Welcome to the North American Subaru Impreza Owners Club Saturday July 11, 2020
Old 11-06-2009, 06:25 AM   #1
flacopower
Member#: 226984
2002 wrx
Default New flywheel or resurfaced?
Hey at 90,000 miles my clutch is pretty much dead so I am replacing it next weekend. My question is should I just resurface my flywheel, or purchase an entirely brand new OEM unit? I have read on here that they can't be resurfaced, while others have had no problem resurfacing their units. So which one is it?
flacopower is offline   Reply With Quote
Old 11-06-2009, 07:49 AM   #2
RacecaR
Member#: 228070
.... t('-'t)
Unless you want the performance gain of a lightweight flywheel, I would go for the resurfacing, I don't see any reason you couldn't resurface the original. All you would need is a machine shop with a blanchard grinder
I wouldn't pay more than about $50, even if they remove the dowel pins. Also there are "insert" style flywheels that have a removable friction plate for ease of replacment in the future.
RacecaR is offline   Reply With Quote
Old 11-06-2009, 07:49 AM   #3
rexblake
Member#: 178426
2010 S4
Gray
Both. According to Subaru you "can't" resurface your stock flywheel. However, when iwas getting mine priced out even the dealership said they resurface them and have had no issues. Just get it resurfaced if you are sticking with oem.
Old 11-06-2009, 09:25 AM   #4
Tim-H
Member#: 65751
'10 VULVA
I had mine resurfaced when I got the clutch replaced. Had severe judder when it would engage. I was also at about 90k when I had to replace the original.
Unless you want to run the risk of opening things up again just buy a new one.
Tim-H is offline   Reply With Quote
Old 11-06-2009, 09:28 AM   #5
SS/GNX
Member#: 216014
2005 WRX STi
CGM
I would just buy a new OEM one. You almost always pay more in the end trying to save a buck...
Plus with a new one you have peice of mind. Just try to get a bargain on the new one.
SS/GNX is offline   Reply With Quote
Old 11-06-2009, 10:42 AM   #6
flacopower
Member#: 226984
2002 wrx
How exactly do you bargain for a brand new OEM piece?
Old 11-06-2009, 10:59 AM   #7
Tim-H
Member#: 65751
'10 VULVA
contact Subarugenuineparts
There's a difference between bargaining and a bargain. It's not a new term.
Old 11-06-2009, 11:45 AM   #8
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
I would never resurface another WRX flywheel.
Subaru says not to.
I tried it anyway.
major fail
it was off by 100ths of an inch
which could have completely borked my engine.
I put the entire clutch back together, tranny back in the car
fired it up and the entire car rattled like a 7.0 earthquake
i had to tear it all down again
buy a NEW flywheel, reinstall.......
Subaru says not to resurface them for a reason.
IMO it's not worth the risk.
Subie Gal is offline   Reply With Quote
Old 11-06-2009, 12:00 PM   #9
Davenow
Member#: 23676
Every WRX and STI I have seen with a resurfaced flywheel ended up with problems of some sort.
OEM flywheels are dirt cheap, aftermarket flywheels arent THAT expensive either.
Do the job right. Dont cut your FW.
Davenow is offline   Reply With Quote
Old 11-06-2009, 12:13 PM   #10
flacopower
Member#: 226984
2002 wrx
thanks for the tips guys!! Going with a new oem flywheel couldn't find the 02 so I am going with the 03-05 part number 12342AA071 I heard the only diff is that its heavier to prevent any clanking around.. Also went with the exedy OEM clutch and Pressure plate.
Old 11-06-2009, 12:28 PM   #11
SubaruGenuineParts
Member#: 82767
12342aa071 is the correct pn for your model and year
SubaruGenuineParts is offline   Reply With Quote
Old 11-06-2009, 12:48 PM   #12
Mechie3
Member#: 120152
Is this specific to certain years? I've done 2 clutches in 06 WRX's (2 different cars) and both used resurfaced OEM flywheels with brand new Exedy (OEM) clutches/pressure plates. Neither had any issues.
Old 11-06-2009, 01:18 PM   #13
happs subi
Member#: 200288
2002 Impreza WRX
World Rally Blue
^^^ the 03-05 flywheels are heavier for a reason, they are supposed to help stop the shakes and judders, and they are cheaper
happs subi is offline   Reply With Quote
Old 11-06-2009, 01:30 PM   #14
Byzantium
Member#: 207826
85k 2002 WRX
Correct Fitment Crew #034
<---- has been running a resurfaced flywheel for ~25k miles with no problems at all.
