Welcome to the North American Subaru Impreza Owners Club Saturday October 31, 2020
Old 10-09-2015, 12:45 PM   #426
ryanoption
Member#: 431795
Trying to find a pic or documentation on this as well. I have a dead stock 2012 WRX with 32k on it and I have the exact same sound decelerating in 2nd usually when going down a steep hill. It sounds horrible and people stare at it like it's about to blow up or something.
ryanoption is offline   Reply With Quote
Old 10-09-2015, 02:10 PM   #427
LatentWagen
Member#: 50315
0806 LGTspecB & Saab
9-2xAero5MT DGM & MBP
LatentWagen is offline   Reply With Quote
Old 11-17-2015, 08:43 PM   #428
stevo_88
Member#: 420002
2012 WRX Ltd Hatch
Keeping this thread alive.
I've noticed my third gen 2011 WRX making the same gear whine noises mentioned in this thread since soon after owning her. Second gear, deceleration in the 1750-2500 rpm range. Just as you approach a corner or come to a stop you hear a loud rattle for a second or two. The noise is louder if you abruptly let off the throttle vs gently let off. It's seems odd that it only happens in that rpm range in that gear.
The video below is a good example of the decel noises my 2011 WRX makes and what I believe other third generation WRX and STi owners are hearing too. I've drove a 2009 WRX and a 2014 STi along with my own 2012 WRX - seems like stock or not, this is a common noise for third gen Subarus. Credit to mrkyle3 for the video:
https://www.youtube.com/watch?v=ohAZNoX_lqo
I thought all along it was a loose heat shield like many others but apparently it's not. It seems pretty clear it's inherent to the style of gears used in the performance driveline of the WRX/STi. I'm ok with that. As long as nothing is gonna break on me in there, I'm still gonna drive it like I stole it.
stevo_88 is offline   Reply With Quote
Old 05-12-2016, 10:50 PM   #429
Asymmetry
Member#: 92646
MY03 WRX Toaster
Angry Exedy OEM replacement clutch review
Update for those considering Exedy OEM replacement clutch for Subaru.
EDIT: what I thought was a new clutch rattle was infact a broken downpipe hanger. Anyone who think they have a rattle, have a look at your downpipe hanger, it will easily break if your aftermarket exhaust hits a speedbump.
Asymmetry is offline   Reply With Quote
Old 05-12-2016, 11:25 PM   #430
n2oiroc
Member#: 141952
20 Audi S4
the 08-14 wrx clutches are just crap. my stock 2011 clutch wouldnt hold stage 2 power with under 10k on it. clutch looked like new when it was pulled. the throwout bearings also fail early. i went with a stage 1 exedy and it held great, but the pedal was a bit stiff and the throwout bearing sounded like you were shaking a can of spray paint when letting the clutch out. deceleration noise was minimal. not nearly as bad as the vids posted.
n2oiroc is online now   Reply With Quote
Old 03-20-2017, 10:01 AM   #431
2ball
Member#: 464330
Originally Posted by LatentWagen View Post
I believe I have this issue, what does the picture have to do with anything?
2ball is offline   Reply With Quote
Old 05-17-2017, 08:47 PM   #432
cam.kenn
Member#: 467266
2010 wrx
dgm
Still no resolve to this? I've been considering a new clutch and bearing/ heatshield delete but was hoping someone would have figured it out by now?!
cam.kenn is offline   Reply With Quote
Old 07-30-2017, 12:46 AM   #433
Dut117
Member#: 471939
07 Impreza 2.5I
Grey
Default The unstoppable noisy gremlin
Ive had the decel noise in my 2.5I since the day i bought it. I'm obviously N/A so the waste gate theories are shot. I'm the second owner, had the car since 2012. Ive since added a 1.5 inch lift, new struts, 255 16 r16 tires, HD front axles, multiple fluid changes in the 5MT tranny and rear diff, driveline carrier bearing, ball joints, tie rod ends and multiple curses. None of these changes had any effect on the noise. Still sounds like the tranny is gonna bust through the floorboard when decelerating, mostly in third and very noticeable in 5th on the freeway. I'm at 127k miles and hoping but doubting that Subaru figures it out before my 200k service is due.
