10-24-2009, 04:23 PM | #251 |
Member#: 211299
NWIC
Vehicle:2005 STi going into 2001 gc |
10-24-2009, 06:19 PM | #252 |
Member#: 212692
Vehicle:2004 Impreza STI WRB |
wow that looks great! awesome idea! I've got a lot of blue in my interior (center console painted blue) i might try a blue LED.
10-24-2009, 08:17 PM | #253 | |
Member#: 183529
Vehicle:i wanna help teh haters ... love life ... |
10-24-2009, 08:59 PM | #254 |
Member#: 206936
Vehicle:20' STI LTD WHC 15' STI 09' GTR 1350whp |
nice, cant wait to do this.
10-24-2009, 09:28 PM | #255 |
Member#: 222835
SCIC
Vehicle:2007 Forester |
I have blue console light & footwell illumination. I thought it would be nice to have red one for shifter accent for nice contrast. I have all the materials I need but I still didn't figure out where to mount it... Whoever did this mod on 09 please share your knowledge
10-24-2009, 10:24 PM | #256 |
Member#: 224589
I just found this tonight...AWESOME I'm totally going to do it.
Where is a good place to tap in? I don't want to do the illumination on the clock; that seems like too much to run. The radio is about the same. Could you just tap into something in the fuse box? It's right under the dash so i figure it'd be easy. Are there specific circuits for illumination? I'm a mechanic guy...I don't do electricity to well. =) |
10-24-2009, 11:24 PM | #257 |
Member#: 227780
Vehicle:2000 Impreza 2.5rs Blue |
Bravo dude, looks sick
10-26-2009, 12:08 PM | #258 |
Member#: 184040
International
Vehicle:. 03' Baja- Sold 83' Datsun 280ZX |
Not to thread jack but I put some LEDs under my window controls and they look pretty cool, I was going to originally do it like the OP and put LED's shining down from the Handle on the roof, but I figured that My arm or something would block the light most of the time so I went from the bottom up and it turned out cool, you cant see anything out of the ordinary in the day time either.... and it shines up on the chrome door handle also Maybe I need something like this on my shifter also..... |
10-26-2009, 01:49 PM | #259 |
Member#: 228083
02-08-2010, 02:37 PM | #260 |
Member#: 180924
Vehicle:2017 Forester |
I had a question about resistors. I ordered some leds to do this mod and wasn't sure what I needed. The plan is for 1 5mm led. I ordered a few of the ones below from superbrightleds.com
RL5-R5015 Red LED RL5-R2415 Red LED I tried this earlier with an led from radio shack but it didn't work. I ran a wiring harness and tapped the power from the same place my defi gauges do. Ground to ground and positive to the illumination wire, so the led would turn on with the lights. Assuming that all that wiring is correct, there might be an issue with the wires themselves...what would I need to make either of those leds work? Also is there a way to test an led by itself to make sure it works? The one I have is 1.7 volt 20 mA. Thanks! |
02-08-2010, 03:10 PM | #261 | |
Member#: 158241
NWIC
Vehicle:2006 CGM WRX Wagon XPT Stage II |
http://led.linear1.org/led.wiz this site helps you determine what size resistor you'll need. |
02-08-2010, 04:14 PM | #262 | |
Member#: 180924
Thanks! |
02-08-2010, 04:25 PM | #263 | |
Member#: 158241
NWIC
and yes, there's +/- on LEDs. for testing, i just put a few batteries together to reach the rated voltage, then wire it up to the LED. oh look, someone wrote a guide on this mod too... maybe it'll help you on the wiring. http://forums.nasioc.com/forums/show....php?t=1715830 |
02-08-2010, 06:56 PM | #264 |
Member#: 236278
Vehicle:2013 WRX DGM |
That's a really cool little mod and pretty neat placement in what I find to be a nearly useless sunblocker up top. GJ
02-08-2010, 10:46 PM | #265 |
Member#: 217771
SWIC
Vehicle:2004 WRX 2000 Audi S4 B5 |
I love it, i'm trying
02-09-2010, 08:31 AM | #266 |
Member#: 225802
Vehicle:1995 Impreza L/sti |
been thinking about doing something just like this to my car. looks good
02-09-2010, 11:53 AM | #267 |
Member#: 217771
SWIC
YOu need to make a video for us, because I have some unawnsered questions.
02-11-2010, 08:31 PM | #268 |
Member#: 219696
Vehicle:2004 STi PSM |
Nice idea! Very original!
02-12-2010, 10:08 PM | #269 |
Member#: 180924
Ok super duper fast write up.
I made a wiring harness out of molex connectors so I could easily disconnect the LED. I ran the harness through the front of the headliner, down the a pillar, under the dash and connected it to where I had my DEFI gauges hooked up. I tapped into the 12v illumination supply and the ground off the radio harness. ^ harness for the led itself. I don't have pictures of the other, but it is literally a molex connector and two wires. Now the fun part. I used my map light to do this mod unlike the other posts. I drilled a hole in the center of the map light closest to the rear view mirror. This hole was widened and slanted to accomidate the LED straight up and down, if not angled a bit backwards. That was the hard part. Getting the LED to shine where I wanted. I tacked it with hot glue and it was basically trial and error. Eventually I got it to where I wanted for now (I was rushing, I might redo) and then smothered in hot glue. Finished product All pictures were with an iPhone, sorry for the quality or lack there of. I don't have any glare off the rearview mirror. The LED is recessed pretty well out of sight. In order to see it from the outside from the front you have to crouch down. Hope this helps! |
02-12-2010, 10:19 PM | #270 |
Member#: 207670
Vehicle:04 Peanut |
What is that flap thingy? And I kinda dig this. Looks cool like Night Rider.
02-12-2010, 10:37 PM | #271 |
Member#: 180924
02-12-2010, 10:42 PM | #272 |
Member#: 238245
SWIC
Vehicle:WRX 07-Mayhem Tuned 280whp/295wtq - VF34 |
Before the pics, I was skeptical. But very nice!
02-12-2010, 10:44 PM | #273 |
Member#: 197609
Vehicle:04 wrx sti aspen white |
that is a vw thing.. but cool none the less.
02-13-2010, 03:53 AM | #274 | |
Member#: 222089
South East
Vehicle:2010 Satin Pearl White |
02-13-2010, 04:44 AM | #275 |
Member#: 187115
HIIC
Vehicle:2010 Legacy 2.5i Steel Silver Metalic |
I don't know if anyone knows this, but the 2009 forester has this stock in the map light trim
I have had many cats, but never seen one do this. | urgewrx | Off-Topic | 11 | 01-05-2009 09:19 PM |
Never seen these STI rims before, have you? | wrxwagon253 | North West Impreza Club Forum -- NWIC | 32 | 01-27-2008 06:39 AM |
I've never seen anyone try to tip a news reporter before | Neek | Off-Topic | 10 | 11-19-2007 05:30 PM |
I have never seen anyone spin on their head this long...ever... | AcquaCow | Off-Topic | 13 | 10-19-2006 12:58 AM |
I've never seen OT so empty before. | obyone | Off-Topic | 10 | 08-23-2003 07:57 PM |
