Welcome to the North American Subaru Impreza Owners Club Friday March 29, 2024
Old 09-04-2018, 02:34 PM   #7776
kaeknows
Member#: 357191
2016 WRX
ISM
Originally Posted by LyGuy View Post
Hey all
Picking up a 2017 WRX in 2 days
Skimming through this thread, I'm guessing my wheels from previous car of 18x9.5 +18 is not going to fit at all no matter the tires?
bc coils, 235/40 tires, lots of camber and rolled fenders
kaeknows is offline   Reply With Quote
Old 09-05-2018, 08:58 AM   #7777
LyGuy
Member#: 316998
I'm definitely not about that anymore lol
I'll need to find new wheels then, sad cause my current ones are discontinued for over 10 years now and rare.
LyGuy is offline   Reply With Quote
Old 09-05-2018, 10:15 AM   #7778
Spark263
Member#: 427360
2013 WRX
Do these wider tires require rolling the fenders?
Spark263 is offline   Reply With Quote
Old 09-05-2018, 10:55 AM   #7779
Obviously Tyler
Member#: 395955
2021 Mazda 3 Turbo
2017 MX-5 RF Club
What tires? On what wheel size? Offset? Car?
Obviously Tyler is offline   Reply With Quote
Old 09-05-2018, 03:01 PM   #7780
kaeknows
Member#: 357191
2016 WRX
ISM
just buy wheels that fits.
Old 09-05-2018, 03:34 PM   #7781
ju1es773
Member#: 491088
[deleted]
ju1es773 is offline   Reply With Quote
Old 09-10-2018, 01:56 PM   #7782
Bobby Jones
Member#: 351474
2016 WRX
World Rally Blue
18 x 9.5 + 40. 265 40 18.
Bobby Jones is offline   Reply With Quote
Old 09-17-2018, 11:58 PM   #7783
jcf_dori
Member#: 484219
@Bobby Jones, lowered or standard height? if so what springs
thanks
jcf_dori is offline   Reply With Quote
Old 09-23-2018, 11:01 AM   #7784
milab21
Member#: 157833
2017 WRB STI
2007 WRB STI-sold
18x10 +38, 275/35 RE71R, 5mm spacer up front with extended wheel studs, SPL lower control arms with AST 5100's, SuperPro Roll Center Kit. No fender work but it needs to be done, rubs in the rear. Rear camber is like -2 and the front is like -1.8, have to give a little more negative in the front. Might end up going down to a 18x9.5 and a 265 or 255..
milab21 is offline   Reply With Quote
Old 09-23-2018, 09:38 PM   #7785
Jgz1994
Member#: 409888
2015 WRX
Interesting. You really shouldn’t have to downsize.. maybe find wheels that don’t need the spacer to clear the front brakes, and with 10” wide wheels rolled fenders are pretty much needed.
Also, what spring rates are your AST’s? I have a set I’m debating on selling or installing. How’s the ride?
Jgz1994 is offline   Reply With Quote
Old 09-23-2018, 09:51 PM   #7786
vtwinjunkie
Member#: 415503
2016 WRX limited
black silica
Originally Posted by wiUFsh View Post
Thanks, crispy. Here's another.
What wheels are these???? I think I need these for my car
vtwinjunkie is offline   Reply With Quote
Old 09-23-2018, 09:58 PM   #7787
jayweth
Member#: 440057
2015 WRX
World Rally Blue
Cosmis R1
18x9.5 +35
Stock suspension
255/35/18 tires
jayweth is offline   Reply With Quote
Old 09-25-2018, 06:03 PM   #7788
simon1112
Member#: 473967
Default 265/40/18 on 18x9.5 +38 wheels?
I currently have some 18x9.5 +38 wheels and I'm curious if anyone's running 265/40 tires on lowering springs. I'm on RCE yellows and I know I'll need fender work done, I just want to have some input and hopefully some pictures with that setup. I know a lot of people run 265/35 but being in New York, I want the extra thickness.
Also, anyone have any personal experience with either Continental DWS 06 tires and/or Michelin A/S 3 tires? I want something that'll soak up bumps a bit better and it seems to be the DWS does a better job of that from what I've read. What do you guys think?
simon1112 is offline   Reply With Quote
Old 09-25-2018, 07:26 PM   #7789
milab21
Member#: 157833
2017 WRB STI
2007 WRB STI-sold
Yeah I'm going to have the fenders rolled and go from there.. I have 7k spring rates front and rear, I really am enjoying them. I've only ever driven on lower end coilovers and they just don't come close to the 5100's. You should install them and drive it for a while, I'm sure you'll be happy. What spring rates do you have?
