#251 |
Member#: 462060
VIC
Vehicle:2011 WRX STI White |
![]() Its really just preference man. People will make this very scientific but the bottom line is as long as it meets the build spec it really doesn't matter one bit. If you want to keep it safe, just stick with Mobile 1 and step up to M1 5W40 if you want to beat on it. I've seen an 700hp eagle talon running on nothing but Valvoline 10W-30 conventional. The owner even admitted to sometimes just buying what ever he could find on sale in a 30-40 weight.
#252 |
Member#: 462060
VIC
#253 |
Member#: 332361
SCIC
Vehicle:2005 Wagonista! SWP |
![]() It's actually reasonably priced & their Signature Series protects 4-5x better than most synthetic oils not to mention all of it's other great qualities. Everything they sell is the best you can find. All you have 2do is sign up as a distributor/dealer & you get a much better price.
#254 | |
Member#: 462060
VIC
![]() Quote:
#255 |
Member#: 332361
SCIC
![]() I'm not sure what you're getting at.
#256 | |
Member#: 459629
International
Vehicle:2017 WRX base WR Blue |
![]() Quote:
Got any independent proof of that? I didn't think so. ![]() |
#257 |
Member#: 470981
Vehicle:2008 Legacy GT spec DGM |
![]() I didn't feel like sifting through 11 pages but has anyone used Pentosin in their car? It's a European spec oil but I'm curious to try it. My co-worker has an Audi and he sweats by it. We stock it at the shop so I'm thinking about giving it a shot. I've been using gtx high mileage and can't say I'm burning oil any quicker than I normally do and with 110k on the clock, I dont know if I want to switch over to full synthetic now.
#258 |
Member#: 462060
VIC
![]() Amsoil has a habbit of claiming their oil is special because you can run it for 25k or what ever. What they don't mention is that you can only do that in a vehicle that doesn't burn any oil (most vehicles do). You can probably run any A3/B4 synthetic for 25k miles if none of it gets burned.
#259 |
Member#: 332361
SCIC
![]() Honestly, I burn a whole lot less oil using Amsoil not to mention it holds up to whatever I throw at it. In my 500hp diesel running an oil bypass system I've gone 50K+ miles with many more miles to go.
#260 | |
Member#: 767
Vehicle:04 FXT 20 OB Onyx XT |
![]() Quote:
Brand doesn't matter. Just look for oil with good specs. Hard to beat Porsche and MB specs and most Wal-Marts carry three 0W40's for $25-$30 for 5 qts. that meet all of the Euro specs (except that M1 no longer meets BMW LL). Go for the Pentosin if you can get it that cheap. Although you might want to go with a High Mileage synthetic like Mobil 1 10W30 since you've used conventional for so long. A typical Euro oil may start cleaning up some sludge and you may get leaks from your gaskets/seals. There's also a lot to be said for sticking with what you've been doing since you don't have any issues. |
#261 | |
Member#: 767
![]() Quote:
As a user of a LOT of brands, including Amsoil as a PC, the benefit of running Amsoil isn't the same today as it was only 5 years ago due to huge improvements in base oils and additives and other oils closing the performance gap. I used Signature Series and it wasn't a good fit for my application. It had decent amounts of anti-wear additives, and boatloads of calcium for extended drains, but still a so-so HTHS and KV like any typical GF5 5W30. If I ran SS today, I would use the 0W40 but it doesn't make much sense to me if I have to pay an annual fee to get a discount and can get 0W40 from Wal-Mart or Amazon for <$30. As current oil manufacturers/blenders are scrambling to reformulate their oils due to LSPI and intake valve deposits, Amsoil has followed suit and reformulated their Signature Series: https://bobistheoilguy.com/forums/ub...ew_formulation Lower calcium, ZDDP, and TBN, but at least a nice dose of the multi-functional additives moly and boron. |
#262 | |
Member#: 301554
BAIC
Vehicle:2002 WRX Wagon PSM 2002 WRX Sedan JBP |
![]() Quote:
I’ve read a lot of oil advice over the years on NASIOC, and this is the most succinct and lucid example I have ever encountered. |
#263 |
Member#: 462060
VIC
![]() Well, if that works for you so be it. Also, your Diesel probably has a huge sump, I am willing to bet any cheap synthetic would last just as long. One day this debate will be moot. We'll be arguing about which LiPo cells are the best for our electric vehicles and why the dielectric material in brand x produces less voltage spikes on discharge.
#264 | |
Member#: 479603
![]() Quote:
#265 |
Member#: 338312
![]() I'm currently using motul x-cess 5w40 in my 2017 sti. Now I can not find this oil .. So i'm between redline 5w40, valvoline, fush or liquimoly.
what do you recomend me ? I only have borla catback and rce yellows. |
#266 |
Member#: 332408
![]() With all this talk about low speed pre ignition (LSPI), how do the HD oils compare, e.g., T6, etc.?
Does low level of calcium indicate that the oil reduces LSPI? The mainstream 5w30 oils are all approved for LSPI and SN Plus, but the HD oils don't have the same approval. |
#267 | |
Member#: 337075
BAIC
Vehicle:2016 STI Limited Silver |
![]() Quote:
However, I kept a 2500 mile OCI. |
#268 | |
Member#: 767
![]() Quote:
The Subaru 5W-30 still has high calcium. If they reformulate it, don’t expect it for another 6-12 months. They were also late to the API SN party as well. And FWIW, Subaru Japan still allows high SAPS 0W-30 and 5W-40 in DIT’s. An alternative for those that want a robust lower SAPS oil is Motul X-clean 5W-40. And while it’s technically still high SAPS, Castrol 0W-40 has less calcium and ZDDP than most other 40 grade oils. I expect other reduced SAPS 40 grades to be popping up in 2018. I think there is an ACEA C3 M1 0W-40 ESP in Europe now. |
#269 | |
Member#: 332408
![]() Quote:
https://bobistheoilguy.com/forums/ub..._5W40_CJ-4/SM_ Calcium went up to 2,xxx. It appears that's a pretty average level. For my application (90% street driven), Mobil 1 5W30 Dexos 1 Gen 2 might be the better option, given talks about LSPI. |
#270 | |
Member#: 767
![]() Quote:
Or RT6 5W-30 MV if you don’t want to run a oil that shears to a 20 grade. |
#271 | |
Member#: 332408
![]() Quote:
Edit: Looks like the 5w30 has slightly lower calcium. https://bobistheoilguy.com/forums/ub..._Multi-Vehicle Looks like this is the oil to have if you want a less shearing 5w30 oil. Last edited by ayau; 03-05-2018 at 04:38 PM. |
#272 |
Member#: 767
![]() Winner winner chicken dinner! You can order RT6 5W-30 MV from NAPA and O’Reilly’s.
#273 |
Member#: 471038
Vehicle:2018 WRX WR Blue |
![]() I'm not sure if this is right place to ask, has any noticed that pennzoil plat doesn't make a 5w30 anymore. The only pennzoil plat that is in 5w30 is the Euro L or high mileage ver. There are still 5w30 out there but at crazy prices.
#274 |
Member#: 767
#275 |
Member#: 471038
![]() i have. i usually try to google and search before i post. maybe i suck at searching this particular topic. Just trying to see if anyone else is seeing the same thing or not in their area. cause i've looked been 3 walmarts here and nothing but euro L in 5w30