EDIT: Alos checked every single heat shield front to back as well as driveline clearance.
Dut117 is offline   Reply With Quote
Old 07-31-2017, 12:27 PM   #434
teewrxx
Member#: 455777
2013 WRX Hatch
Plasma Blue Pearl
I just got this decel noise in 1st and 2nd (worse in second) and I get it the most when I u-turn to the Left versus the Right. It also makes the noise in neutral as well as in reverse. I have no idea what the hell the sound is, i can't recreate it consistently but it it usually happens when I first turn the car on then going in reverse. I feel like the sound comes from underneath the car and its like there was a giant rat in the pipes trying to scratch its way out of there.
Let me tell you though that I recently got this happening when I was burning my clutch in stop and go traffic going up a 20-30% grade on a 2+ mile hill.
teewrxx is offline   Reply With Quote
Old 08-01-2017, 03:06 AM   #435
teewrxx
Member#: 455777
2013 WRX Hatch
Plasma Blue Pearl
Originally Posted by Scubarex View Post
I have the same noise in a bone stock 2014 WRX with 16,xxx miles, not nearly as loud as some of the videos posted in this thread, but it is there on deceleration off throttle in 1st and 2nd gears between 1,500-3,000 RPM. Took it to the dealership and had a guy ride with me, it was noisy out and lots of traffic. Was able to produce the sound for him but didn't do it justice to how bad it sometimes sounds. He said the noise is perfectly NORMAL for WRXs and that it's just the transmission.. He said "Papi, just enjoy the car".
I have been enjoying that piece of mind for a bit, but every time I hear it, I think about taking it to another dealership for a second opinion.
Anyone else experiencing this on a stock 2012-2014 WRX?
Yes sir! Other than my CBE, she's bone stock. I get the metal clanging/grinding on reverse, decel in 1st and decal in 2nd after the engine drops load in those gears so around 2-1k RPM. It gets the noise ok neutral as well and I reproduce it the best when doing a u-turn. Did you find a solution?
Old 09-12-2020, 01:45 PM   #436
jeffambo
Member#: 507933
2013 WRX Base Hatch
Obsidian Black Pearl
Originally Posted by S_Faux View Post
Yes, yes, yes, yes, THANK GOD.
On my MY02 Wagon this was literally the cause of all my problems. I was having clunking during weight transfer from front to rear, vibrations at just under 2K RPM (under power), and grinding during deceleration above 40mph. It was driving me insane.
Yep, I bent those plates jacking up the car.
I have new plates on order from the dealership, but I took the existing outboard rigger plates off and after 3 minutes of beating them back into shape with a hammer (and re-installing them of course) I am no longer hearing a peep from the rear end of the car. Look for part number "41321FA040", although I was told by the parts guy at Heuberger Subaru that this number is different from Sedan to Wagon.
Can someone explain this a little more? Any pictures or anything like this?
I swear this site....Yahoo answers has more users that follow up once they find a solution.
I think the problem is that you don't get an alert when someone replies to a thread you've posted in, I constantly realize someone replied to me weeks prior but I didn't realize because unless I manually go to that thread, there's no alert or anything
jeffambo is offline   Reply With Quote
Deceleration Noise Issues: Clutch Only. WRX Pilot Warranty Issues & SOA Problems 147 12-20-2002 08:41 PM
Deceleration Noise Issues: Clutch Only Dat Southern California Impreza Club Forum -- SCIC 13 04-19-2002 04:44 AM
Decelerating noise Blindeye_03 Brakes, Steering & Suspension 8 04-11-2002 05:28 PM
Deceleration noise similar to WRX liberty Warranty Issues & SOA Problems 1 02-13-2002 09:44 PM
Deceleration Noise Poll (popular demand) FargoRS Warranty Issues & SOA Problems 0 12-06-2001 11:43 AM
