfortunately can't show picture of cracks. They can only be seen from up very close with the naked eye, so will be interested to hear views on running them.
Old 11-23-2012, 08:00 PM   #9
nottofast
Member#: 89663
1962 Fuji 350
cerelean blue
anyone know the cause? i wonder if it has to do with the hardened valve seat that is pressed in?
nottofast is offline   Reply With Quote
Old 11-23-2012, 08:12 PM   #10
Flat 4 Motorsport
Member#: 295846
WRX FP HTA GT3076R
Sexual Chocolate
pretty common, I've heard of issues with random misfires but if they were fine before you removed them they're probably still fine.
Flat 4 Motorsport is offline   Reply With Quote
Old 11-23-2012, 10:12 PM   #11
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
it caused us to drop out of one lap. More coming when I'm not on a phone.
Old 11-23-2012, 10:29 PM   #12
flstffxe
Member#: 155358
2008 Forester
Steel Silver
As Fuji said. It is a common issue for many engines. Some it causes the seat to drop others(like Subaru) it doesn't seem to cause much of an issue too often, not that it doesn't cause any...
It is actually common in many air cooled motorcycle engines. Many shops don't even have an issue working on these, they will do a valve job , note it and give them back if you wish.
It is entirely possible to remove the seats, repair the crack, chase the plug hole and remill the pocket for the valve seat. IME they will crack again in time.
In Harley's case on the Evolution many shops will also weld in the 14mm plug hole while repairing the crack and drill and tap it for the later Twin Cam 12mm plug giving more meat between the seat and hole, which seems to be the long term cure.
flstffxe is offline   Reply With Quote
Old 11-23-2012, 10:40 PM   #13
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
If the cracks get too huge, I'd look for another head.
Makes me wonder if I ran a brand new head with a 1 step colder plug, would it prevent this?
Old 11-24-2012, 05:03 AM   #14
EMS
Member#: 14116
Cracks even bigger than what they are now??? Those are the biggest cracks I've seen in Subaru heads... (and I've seen quite a few) I think you are pushing as there is a risk that a valve seat will drop at some moment. But if you are comfortable with that, it's no problem of course.
1 step colder plug won't help. I've seen heads with big cracks and those engines had colder plugs in from new.
I have no 100% proof, but I expect the cracks to form when running too much power before the engine is up to it's "normal" coolant temperature.
EMS is offline   Reply With Quote
Old 11-24-2012, 04:48 AM   #15
Surb00
Member#: 27132
1999 2.5 RS-T
Rally Blue
eg33 - I have seen a few ej25d phase 1 heads with the same cracks when I was at the Subaru dealer. Definately a known problem in all the twin cam heads. However, most of the time you wouldn't notice a problem until you're replacing the shortblock for bearing or ringland failure.
Surb00 is offline   Reply With Quote
Old 11-24-2012, 05:53 PM   #16
ripman
Member#: 305707
1999 WRX
WRC Blue
So what did the Subaru dealership do with them? Re-use due to it not having caused a problem, or reccomended to customer to replace them?
The cracks I'm seeing are more the same as in Flat 4's photo and came off a good running motor.
Old 11-24-2012, 10:25 AM   #17
GrundleJuice
Member#: 165749
In Aircraft Engines cracking between plug hole and Exhaust valve seat is not uncommon and it's attributed to heat Management. This is supported by improved cooling fin design in the area reducing or stopping the problem from happening and that it's often found on Engines with poor baffle seal.
Does anyone have cylinder head temp probes on an Engine where the cracking occurred? Is there a trend in what cylinder the heads are cracking on?
Old 05-25-2013, 07:33 PM   #18
HiImZackJones
Member#: 324552
Red
I hate to reply to this so many months after but I have seen damage happen on cylinder #4 first in most cases. The unequal header length tends to create more tear on that cylinder due to it being the longest length.
HiImZackJones is offline   Reply With Quote
Old 11-25-2012, 03:55 PM   #19
SW00P_G
Member#: 5591
EJ257 Gt35r
I've never seen a set pulled off a car that DIDN'T have the cracks. Sometimes you can't see them until the heads are cleaned up.
SW00P_G is offline   Reply With Quote
Old 11-25-2012, 10:57 PM   #20
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
I have built three 02 rex's lately and I couldn't find any cracks. I have seen these cracks on past engines and have used the heads with no problems. Not as bad as fuji's though.
Old 11-27-2012, 01:13 AM   #21
Surb00
Member#: 27132
1999 2.5 RS-T
Rally Blue
ripman - We'd document the cracks and send it down the road! Usually it is no problem. It's 3 different materials with different rates of thermal expansion in an extremely high temp environment somethings going to give.
Old 11-27-2012, 05:25 AM   #22
ripman
Member#: 305707
1999 WRX
WRC Blue
Thanks Surb. Good to know. Most of the comments have me reasonably comfortable to run these heads.
Old 11-29-2012, 10:58 PM   #23
nottofast
Member#: 89663
1962 Fuji 350
cerelean blue
Curious if anyone knows if this occurs across the board on heads from 1990 up to current?
Old 11-30-2012, 02:59 PM   #24
tja1618
Member#: 181995
Just found that my 2003 WRX heads have the infamous cracks. Was planning to use these in a hybrid build, but now I'm just going to get new castings to go along with the new EJ257.
How can I prevent this with a new engine? I'm going to have the new heads chamber matched and ported.
tja1618 is offline   Reply With Quote
Old 11-30-2012, 06:44 PM   #25
NW2TONE
Member#: 212509
your **** go faster
those cracks aint ****. run it. you wont notice a differance.
