04-08-2010, 10:56 PM | #1 |
Member#: 156240
Vehicle:02 WRX 06 Impreza |
Whats a good High Pressure Hose Nozzle to use?
I've been trying to find a decent priced good quality high pressure hose nozzle and I went to loews and bought myself a 20 dollar one and it sucks. And to get anything better then that I'd have to invest in a gas or electric high pressure machine. So where can I find a good high pressure nozzle that I can simply use on the hose!?
04-09-2010, 05:25 PM | #2 |
Member#: 42303
NESIC
Vehicle:2004 WRX Rally Blue |
I have something like this.
http://www.amazon.com/gp/product/B0001L0DFA/ref=pd_lpo_k2_dp_sr_1?pf_rd_p=486539851&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B0015AUOSC&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=1A534DFN300J93K98DTB Got mine at home depot. The one I have is a Goodyear, and apparently it's impossible to find. Last edited by jefmcc; 04-09-2010 at 05:32 PM. |
04-09-2010, 06:33 PM | #3 |
Member#: 82243
Vehicle:13' BMW X3 35i |
You won't get high pressure without a pressure washer. If you're not satisfied with normal nozzle attachments your water flow rate might be low. Usually ones that have like 5 different spray patterns work well, if you need more than that well, you're asking too much or you have insufficient water flow.
AC high pressure hose interchange? | Superorb | Service & Maintenance | 23 | 10-29-2007 09:21 AM |
Wanted: A/C High Pressure hose for any Impreza/WRX/STi 05+ | Superorb | Private 'Wanted' Classifieds | 0 | 10-11-2007 09:30 AM |
Impreza AC high pressure hose leak | Malik | Service & Maintenance | 3 | 04-07-2007 08:50 PM |
What are good Tire Pressures for track use? | Onedwn5up | Tire & Wheel | 0 | 10-05-2006 09:37 PM |
what pressure hoses connect to the turbo? | flp_sde | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 1 | 11-17-2005 01:31 PM |
