01-07-2013, 01:25 PM | #251 |
Member#: 323869
W. Canada
Vehicle:2000 ST-outback White/Grey |
Yep, generally the pipes are purged with argon to provide an inert environment on the back which prevents sugaring/oxidation of the weld.
01-08-2013, 09:53 PM | #252 |
Member#: 256615
Custom muffler I made for my car. Oem sti shaped muffler with 3" mandrel bent perforated core with ceramic packing.
01-20-2013, 05:21 PM | #253 |
Member#: 322678
i bought some mandrel bends a while back to build a set of headers for my bug eye project. decided im going to sell it anyways, so im using them to build a set of UEL headers for my friends 2.5rs. pictures arent the greatest and im only about a 1/4 of the way done haha once the other collector i need comes in i'll be able to finish them and see how it sounds
done with 16g 1.75" steel tube Last edited by RockNRace03; 01-30-2013 at 09:25 PM. |
01-27-2013, 09:35 AM | #254 |
Member#: 239233
Vehicle:1998 LGT White |
Build an axle back for my legacy
01-27-2013, 10:00 AM | #255 | |
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT 1996 Impreza coupe |
01-28-2013, 07:02 PM | #256 |
Member#: 345207
Vehicle:2005 Impreza WRX Rally Blue Pearl |
I want custom dual straights on my subie!
01-28-2013, 10:13 PM | #257 |
Member#: 141238
Vehicle:2006 STi Crystal Gray Metallic |
01-28-2013, 10:48 PM | #258 |
Member#: 141238
[IMG][/IMG]
3" to a 80 series flowmaster (that was chopped 3 inches to fit) then back out to two 3" tailpipes that are finished off with SRT-8 Jeep black chrome tips |
01-30-2013, 09:25 PM | #259 |
Member#: 322678
05-20-2013, 08:22 PM | #260 |
Member#: 185910
Vehicle:2007 FSXT |
Come on I want to see some more awesomeness!
06-10-2013, 01:12 PM | #261 |
Member#: 324962
BAIC
Vehicle:02 WRX |
Would it be ok to arc weld an exhaust system. Its inconvenient for me to mig and I cant tig worth a damn.
06-10-2013, 01:26 PM | #262 |
Member#: 176128
South East
Vehicle:5862 ...baby boosted |
No reason why not. They make some good rods that leave a nice bead too
06-10-2013, 05:52 PM | #263 | |
Member#: 260314
Vehicle:2007 STI silver gray metallic |
There's no reason not to if they are solid welds. However, if you have access to it, I would learn to TIG if I were you. So nice! |
06-11-2013, 01:22 AM | #264 |
Member#: 324962
BAIC
Vehicle:02 WRX |
^ya I'm pretty decent at arc and mig, but I always shock myself or burn holes with tig. I'll practice some more some day.
06-11-2013, 07:00 PM | #265 |
Member#: 359209
Vehicle:2013 Impreza Dark Grey Metallic |
Gonna have to save this thread for when I start working on my own. Love the beautiful stainless here, as well as all the bench-top shots.
Do have some questions relating to people's builds, to give me a chance to plan my own. What alloys are favored for your exhaust work? Personally, I'd consider marine-grade 316, but maybe that's just because I live in the north-east... What sort of tuning are you planning into your builds? I figure that hi-flow components are a must, although I've heard that equal-length headers don't work quite as well on our boxers. Just as a reference, I've got a 2006 outback with a N/A 2.5L, although I'm thinking about rebuilding it with a turbo, or swapping to an STi motor. The exhaust work will probably be part of the rebuild/swap. Still very much in research phase at this moment. |
06-21-2013, 06:30 PM | #266 |
Member#: 147776
Vehicle:2001 Forester 2013 Scion FR-S |
Where is an affordable place to pick up stainless piping, bends, and flanges?
06-22-2013, 01:07 AM | #267 |
Member#: 179783
W. Canada
Vehicle:2002 WRX Silver STi swap 380wph!! |
It's been covered a lot in this thread and forum, Columbia mandrel bends is one, burns stainless is another. Reid Washbon has some nice exotic stuff.
06-22-2013, 01:56 AM | #268 |
Member#: 39149
06-22-2013, 02:17 AM | #269 |
Member#: 104878
TXIC
Vehicle:02 wrxbastardchild aw, MPS 2.34 breaking in |
How thin would any of you go for a SS system? Im thinking .020 304 for a dp back system. Car doesnt get used on the street but for limited runs. Think I could go thinner and it not get beat to crap? Im trying to keep it as tight to the bottom as humanly possible.
06-22-2013, 07:06 AM | #270 |
Member#: 193014
Vehicle:02 WRX WRB, 05 STI FPGreen E85 400+whp |
06-22-2013, 12:58 PM | #271 |
Member#: 179783
W. Canada
It's going to be impossibly hard to find that wall thickness in anything, even 321 or inconel
Thinness wall available for 304 is 0.035 and you won't be able to find that in a tubing size larger than 2" very easily. 0.049 and 0.065 is pretty standard, both should be okay for what you are looking to do. You could step up to 321 and to a really tight fitting 2.75" exhaust in 0.035" that's what my plan is... |
06-22-2013, 05:17 PM | #272 |
Member#: 104878
TXIC
Maybe I can talk someone into making some .020 ss 3in for me then.
06-22-2013, 06:59 PM | #273 |
Member#: 179783
W. Canada
So you want someone to roll stainless sheets and seam weld it? I don't see the benefit of that and it Sounds expensive to me, better off using 321 0.035 it can handle the heat way better than 0.020 304, it will be too weak and you will risk cracking.
06-22-2013, 07:33 PM | #274 |
Member#: 256615
Your asking for trouble with .02" tubing. And no one will just make a small amount of that size. You need to order a **** ton of material from a mill to get a special size. I wouldn't do anything less than .035" and it would have to be 321 or inconel.
06-23-2013, 03:21 PM | #275 |
Member#: 104878
TXIC
Why so thick and why not 304? Its just from the dp back. People are using aluminium for catbacks and this isnt a street car.
Similar Threads | ||||
FS: 2 STI hood scoops, stock STI exhaust, 2.5RS/TS/OBS custom exhaust, and more! | dlong27 | NESIC Private Classifieds | 18 | 03-12-2010 03:11 PM |
Another Exhaust thread, sorry:Building a custom performance exhaust? | agilitymaneuver | Normally Aspirated Powertrain | 1 | 09-02-2008 12:59 AM |
Custom intake thread | Machine Age Victim | Member's Car Gallery | 4 | 04-27-2004 02:25 PM |
Custom Exhaust - Skips Exhaust Plaistow NH | WRXBanish | New England Impreza Club Forum -- NESIC | 3 | 11-14-2003 06:50 PM |
Trade! my custom Exhaust on your RS Exhaust! | SONofSAM | Bay Area Impreza Club Forum -- BAIC | 7 | 04-13-2002 02:15 PM |