Byzantium is offline   Reply With Quote
Old 11-06-2009, 02:20 PM   #15
Tim-H
Member#: 65751
'10 VULVA
For future reference if people search for this topic:
There will always be people that do things the wrong way and have no problems.
A stock flywheel is cheap and will work better than a resurfaced one 100% of the time. It's a time saver vs removing and taking it to be resurfaced, and gives you piece of mind that it will work correctly the first time you install it. You will only replace it once or twice the entire time you have the car(if you know how to drive a manual correctly). Just do it the right way and get a new one.
Old 11-06-2009, 02:30 PM   #16
ravenlunatic
Member#: 180601
2003 PSM WRX
(>")>==HADOKEN==<(o)
i had mine resurfaced when i upgraded to an ACT HDMM clutch. I didn't have any issues with it until it came time for a new clutch disc cause i was a noob at launching. Maybe it just depends on the person or shop that does the resurfacing?
ravenlunatic is offline   Reply With Quote
Old 11-06-2009, 11:50 PM   #17
Carlito2002WGN
Member#: 18914
2006 WRX
Black with some stuff
This is interesting. I had my flywheel resurfaced and now I am experiencing some issues that I feel can possibly be attributed to the flywheel/clutch. Strange noises. At first, I thought that is was bearing noise, but now I am wondering if there is some engine noise too, caused by the resurfaced flywheel. Damn.. this is really upsetting. I wish I would have read this thread, or one like it, months ago when I installed a new clutch on my car.. I would have just bought a new flywheel!
Carlito2002WGN is offline   Reply With Quote
Old 11-06-2009, 11:54 PM   #18
vinxH
Member#: 159796
2006 WRX
i'll chime in here as well... been on a resurfaced flywheel under a subaru dealership's recommendation for 20k miles already and no issues.
vinxH is offline   Reply With Quote
Old 11-07-2009, 12:06 AM   #19
Onemanparty
Member#: 220119
07 suabaru sty
Ive been on both resurfaced and new, frankly I cant tell the difference.
Onemanparty is offline   Reply With Quote
Old 11-07-2009, 06:55 AM   #20
flacopower
Member#: 226984
2002 wrx
Please don't tell me to search as this is obviously a controversial issue, and even this thread has been back and forth without a conclusive determination as to which is better or worst... I am leaning towards a new flywheel though...
Old 11-07-2009, 08:02 AM   #21
RacecaR
Member#: 228070
.... t('-'t)
It would be interesting to know what the rotating assembly weight v.s. flywheel weight is, being that 100th's of an inch makes it off balance. Also of interest, how many people with resurfaced clutch problems have installed aftermarket pullies?
Old 11-07-2009, 08:13 AM   #22
REX8
Member#: 24038
How in gods name can you make this statement?
Even assuming resurfacing your flywheel is a horrible idea that is VERY likely to cause problems....you can't make the above statement.
REX8 is offline   Reply With Quote
Old 11-07-2009, 08:29 AM   #23
jays05
Member#: 78165
05 STI 35r + e85
I have a resurfaced OEM flywheel in my STI... no problems, even with a nasty 6-puck clutch.
jays05 is offline   Reply With Quote
Old 11-07-2009, 11:18 AM   #24
Tim-H
Member#: 65751
'10 VULVA
Yes it's very easy to make that statement. Buying a new flywheel will work properly everytime you install it. Resurfacing, as we've seen, is prone to problems.
I meant if people search and find this thread in the future.
Old 11-07-2009, 11:50 AM   #25
blackfang
Member#: 131347
2007 Legacy 2.5i SE
98 Z/28, VN 900 custom
+1 to not resurfacing them. Subaru doesn't recommend it as it can cause issues. None of my techs recommend it and every technical engineer and field rep I have spoken to has said the same.
blackfang is offline   Reply With Quote
new flywheel or resurface the old one seanvetter123 Transmission (AT/MT) & Driveline 3 06-09-2012 06:54 PM
Legacy Clutch, replace flywheel or resurface? GrannyWagon Transmission (AT/MT) & Driveline 4 05-27-2009 01:03 AM
new flywheel or resurface? sike43 Transmission (AT/MT) & Driveline 11 06-29-2007 08:51 AM
URGENT WTB: New or resurfaced flywheel for WRX DeusExMachina New England Impreza Club Forum -- NESIC 3 08-23-2004 10:36 AM
New rotors or resurface OEM? tribegolfer Brakes, Steering & Suspension 7 02-19-2004 03:17 PM
