Brakes & Suspension Forum sponsored by The Tire Rack |
02-19-2014, 03:20 AM | #1 |
Member#: 191212
Vehicle:2007 FXT-5MT E85 20G TD06SL2 Kinugawa |
2015 STI Steering Rack 13.1!! Anybody Planning to swap?
Just wondering if it will fit older Subarus, the 19 ratio on the Forester is just ridiculous, feels I am driving an 18-wheeler. 13.1 = delicious.
02-19-2014, 08:38 AM | #2 |
Member#: 175624
Vehicle:0304 WRX WRX SY WRB |
That was actually the first thing that came to mind when they released specs for the '15. I'm sure it won't be a direct fit, but I'd imagine it should be possible with enough fabrication. It's tough to say until somebody gets their hands on one and tries it though. I'd love to put one in my '04 WRX...that may end up being my winter project next year
02-19-2014, 12:45 PM | #3 |
Member#: 191212
Fabrication is letigiously dangerous, Q-Rack had a lot of issues, hopefully is a direct fit.
02-19-2014, 01:27 PM | #4 |
Member#: 175624
Eh, unless you're selling them or telling people how to install them (or selling the car,) why be worried about litigation?
I'm not particularly afraid of fabbing brackets, even if it requires cutting up and welding a crossmember. It would be nice to have a quick rack that you can pick up at any dealership in the states for a "reasonable" price. Q-racks recent issues are why I'm even considering going to the effort. |
02-19-2014, 01:40 PM | #5 |
Member#: 103232
Vehicle:GTX 3071R'd 11WRX PPG,4.44,LSD,E85,6spdx3 |
If we could it would be amazing....
02-19-2014, 01:41 PM | #6 |
Member#: 39086
Vehicle:2004 STi White |
Having an STi, I'm more concerned how compatible it is with the older steering angle sensor. The Q- rack was not.
02-19-2014, 02:47 PM | #7 |
Member#: 191212
2004 STi not aware they had steering angle sensors back then?
02-19-2014, 02:54 PM | #8 | |
Member#: 39086
It's some of the other sensors in the center consol that came later. |
02-22-2014, 06:06 PM | #9 |
Member#: 13530
Vehicle:EA63 , EA81T, EJ20G, EJ205 |
I'm pretty sure the 07 STI was the first to get the steering angle sensor. The clock spring is NOT a steering angle sensor.
02-22-2014, 07:43 PM | #10 |
Member#: 39086
All I know is the DCCD doesn't like the Q-rack. The firstto try it gave up. This a ~decade old memory test.
03-02-2014, 12:53 AM | #11 |
Member#: 343711
Vehicle:2013 STI WRB |
really would love to know if it's a direct fit
03-02-2014, 07:25 AM | #12 |
Member#: 32792
Vehicle:2003 GGA MBP 12.9 / 105+ |
i'm in the market for a new rack these days (excessive shaft play in my original).
somebody grab an '15 sti rack and take a picture of the mounting points!! |
04-25-2014, 11:01 PM | #13 |
Member#: 188132
which racks will work on a GC? Will new STI even work and what's up with this sensor u mention?
04-26-2014, 11:36 AM | #14 |
Member#: 1130
Vehicle:2013 STI Hatch DGM |
I'd love a quicker rack for my '13...
04-28-2014, 03:19 PM | #15 |
Member#: 103232
The 2015 wrx has a electric rack. Anyone know about the STI?
04-28-2014, 03:54 PM | #16 |
Member#: 110994
Vehicle:2006 SGM STi 1997 SVX LSi |
sti rack is hydraulic like normal
04-28-2014, 09:21 PM | #17 |
Member#: 1130
So, in theory, if it did fit, would we not also have to reprogram the traction control etc to accept the new quicker steering angle?
Is this reprogramming even available? |
04-29-2014, 10:57 AM | #18 |
Member#: 72713
BAIC
Vehicle:2005 STi PSM |
Rallispec sells an OEM group N 13:1 LHD steering rack.
Only $4000 |
04-29-2014, 01:08 PM | #19 |
Member#: 72730
Vehicle:2019 Volvo S60 T6-R SPORT CHASSIS |
Nope. Only current solution is turn off VDC or disable it and ABS. There is likely not enough economic gain in anyone reverse engineering the VDC unit so not likely to ever change. Perhaps someone will figure out how to intercept the steering angle sensor and change the signal, but it speaks directly to the CAN BUS so not sure how feasible that is either.
04-29-2014, 01:15 PM | #20 | |
Member#: 175624
That or starting with a WRX so you don't have to worry about DCCD |
04-29-2014, 02:31 PM | #21 | |
Member#: 72730
DCCD is not the problem here, it is relatively minor to have the level of center diff lock not be quite right due to incorrect steering angle input. The VDC on the other hand (which all WRX/STI since 08 have) goes a bit nuts when the wheels are turned further than it expects! If you don't care about turning VDC off every time you drive no big deal. |
04-29-2014, 02:39 PM | #22 |
Member#: 103232
04-30-2014, 08:46 AM | #23 |
Member#: 245787
W. Canada
Vehicle:GD Race Car |
I have a q-rack and there are no issues with the DCCD as there is no steering angle sensor for the 04's and I thought it wasn't until 08 but I haven't really looked into it.
05-02-2014, 10:16 AM | #24 |
Member#: 72713
BAIC
05-02-2014, 10:53 AM | #25 |
Member#: 32792
somebody get a part number for this bad boy.
