Welcome to the North American Subaru Impreza Owners Club Friday March 29, 2024
Go Back   NASIOC > NASIOC Subaru Models > Tribeca Forum
Old 08-30-2019, 02:26 PM   #1
hfd
Member#: 498680
Default ac problems
any one know if both radiator fans are supposed to come on when u turn on ac.The one on drivers side is only one coming on.Pressure is 28 low side and 350 high.shouldn't both fans be coming on.Get cold air some then it will get hot then get cold again.Any one know if it could be fan problem.Tks in advance
hfd is offline   Reply With Quote
Old 12-12-2019, 09:50 PM   #2
NighthawkSTI
Member#: 495630
pretty sure only one fan will come on with the A/C unless the engine coolant temp is over 207 degrees...then both fans will come on
if you have auto climate control it blow cool until it drops to say 65 degrees, but then it should stop....not start blowing warm air.
Do you have the temp control set to the coolest temp or to 85??? Set it all the way to cool and see if it just blows cool air only
NighthawkSTI is offline   Reply With Quote
