06-08-2014, 09:59 PM | #1 |
Member#: 312024
Vehicle:2011 sti |
help cel code p0024
Was just driving home from wbm and got the code p0024 . Any one ever have this and how to fix?
06-09-2014, 11:47 AM | #2 |
Member#: 312024
Vehicle:2011 sti |
Anyone ever get this code?
06-13-2014, 04:54 PM | #3 |
Member#: 393336
NESIC
Vehicle:2002 WRX Green |
thats an avcs code. you could try changing your oil, checking your oil (is it low?), or cleaning the avcs solenoid. if its none of those issues then it could be a timing issue. is your car running funny?
06-13-2014, 05:09 PM | #4 |
Member#: 312024
Vehicle:2011 sti |
Oil is fine. Car runs fine. Just when I turn it on in the morning it will stumble/shake for a min then it's fine.
Going to buy a new oil control valve for the driver side head and see if that helps. |
06-13-2014, 06:10 PM | #5 |
Member#: 250152
Vehicle:2006 WRX Limited OBP |
Try removing the AVCS filters first. If you arent sure how to, do a search, I believe theres a few write ups here in the forums
06-13-2014, 06:24 PM | #6 |
Member#: 312024
Vehicle:2011 sti |
Thought they didn't have filters anymore.
06-13-2014, 06:56 PM | #7 |
Member#: 250152
06-13-2014, 06:59 PM | #8 |
Member#: 312024
Vehicle:2011 sti |
2011 sti.
06-13-2014, 08:40 PM | #9 |
Member#: 250152
06-13-2014, 10:25 PM | #10 | |
Member#: 310506
South East
Vehicle:2005 WRX STi CGM |
Data log your avcs vvt intake duty cycle etc and see what your numbers are. You shouldnt see more than 1 at idle after the car warms up. I believe there is another parameter that indicates the target vvt advance |
06-13-2014, 10:38 PM | #11 |
Member#: 312024
Vehicle:2011 sti |
If it's more then 1 at idle when warm what does that mean?
06-16-2014, 07:36 PM | #12 |
Member#: 312024
Vehicle:2011 sti |
So once the car was warm it showed 0 for intake and exhaust cam.
06-16-2014, 10:48 PM | #13 |
Member#: 78640
NESIC
Vehicle:19 Tundra 20 Landcruiser | 12 IS-F |
I had the same issue. My post is #12. Code has been gone since I posted that. Easy $180 fix.
http://www.iwsti.com/forums/warranty...ml#post3926889 |
06-17-2014, 03:06 AM | #14 | |
Member#: 312024
Vehicle:2011 sti |
06-17-2014, 06:44 AM | #15 |
Member#: 78640
NESIC
No. Just ask for the exhaust AVCS solenoid. They'll know what you're looking for.
06-17-2014, 07:19 AM | #16 |
Member#: 312024
Vehicle:2011 sti |
Will do. Thanks for the info
06-17-2014, 10:06 AM | #17 |
Member#: 78640
NESIC
It's bank 2 (driver side). They aren't interchangeable.
06-17-2014, 01:12 PM | #18 |
Member#: 312024
Vehicle:2011 sti |
It's on the bottom correct? With the two connectors?
06-17-2014, 01:22 PM | #19 |
Member#: 78640
NESIC
Yes on the bottom. Can't remember about connectors atleast one plug and a ground I think?
06-17-2014, 01:40 PM | #20 |
Member#: 312024
Vehicle:2011 sti |
Ok I know which one it is now.getting it replaced Friday along with some new up pipe gaskets. Car sounds like a sewing machine when given throttle. Very annoying.
06-22-2014, 09:17 AM | #21 |
Member#: 312024
Vehicle:2011 sti |
Problem resolved was just the sensor.
06-06-2019, 09:53 AM | #22 |
Member#: 467372
Vehicle:2004 WRX |
07-30-2019, 02:57 AM | #23 | |
Member#: 504753
On my accessport i put four monitors up with avcs exh. left, avcs exh. right, avcs in. left, and avcs in. right. Exhaust right would go up to 25 and intake left & right would go to 15, but the exh left would stay at 0 and go to 1 once in awhile. So someone told me check my oil, check avcs solenoid for gunk and to go from there. Im taking solenoid out tomorrow... |
