Welcome to the North American Subaru Impreza Owners Club Sunday August 19, 2018
Old 11-01-2005, 01:17 PM   #1
Crazykev
Member#: 93667
'03 Build'n a 2.12L
331whp/331wtq
Default Cost for WRX front ring & pinion
Hey guys,
Who here know what the cost is for a new front WRX ring and pinion? I am going to be putting in a LSD in the front and want to replace the R&P so I don't have to crack the tranny open again for a long time. Also replacing ALL bearings. Already have new synchro cones and hubs and RA gears.
Thanks,
Kevin
Crazykev is offline   Reply With Quote
Old 11-01-2005, 04:45 PM   #2
sjl1614
Member#: 56791
06 OBS
It depends if you take the trans out....that will add cost to the job
sjl1614 is offline   Reply With Quote
Old 11-01-2005, 04:48 PM   #3
Acostafan
Member#: 67398
2002 Now with 100%
RDA of 2.5l Goodness!!!
I just had mine replaced along with my center diff, bearings, and syncros. Seems like I remember them being $300ish but PM SubieGal, she can get you pricing.
Acostafan is offline   Reply With Quote
Old 11-01-2005, 04:50 PM   #4
Crazykev
Member#: 93667
'03 Build'n a 2.12L
331whp/331wtq
Sorry, I am only talking about the cost for the part. I can't find it on-line anywhere?
I know I can get it from my dealer, but want to have another option if they are WAY high.
Thanks Acostafan! I will hit her up.
Kev
Old 11-01-2005, 04:57 PM   #5
Acostafan
Member#: 67398
2002 Now with 100%
no problem....I think getting them through her is cheaper but again, she can give you the 411 on all that...
Old 11-01-2005, 05:04 PM   #6
Crazykev
Member#: 93667
'03 Build'n a 2.12L
331whp/331wtq
I sent her a PM. $300 doesn't sound too bad, hopefully that is all it cost.
I have seen the 4.44 R&P sets go for $800-$900 and thought the front was $500 of that.
Kevin
Old 01-30-2006, 05:12 PM   #7
o2sys
Member#: 43842
200? WRX STI
Ok besides the parts...how hard is it to change the ring and pinion on the R160 diff?
o2sys is offline   Reply With Quote
Old 01-30-2006, 05:31 PM   #8
Crazykev
Member#: 93667
'03 Build'n a 2.12L
331whp/331wtq
Have you ever setup a R&P?
It is about as simple as could be as long as you have done them on any car before.
Old 01-30-2006, 05:36 PM   #9
ChrisDP
Member#: 5879
'02 WRX SDN 5MT
STS Civic, ITA Integra
You could also try Liberty Subaru... I forget their phone number, but their parts prices are pretty good.
The ring gear is easy to swap, just a few bolts that hold it to the differential. As for the pinion gear, that's a one piece part combined with the input shaft. So all the gears and bearings and such need to be pressed off the old shaft onto the new one, to replace the pinion. I had a shop do mine, it's a fairly involved pressing operation since there are a number of sleeve bearings and such that need to be in just the right place.
ChrisDP is offline   Reply With Quote
Old 01-31-2006, 03:51 AM   #10
Pacobeagle
Member#: 8775
2010 "Zed" 1000
Orange/White
Actually, changing the front ring and pinion takes about 5minutes! That is, after you've taken the tranny out and completely split the cases.
But you say you want to replace the bearing so that's going to take a bit longer. I simply bought a used tranny with a broken 2nd gear for $250 and used whatever parts I needed. Plus, I still have some other gears and the like if ever I need them.
Jose
Pacobeagle is offline   Reply With Quote
Old 01-31-2006, 08:52 AM   #11
Crazykev
Member#: 93667
'03 Build'n a 2.12L
331whp/331wtq
I was talking about the rear R&P. The front is much harder to do.
FS CA Feeler: 02 WRX Brakes Front and Rear, R160 3.90 Ring & Pinion, Rear Axles ViperWRX Suspension/Brakes/Handling 38 08-19-2010 10:21 AM
FS: CT - 4.44 Front Ring & Pinion drewdogg Drivetrain 13 06-02-2010 01:19 PM
Front ring and pinion for wrx 5mt LiquidForce Private 'Wanted' Classifieds 1 03-08-2008 10:26 AM
WTB: R160 3.90 Ring & Pinion & 04 STI 6MT axle stubs Crashed_Again Private 'Wanted' Classifieds 0 02-28-2008 12:49 PM
Locating: Tranfer gear, front/rear ring & pinion in tranny FuJi K Transmission (AT/MT) & Driveline 4 10-27-2004 10:35 PM
