#26 |
Member#: 142868
Vehicle:2014 BRZ LIMITED Satin White Pearl |
![]() You need a DP, although a full ext. would be better
#27 |
Member#: 150794
SCIC
Vehicle:Qcab dakota 4x4 LT1 Formula Firebird |
![]() Since the car is stock, I think you'd be making a huge mistake jumping right to that horsepower level. It sounds like you're aware of that...
Since you will need these parts to EVER hit that horsepower level anyways, I'd recommend a turbo-back exhaust, new uppipe, fuel pump, injectors, boost control solenoid, and then a professional tune. That will make MUCH more power than you have now, as well as being closer to your final goal. Talk to whoever will be tuning your car about what injectors to run now that will also suffice for your goal later. Go with that, and then come back and talk to us when you get bored of it in a few months ![]() |
#28 |
Vendor
Member#: 155450
Vehicle:2007 FXT WRB |
![]() You will most definitely, 100% need pistons. This isnt an if, its a sure thing. I would be suprised if it lasted more than a few weeks at that power level on stock pistons. May as well toss a set of mild cams in while you are at it.
Here is the mod list I would suggest. TD05-20G 7cm TurboXS 44mm EWG kit TurboXS turboback high flow cat or catless. RFL axleback or magnaflow axlebakc depending what you want for sound. TurboXS FMIC Deatschwerks 750cc injectors CP forged pistons New water pump, timing belt, tensioner TGV deletes Port/polished stock exh manifolds -I can do it, or Grimmspeed, I wouldnt trust anyone other than either myself, themadscientist (who isnt doing porting for people right now) or Grimmspeed to do it. Walbro pump AEM alch injection kit Stage 1 clutch STI 6 speed tranny swap. That will get you right about where you want to be, and compared to where you are now, the car will be terrifying. Honestly, I dont recommend going to this setup right now. If you are stock, even going to an EVOIII-16G and a good TMIC will be a HUGE increase, and would likely pull harder than what you think 375whp would feel like. You are also looking at EASILY $10,000 to get to your 350-375whp level reliably. |
#29 | |
Vendor
Member#: 155450
![]() Quote:
You have an 05 STI, he has an 05 WRX, what it will take to hit 375whp on his car is a LOT more than what it takes on your car. The engine and transmission mods alone will cost him easily 5k more than what you spent. I dont mean to poop on your reply, but unfortunately your post couldnt be further from relevant to this discussion. ![]() |
#30 |
Precious ❄
Member#: 603
NESIC
![]() ^^ What Defiant said
#31 |
Member#: 168386
![]() My bad thought he said he had an STI.
Anyways, go with a 20g if u got a wagon. We have one here in chicago pushing 375 on a stock block with 130k miles. 100 oct ftw. 5 Speed ftl |
#32 | |
Vendor
Member#: 155450
![]() Quote:
BTW I hope you didnt take my reply to you as me being a dick, I dont mean it that way, but sometimed I tend to be a bit blunt and come off harsher than I mean. I dont always translate well online ![]() |
#33 |
Member#: 150794
SCIC
![]() He will not have that stock block very long.... And the guy said he's going to be running pump gas 91-93, NOT 100 octane, so again that example is out the window.
#34 |
Vendor
Member#: 155450
![]() Not to mention the HUGE power difference between 91-93 octane and 100 octane. Minimum 30whp. MINIMUM.
Also, I would question the validity of that dynos numbers. Unless he hasnt been doing it for long. And I would bet he wont be ![]() |
#35 |
Member#: 212399
NWIC
Vehicle:09 wrx 301hp/328tq '00 miata blue |
![]() why, you would need about 138 steeds to pull your car along!
#36 | |
Member#: 187013
Vehicle:2013 ST |
![]() Quote:
I think you need to do A LOT of research. I dont want to sound rude, but you have no idea what you are getting yourself into. I have no idea what I would do if I was trying to put down the numbers you are, and I consider myself to have a good knowledge of stage 2 stuff. Spend a few weeks researching and reading a lot of threads, and then tell us if you still want 375 whp. |
#37 | |
Member#: 120273
SWIC
Vehicle:06 WRBWRXWGN Now with 100% more Spec-C |
![]() Quote:
You know the old saying: Fast, Cheap, Reliable - Pick any two. |
#38 | |
Member#: 143522
SWIC
Vehicle:1987 Brat GL 4 Speed 98 Forester L (RIP) |
![]() Quote:
you realize the OP user name has "chick" in it right? pretty sure pipchick has de vageen |
#39 |
Vendor
Member#: 155450
![]() oops lol
If so, then SHE has an 05 WRX ![]() |
#40 |
Member#: 181927
Vehicle:99 RS - RBP 10 DSP |
![]() i have a 350 whp / 375 tq 06.. and trust me it takes a lot..
20g, fmic, intake, bigger pump, injectors, TBE.. ( on a 2.5 ) its fast, i've slowly gotten to this point and its still a lot too handle. seriously go stage 2 and go from there. |
#41 | |
Member#: 143522
SWIC
![]() Quote:
any forged internals??? cuz that sounds like its a ticking time bomb. is it a conservative tune? low boost? |
#42 |
Member#: 219009
Vehicle:2018 LBP WRX Ltd. 2005 PSM WRX - St.2 (rip) |
![]() You need a good amount of money!!
#43 |
Member#: 207826
Vehicle:85k 2002 WRX Correct Fitment Crew #034 |
![]() He/she will also need forged rods as well.
#44 |
Member#: 135893
NWIC
Vehicle:2017 STI WRB |
![]() Might as well sell it and buy an STi. Seriously. Much better platform for that kind of horsepower. I think I'm headed that way within the next year or so - stage 2 and the gutless 1st gear just aren't doing it for me.
Plus I drove my friend's STI with an E85 Stg 2 tune, and it opened my eyes. ![]() |
#45 |
Vendor
Member#: 155450
#46 |
Member#: 207826
![]() '05 WRX dude. They aren't forged, and the op is looking for close to 400.
#47 | |
Vendor
Member#: 155450
![]() Quote:
#48 |
Member#: 207826
![]() Having owned 2 different EJ205s, they are not forged.
![]() And no need, I have a built 2.5 right now. |
#49 |
Vendor
Member#: 155450
![]() okey.
![]() Regardless, time has proven the stock WRX 2.0L rods ok till @400whp. |
#50 |
Member#: 181927
Dyno Numbers and you- What do you need to hit XXX hp? | Defiant Autospeed | Newbies & FAQs | 676 | 02-19-2024 10:20 AM |
what do I need to hit 250whp? | juvenescence | Newbies & FAQs | 29 | 01-15-2019 02:38 PM |
I’m flying to Orlando. What do I need to do in the airport and what to bring home? | KingGalantVr4 | Off-Topic | 37 | 01-14-2010 11:49 PM |
WHat will i need to get 350 to 400hp out of a 2.2t | TURBO KID | Built Motor Discussion | 3 | 03-02-2008 04:10 PM |
I want to do my own 30,000 mile service, what do I need to do? | Drav | Service & Maintenance | 12 | 06-20-2005 06:43 AM |