Old 09-26-2018, 10:06 AM   #7790
gti_speed
Member#: 483443
2016 WRX STI
Ice Silver
I run a 265/40/18 Pilot Sport 4S on 18x9.5 -w- coilovers. You'll want to go on TireRack and probably compare how wide those other tires run vs the Pilot Sport 4S but you're definitely going to need a good roll/pull in the rear to not have rubbing. I got it pretty bad on this setup but I was a little lower than RCE Yellows. I'd probably recommend a 255/40 since you are just looking at street tires. I have some posts in this thread if you search for me.
gti_speed is offline   Reply With Quote
Old 09-26-2018, 10:22 AM   #7791
Obviously Tyler
Member#: 395955
2021 Mazda 3 Turbo
2017 MX-5 RF Club
Just go 265/35 Conti DWS06. You'll be fine.
265/40 is tall. 0.7" taller than stock to be exact. Even if it fits your car will be sitting higher and might feel a bit slower.
Old 09-26-2018, 12:29 PM   #7792
simon1112
Member#: 473967
I appreciate the input! I was actually torn between 255/40 and 265/40 but I was curious if anyone ran 265/40. I found your post but I couldn't see the pictures for some reason. Is there any chance you can repost the pictures?
Old 09-26-2018, 12:43 PM   #7793
simon1112
Member#: 473967
I appreciate the input! Yeah I figured 265/35 works fine but according to the discount tire size calculator, the sidewall for 265/35 is thinner shorter than it is for 245/40 and some of the bumps in NY (belt parkway, queens, fdr drive) are already loud on my 245/40 Bfgoodrich a/s tires so I figured I'd get a thicker and a softer tire. I'm okay with the performance decrease as long as it's not drastic. I just don't like how I can drive much faster in my FXT because in my WRX, I'm too concerned about when the next little, but loud, bump will be.
Old 09-26-2018, 09:56 PM   #7794
jrocklage
Member#: 491989
Are you running OEM springs or lowering springs on your setup? I dig the look and recently ordered the same wheels for my 2016 WRX
jrocklage is offline   Reply With Quote
Old 09-26-2018, 11:56 PM   #7795
dylbeau1500
Member#: 480010
2015 Wrx
Ice Silver Metallic
Originally Posted by arterberry13 View Post
Does anyone else run a lower offset wheel? 9 out of 10 people run 18x9.5+38. Just curious to see.
My setup is
18x9.5 +22 245/40/18
Great looking car btw and I was wondering what kinda grill is that?
dylbeau1500 is offline   Reply With Quote
Old 09-27-2018, 01:47 AM   #7796
BRipper
Member#: 417473
2015 WRX
Phatbotti tuned
I'm thinking of getting some Titan 7 5 spoke wheels in 18x9.5 +40 265/35 tires, does anyone have pics of a 2015-2018 wrx with these wheels
BRipper is offline   Reply With Quote
Old 09-27-2018, 03:08 AM   #7797
Ciedric
Member#: 345886
2016 Impreza WRX STI
Crystal black silica
Please help me out!
I'm thinking of buying a 2014 STI (MY2015) and sell my STI '09.
It's on Bilstein B12 shocks with stock top heads and Eibach springs, it dropped around 0,6 inch compared to stock suspension.
On my STI Hatch I run Rota G-force 18" 9j Offset 27 with rolled fenders and BC coils and rear Cusco lower control arms. Bridgestone Potenza S001 XL in stock size 18" 245/40
Can I run the Rota's on the current STI 2014 shock setup???
Ciedric is offline   Reply With Quote
Old 09-27-2018, 08:05 AM   #7798
Obviously Tyler
Member#: 395955
2021 Mazda 3 Turbo
2017 MX-5 RF Club
Originally Posted by Ciedric View Post
Please help me out!
This thread is 2015 and up.
Old 09-27-2018, 10:32 AM   #7799
vlad11591
Member#: 295970
2019 STI
CWP
QQ
Winter is coming, and the last couple of winters in NJ have been pretty awful.
Should I be running smaller tires/larger tires for winter?
OEM spec 18 WRX runs 240/45/18 I believe. I was thinking of the Michelin X Ice Xi3 with stock wheels, then getting a summer set up later on.
vlad11591 is offline   Reply With Quote
Old 09-27-2018, 10:59 AM   #7800
Obviously Tyler
Member#: 395955
2021 Mazda 3 Turbo
2017 MX-5 RF Club
Originally Posted by vlad11591 View Post
QQ
Generally you want narrower tires for cutting through snow rather than climbing on top of it. But a dedicated snow/ice tire in 245 should be just fine.
