Welcome to the North American Subaru Impreza Owners Club Saturday December 7, 2019
Go Back   NASIOC > NASIOC Technical > FA Series Factory 2.0L Turbo Powertrain
Notices
Old 08-21-2019, 05:04 PM   #1
bluewrx2018
Member#: 485226
Default LTís FA20 Engine Build
So I threw a rod on cylinder 2 recently commuting to work one morning. Itís a 2018 with approximately 11k miles with a moderate spirited driving history. Oil changes done every 2,500 miles with Motul 8100 X Clean.
Modified for nearly 8k miles with no issues. Mod list includes:
Perrin Intake
Perrin Motor Mounts
Perrin Header
MAP 3Ē J Pipe w/ HFC
MAP Exhaust w/ Muffler Deletes
Perrin Trans Mount
Cobb AP
Perrin Strut Tower Brace
Cruising to work doing 55MPH when all of a sudden I heard a loud tapping noise coming from my engine bay. No visible leaking of oil.
Had it towed to PRO COM Racing in Toms River New Jersey for inspection and confirmed diagnosis. A timing chain inspection initially was performed. Next a compression test which failed miserably. On not only cylinder 2 but cylinder 4. Upon opening up motor they found the culprit a thrown rod on cylinder #2.
Timeline for build is 3-4 weeks which includes break in period. Build will be capable to holding 500HP.
Engine build is as follows:
-New OEM FA20 Case Valves
-Manley Platinum Series 86mm Forged Pistons
-Manley H Tuff Connecting Rods
-ARP Rod Bolts
-King Rod / Main Bearings
-New OEM FA20 Crankshaft
-ProCom Proprietary Block Strengthening and Oiling System Modifications
-Motul 300v 5w40 Syn Oil
-ARP2000 Head Stud Kit
-OEM Engine Seal Kit
-OEM Oil Cooler
-OEM Oil Pump
-OEM Timing Chains
-OEM Guides / Tensioners
-OEM Water Pump
-OEM Thermostat
-AOS Separator
-Perrin Front Mount Intercooler
-Perrin Boost Controller
-NGK 1 Step Colder Plugs
-EGR Delete
-TGV Delete
-Big Oil Filter Kit
-Machined Cylinder Heads
Resurfaced, Valve Seal Replacement, Valve Lash Adjustment, Clean / Sonic Blast of Cylinder Heads
Upon completion of engine build there will be another compression test, 1k miles break in period and a full Mustang Dyno Tune.
ENGINE COST BREAKDOWN:
*Engine will have a full warranty*
There is no additional charge for any additional parts I wish to add on during the build. Such as a FMIC, TIP etc.
https://www.procomracing.com
bluewrx2018 is offline   Reply With Quote
Old 08-21-2019, 05:05 PM   #2
bluewrx2018
Member#: 485226
Perrin Intake
Perrin Motor Mounts
Perrin Header
Perrin Trans Mount
Cobb AP
-ARP Rod Bolts
-OEM Oil Cooler
-OEM Oil Pump
-OEM Timing Chains
-OEM Water Pump
-OEM Thermostat
-AOS Separator
-Boost Controller
I will posts pics and updates as the build goes on. Thanks
Old 08-21-2019, 05:18 PM   #3
idiosyncrisia
Member#: 448185
2016 WRX
I'd say modified for 8k with no issues is wrong if the engine blew haha
That's going to be a pretty sweet build, but it sucks that you now just eclipsed STi pricing for your low mileage car.
idiosyncrisia is offline   Reply With Quote
Old 08-21-2019, 05:26 PM   #4
bluewrx2018
Member#: 485226
Yea totally. I sick to my stomach but excited at the same time.
When I initially threw the rod driving I said ďThat canít be my carĒ sounded like a baseball card on a bicycle spoke flicking. Epic fail
Old 08-21-2019, 05:49 PM   #5
2018wrx_newbie
Member#: 477489
2018 WRX Limited
CWP
Yikes, sorry to hear that man.
What tune were you running? And what did the shop quote you for the build?
2018wrx_newbie is offline   Reply With Quote
Old 08-21-2019, 06:12 PM   #6
bluewrx2018
Member#: 485226
Thanks.
Cobb Stage 2+ OTS Map
Engine Tear Down 714.00
ProCom Racing Short Block 3,499.99
Engine Fit Up Package 1,849.99
Machine Cylinder Heads 525.00
Engine Assembly 1,968.75
Engine Removal / Install 880.00
Engine Break-In 399.99
Dyno Tune 600.00
Old 08-21-2019, 06:31 PM   #7
WRXnick16
Member#: 447898
2016 WRX (traded)
2019 STI CWP
Sorry to hear about your loss. At least you'll have to worry about the block a bit less now. Just make sure that you have a quality tune for your parts.
You had a Cobb Stage 2+ OTS map with this mod list?
Perrin Intake
Perrin Header
MAP 3” J Pipe w/ HFC
Cobb AP w/ Stage 2+ OTS Map
I hate to be that guy, but that likely contributed to the failure. Cobb's OTS tunes are designed specific to their parts. The stage 2+ map requires the Cobb Big SF intake. It's not designed for the header either, but that probably made less of a difference than the intake and maf scaling.
