07-26-2001, 04:04 AM | #1 |
Member#: 1170
BAIC
Vehicle:2005 STi White |
How do torque converters work?
I know this is a great mod for automatic cars and I always suggest it to people to have it done, but im not sure how they work. Could someone explain how they transfer torque and why higher stall speeds are better for higher powered cars. Also what "locks up" in them?
07-26-2001, 09:31 AM | #2 |
Member#: 5470
Vehicle:2014 Honda Odyssey Nondescript |
check out www.howstuffworks.com and do a search. It's a really good site for stuff like that.
07-26-2001, 10:51 AM | #3 |
Member#: 1904
TXIC
Vehicle:2017 Impreza Sport E36 M3/4/5 |
they're not a "mod". They are the clutches in an auto. Basically, they use fuild, which heats up when the plates inside (one attached to flywheel, one to tranny) spin at different speeds. The hotter the fluid gets, the thicker it gets, which makes the plates spin at the same speed.
but yeah, check out the howstuffworks web page. |
07-26-2001, 05:34 PM | #4 |
Member#: 1170
BAIC
i meant "mod" only as to upgrading the stock one. not something you would just add because it doesnt have it...
thanks for the site, ill check it out later tonight |
07-26-2001, 10:12 PM | #5 | |
Member#: 4021
NESIC
Vehicle:1999 Legacy GT Ltd Quick Silver Metallic |
Most fluids, such as automatic transmission fluid, tend to become more viscous (easier flowing) the hotter they become. The wisdom of utilizing a torque converter with a HIGH stall rate is to assure that the engine is in its correct 'powerband' when the car starts moving forward. Most typical Automatic transmission vehicles suffer from a brief delay period when first starting out from a dead stop. Many amatuer 'Drag Racers' will resort to 'brake standing' (nailing both the brakes and the throttle) before starting there runs in an effort to thward this tendancy. Installing a High stall speed torque convert also helps in this regard. |
07-26-2001, 10:49 PM | #6 |
Member#: 1904
TXIC
Jonathan: I would say we're both correct. The torque converter works in the same exact way the viscous center diff. works, just with a different fluid, and different number of plates.
07-26-2001, 11:17 PM | #7 |
Member#: 8679
Vehicle:2010 The most hated vehicle on the internets |
Viscosity
Most fluids become less viscous (flow easier) as they heat, although some behave in the opposite fashion. The AWD may also work off of the fact that viscosities can change as the fluid is pumped, irregardless of heat. A great example is blood; as long as blood is being pumped, it flows fairly easy. When blood is allowed to puddle though, the viscosity increases because it is not being pumped. And some plastics/polymoers thicken as they are circulated, which may be similar to something in a torque converter/AWD linkage. I know little about cars/car parts, I just remember some of this from a fluid mechanics course.
Corn-Picker |
07-26-2001, 11:54 PM | #8 |
Member#: 4021
NESIC
Corn-Picker -
Good point. Yes the Viscous coupling employed in Subaru's AWD set up does indead get thicker as it gets hotter. When the front and rear axles are turning at approximatly the same speed the coupling fluid is cool and flows fairly eaisily, allowing a certain amount of minor slippage (such as when taking a tight corner, for instance), however when one set of wheels begins to loose traction, very quickly this causes the fluid to heat up, and not allow much slipage, fourcing both axles to turn at the same speed. |
07-27-2001, 12:16 PM | #9 |
Member#: 1415
RMIC
Vehicle:2015 F150 3.5EB 2014 Jeep GC |
Someone suggested www.protorque.com. Once I have all the data needed to have one made I will do just that. If we were able to bring the RPM's up a little higher (instead of brake standing) the auto's would jump off the line pretty well. This is a common upgrade for the Aus/Europe WRX gents. They also run one to two tranny coolers. There is/was a forum out there for Auto WRX's. It was very very informative.
Shawn |
07-28-2001, 11:14 AM | #10 |
Member#: 4423
Vehicle:'04 08 Tribeca, SVX Gold, Maroon |
Hello Moderator, please pardon my impudance for not agreeing with you. Torque Convertors consist of an Impellor, a Stator, and a Turbine as their major parts. There are no friction plates in a Torque Convertor.
Subaru also uses a computer controlled Lock-up mechanism in the Torque Convertor. Last edited by SubyTechMaster; 07-28-2001 at 11:17 AM. |
07-28-2001, 11:37 AM | #11 |
Member#: 1904
TXIC
hey, I don't claim to know it all
that was just the understanding I had about them...I was wrong. |
how do i convert my 4.11 to 4.44 | TurboCharged97L | Transmission (AT/MT) & Driveline | 7 | 08-18-2006 12:46 PM |
how do i convert my 4.11 to 4.44 | TurboCharged97L | Subaru Conversions | 4 | 07-18-2006 02:31 AM |
how do i convert a .DAT file into a .CUE file? | MyScoobie28 | Off-Topic | 10 | 09-23-2005 08:32 PM |
C++ How do you convert from a float to an integer? | Corn-Picker | Off-Topic | 28 | 10-04-2002 03:56 PM |
how do i convert this? | nitrousjunkie68 | General Forum Archive | 4 | 03-28-2001 07:13 PM |