We all make mistakes and learn from them.. that was just a very expensive $10k lesson. At least you're willing to admit it. Most people would make excuses, blame Subaru, and try to commit warranty fraud in hopes that Subaru would cover it.
WRXnick16 is offline   Reply With Quote
Old 08-21-2019, 06:45 PM   #8
2018wrx_newbie
Member#: 477489
2018 WRX Limited
CWP
Good luck with your build. Please post updates of your build, hopefully you have some interesting updates as it progresses. Will be following this thread.
Old 08-21-2019, 07:24 PM   #9
bluewrx2018
Member#: 485226
Thanks.
I sure will post updates and pics along the way.
Old 08-21-2019, 06:47 PM   #10
2018wrx_newbie
Member#: 477489
2018 WRX Limited
CWP
This ^. Thanks for posting and sharing the experience so others can learn.
Old 08-21-2019, 07:26 PM   #11
bluewrx2018
Member#: 485226
No problem. Hopefully I can steering people from making the same mistake. And if they donít hopefully they have a lot of money to fix it
Old 08-21-2019, 06:58 PM   #12
GlarryHoodDIT
Member#: 460907
2016 WRX
This x200000. Pretty clear what led to failure: OTS map with the wrong mods. Did you happen to take any catalogs?
No blaming Cobb, no trying to blame a shop, no trying to pawn this off on Subaru to fix. Respect to OP for handling this like it should be.
GlarryHoodDIT is offline   Reply With Quote
Old 08-21-2019, 07:42 PM   #13
bluewrx2018
Member#: 485226
No data logs however starting getting enormous feedback knock and fine knock learning before my incident.
The racing shop stated the spark plugs were toasted. Compression test failed on multiple cylinders.
Iím thinking more of a detonation issue. Creating too much pressure in the crankcase. Leading to failure.
Old 08-21-2019, 07:57 PM   #14
GlarryHoodDIT
Member#: 460907
2016 WRX
Was the knock happening at WOT or cruise, or both? Did you notice any feeling of power loss before it finally gave out?
Old 08-21-2019, 08:27 PM   #15
bluewrx2018
Member#: 485226
I was getting knock at both WOT and cruising speeds. Before it gave 12.xxx knock. No feeling of lost power. Lots of backfire from exhaust. My AFR were bouncing around cruising prior as well.
Old 08-21-2019, 07:23 PM   #16
bluewrx2018
Member#: 485226
I for sure made the mistake of thinking ďit can happen to meĒ. As time went on mileage wise I felt more assured I was bullet proof. And for 8k miles I was. Had a lot of fun along the way lol
Appreciate the comment. At the end of the day there is no one to blame but myself.
Old 08-21-2019, 06:49 PM   #17
Matrex15
Member#: 473848
2015 Wrx
OTS map???Really? Were you trying to blow it up?
Matrex15 is offline   Reply With Quote
Old 08-21-2019, 07:29 PM   #18
bluewrx2018
Member#: 485226
Not at all. Ran it for so long like this it became normal for me. Didnít even think about throwing a rod or spinning a bearing. Just turned the key and drove.
With all the information on this site I should have known better. You live and learn. And I certainly did.
My first Subaru too
Old 08-21-2019, 07:15 PM   #19
gn4rwhals
Member#: 453427
2017 WRX
Crystal White Pearl
That price breakdown isn't that bad considering, but you are gonna need a new clutch too.
gn4rwhals is offline   Reply With Quote
Old 08-21-2019, 07:22 PM   #20
WRXnick16
Member#: 447898
2016 WRX (traded)
2019 STI CWP
Since you're in New Jersey, maybe reach out to Prime Motoring for a quote to do a FA24DIT swap
https://forums.nasioc.com/forums/sho....php?t=2907007
Old 08-21-2019, 09:11 PM   #21
bluewrx2018
Member#: 485226
Maybe next time around
Old 08-22-2019, 12:15 AM   #22
WRXnick16
Member#: 447898
2016 WRX (traded)
2019 STI CWP
You won't need a new clutch with your low mileage and power levels. Obviously you'll need to look for an upgrade if you go with a larger turbo and start pushing higher power levels later on. It really just depends on your plans for the car and if you would rather replace it now while the engine is out or wait and pay the labor cost again down the road.
Old 08-22-2019, 01:20 AM   #23
adam99
Member#: 480524
2015 WRX
Catted or catless exhaust? If it is catless with the combo of header and intake then it will 100% creep. If you are then get you wastegate ported or just go with socal v3 or fp blue.
adam99 is offline   Reply With Quote
Old 08-22-2019, 10:37 PM   #24
bluewrx2018
Member#: 485226
The tuner said stock fueling is holding me back. Said the stock turbo has more power to offer. Just getting the fuel now is the bottle neck.
I might keep the stock clutch for awhile. And see how things go.
Old 08-21-2019, 07:43 PM   #25
bluewrx2018
Member#: 485226
Any suggestions on this?
